notchboy Samba Member
Joined: April 27, 2002 Posts: 22460 Location: Escondido CA
Posted: Sat Jan 03, 2009 10:11 pm Post subject: Eberspacher Gas Heater 101(tech session) |
Yesterday I recieved a very special package. It contained a compleet East-West configuration Eberspacher BN2 Gasoline Heater. This set up was made for two years only before being phased out. Its an important piece of the history of the BN2 as it was the first of its type and was deemed important enough for VW to change the sheet metal stamps in order to accomodate it. I belive that due to its elaborate design and cumbersome install, it was totaly replaced by the (compared to this) North-South design.
If you look at 65 and up front nose panels you will notice the oval stamps found on eithor side of the spare tire well. These stams were made to assist the instalation of this type of heater. VW also made changes to the cabin wall to help install the Noth-South type as well. Prior to the cabin walls flat surface, there were ridges in the panels. I borrowed some of Berts 68 fasty photos to help illustrate.
Up until now Ive only seen pictures of this rare beast. I was fortunate to work out a deal with Gary LaVere of LaVere's VW Restoration in Concord Ca. He had Denny Vargas pull this unit from a 65 notcback and ship it out to me. Thanks again guys for taking the time and ensuring I got all the bits. Beer is on me!
Just by looking at the blow out view you can see that it has alot of little parts. Most of which are type 3 specific. Even the on/off switch is for a type 3. It has a stand off that compensates for the angle of the dash. Ask tomnotch how hard those are to find
The parts that realy make this set up stand out from the other units is the need for long tubes to streatch under the front fenders. This cumbersome install was surly its downfall.
If you look close at the above photo you will notice that the front portion of the tube is installed at a shape angle different from the oval stamp angle I described above. Thats because this 64 or early 65 dosnt have the oval stamps and was cut as best the tech thought at the time.
Here are the tubes off the car. They measure about 5.5 to 6 ft!
Last shots are of the oval tube housing, the complicated switch (thats not even the the realy complicated one!) and a real red gas cap next to on of Bezelworks fine reproductions.
Now go impress you friends down at the pub _________________
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
1977 Westfalia Camper pop-top
ibjack Samba Member
Joined: February 06, 2002 Posts: 2106 Location: Imperial Beach CA
Posted: Sun Jan 04, 2009 12:16 am Post subject: |
I loathe you Mr.Notchboy!!!!! _________________ '68 Lotus White T34 automatic sunroof
'64 Manila Yellow T34
'65 Sea Blue Square Panel
the1500club.com
Shop Lacky at the T3/34 Factory, https://www.facebook.com/profile.php?id=100094313902074 |
JSMskater Samba Grease Gorilla
Joined: February 01, 2006 Posts: 5362 Location: Murrieta California
Posted: Sun Jan 04, 2009 12:57 am Post subject: |
watch-- your fancy pants heater has just laid VOODOO on your engine.
nice score-- I actually think I like the long hose/tube idea better than the sketchy hacking of the front firewall/trunk area. I still have to patch the gaping hole under my dash where the A/C crap used to go _________________ 71 Squareback-FI -- 73 Bay (subaru powered)
TOOB Member #3
I make D-jet FI connectors |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21518 Location: Oklahoma City
Posted: Sun Jan 04, 2009 11:46 am Post subject: |
You are gonna love it. Gasoline heat is one of the really nice things about driving my 412. It has the BA4. Sweet! Ray |
DucMike Samba Member
Joined: November 27, 2006 Posts: 156 Location: Outskirts of Sacramento, CA
Posted: Mon Jan 05, 2009 5:23 pm Post subject: |
Dammit! I was dreaming of that heater set-up back when Denny showed me pix of the car. IIRC, they weren't parting the heater off the car at that point. Had I known...
Probably would have even mix-n-matched the set-up with the brand-new-in-crate BN gas heater set-up I have. I've always prefered the East/West layout over the North/South.
Oh well; ces't la vie. _________________ Mike S.
'66 Variant Sunroof TIII4ME
'76 Rabbit
'91 Passat Variant (Big 'back)
'96 GTI VR6
'03 20th AE GTI OEM+ 20th
Niello Ranch Run |
Sumguy Everett's Parts Holder
Posted: Mon Jan 05, 2009 6:53 pm Post subject: |
Very cool heater. Gary is across town from me , wish i would of known i could of maybe helped ya.
Where did they mount the spare tire being the heater was in the tire well ?
On top of the gas tank with a speical mount or ? |
Posted: Mon Jan 05, 2009 7:46 pm Post subject: |
The tire goes in the same place. Think of the heater mounting in the space above the horn.
On a T34
In a T3
t3kg wrote: |
1964 1500 S
Posted: Mon Jan 05, 2009 8:00 pm Post subject: |
Ah....that makes sense. Looks like a tight fit , must be a pain to work on it while it is in the car. Good use of that space though and you still have the whole trunk to use. |
Posted: Mon Jan 05, 2009 8:16 pm Post subject: |
Sumguy wrote: |
I think thats what helped it-space in the actual trunk and its down fall-people realy didnt care about the lost space (for the N-S aplication).
t3kg wrote: |
1964 1500 S
t3kg Samba Member
Joined: June 14, 2006 Posts: 2712 Location: Los Angeles
Posted: Tue Jan 06, 2009 7:02 am Post subject: |
t3kg wrote: |
I wonder if this heater is why the horns were moved outside behind the bumper on Type 34s in 1964 or 65? The horns on my '62 would be in exactly the wrong place. |
Good point. One more detail to add to why things were moved around. _________________
t3kg wrote: |
1964 1500 S
tomnotch Samba Member
Joined: October 22, 2004 Posts: 788 Location: Key Peninsula, Wash.
Posted: Tue Jan 06, 2009 4:41 pm Post subject: |
Naw. I think people just didn't like building a camp fire on top of the gas tank........
notchboy wrote: |
_________________ Tom
DVKK
DSD, Dark Side Disciples
Progenitor |
Posted: Mon Jan 12, 2009 8:04 am Post subject: |
Ive got it all pulled apart and inspeted. One of the leadind causes of people not getting these things to run is the rubber diaphram gaskets in the fuel pump and he meetering diaphram. They get hard of the years from the gas and or age wearing on them. I however was seriously lucky. The pump and the meeter are still plyable! And the glow plug works. I would of bet I could of added gas and power and this sucker would of powered up without a problem.
I did however tear it down to get it restored. The crackle finish is a HomeDepot shelf item and matches perfect. Cleaned and painted. Now onto reasembly and firing it up.
t3kg wrote: |
1964 1500 S
Adriel Rowley Samba Member
Joined: October 12, 2006 Posts: 4748 Location: Mesa, Arizona
Posted: Mon Jan 12, 2009 1:50 pm Post subject: |
Yes there should be flat spots in the metal for a N-S config heater in later T3s. And for sure this design was long gone by the time the fat chick made her way into the room _________________
t3kg wrote: |
1964 1500 S
Typ311Dave Samba Member
Joined: June 16, 2006 Posts: 1253 Location: San Diego, CA "6-Volt"
Posted: Mon Jan 12, 2009 8:12 pm Post subject: |
raygreenwood wrote: |
Yeah, but in Texas? _________________ '62 golfblau Typ 311 Limousine
'89 Vanagon GL Bluestar
"The object of war is not to die for your country but to make the other bastard die for his." - Gen George S. Patton |
Posted: Tue Jan 13, 2009 6:36 am Post subject: |
architect_7 wrote: |
Typ311Dave wrote: |
Yeah, but in Texas? |
You be surprised. If he is in the hills, it can snow, I.I.R.C.. If he is in the desert, it gets COLD at night, especially just before sunrise. |
Not quite the hills but it does get colder here than San Diego! And I had one there All the lovely air from Canada through the mid west comes right through here. _________________
t3kg wrote: |
1964 1500 S
