burleymotorsports Samba Member
Posted: Sun Jan 04, 2009 9:23 pm Post subject: Burley Motorsports News |
Hello, My name is Burley,I am new to this forum. Some of you may know me I am the owner of Burley Motorsports,we make custom vanogan parts for subaru conversions and alot of custom suspention parts for both Syncro and 2wd.as well as other trick vanogan bits. Just wanted to introduce myself and let everyone know that I want to participate with helpful info whenever possible,and thank you for letting me join. Thanks Burley
*Burley Motorsports - World Class Custom Syncro Parts*
Facebook.com: burleymotorsports
Instagram: burleymotorsports |
iltis74 Samba Member
Joined: November 20, 2003 Posts: 826 Location: Anchorage, AK
Posted: Sun Jan 04, 2009 9:50 pm Post subject: |
Hello and welcome. You have good timing, your name recently came up here when some of us were wondering about the possibilities of running a front upper control arm ball joint spacer on a two wheel drive. I don't mean to put you in a situation you may not want to be in, but any info or thoughts you had would be great. Thanks.
http://www.thesamba.com/vw/forum/viewtopic.php?t=327242 |
Posted: Sun Jan 04, 2009 10:16 pm Post subject: Burley Motorsports 2wd ball joint spacer |
Well you have good timing too. As a matter of fact I will be making some 2wd upper ball joint spacers this week. I already make them for the Syncro, and it seems that lifted 2wd's lack enough camber adjustment as well. These spacers will be the same, except a chamfer will be necc on the outer edge to let them fit the 2wd. I have a set of 2wd arms here for ''mock up fit''. We are also in the testing phase of our 2wd tubular upper control arms,there are pictures on our website, click on ''current projects''. These are for the guys that like to get as much lift as possible on a 2wd. I have been selling these arms for Syncro's for a couple years. The spacers have been working well with no problems, I supply 12.9 grade bolts with them. Of coarse for severe and harsh use conditions we reccomend installing our tubular arms instead of spacers. It seems if you put 2'' or more lift the camber problem presents itself. How much lift does your van have? Thanks Burley www.burleymotorsportsdirect.com |
madspaniard Samba Member
Posted: Sun Jan 04, 2009 10:42 pm Post subject: Burley Motorsports 215 tire mount |
Hi, sorry I dont have a 2wd version right now,but I will sell just the steering shaft gaurd piece seperatly and I can tell you when I was working for Seth how we did our spare tire mod. we were cutting the hindge point off of the subframe,flipping them over and welding them back on,to lower the hindge point of the clamshell, then we cut about 1 1/2'' off of the outside of the clamshell,this lets the tire fit in it, then we added about 1 5/8 to the front where the bolt goes through,this can also be done with a spacer and a longer bolt, and we installed the steering shaft gaurd to keep the tire from rubbing on the shaft and making the steering feel tight and sticky. I forgot, we also removed the rods on the top of the tire mount cavity. I have had a lot of reqests for a 2wd version,and I will be making some very soon. Burley www.burleymotorsportsdirect.com |
Posted: Thu Dec 29, 2016 11:31 am Post subject: Re: Burley Motorsports |
Thanks to the awesome crew at The Samba we have been given approval to use this thread for all things Burley at Burley Motorsports.
That said ,
we will be using this thread periodically to make new product announcements, fun things we are doing ,announce sales etc .
So for today we want to reach out and let you guys know that we still have some selected items on sale on our website.
Also we want to say
THANK YOU to all those that have given us great support over the years
After many years of working in various arena's of motorsports I must say
this is a very enjoyable group to serve.
Happy New year everyone _________________ Protect your investment !
Buy only genuine Burley Motorsports products
I will not see your PM.
Please email us directly through our website at http://www.burleymotorsports.net . Thank you.
Web: http://www.burleymotorsports.net
Facebook: http://www.facebook.com/burleymotorsports
Instagram: http://www.instagram.com/burleymotorsports |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16505 Location: Brookeville, MD
E1 Samba Member
Joined: January 21, 2013 Posts: 6571 Location: Westfalia, Earth
Posted: Thu Dec 29, 2016 1:09 pm Post subject: Re: Burley Motorsports |
Second that! _________________ ‘84 Westy, 2.1L with Digijet, 5.43 R+P, GT Gears
— Colin Chapman |
Stephan Schmidt Samba Member
Joined: March 26, 2002 Posts: 213 Location: Vancouver, BC, Canada
Posted: Thu Dec 29, 2016 4:13 pm Post subject: Re: Burley Motorsports |
I just placed an order with Burley today and I have to say that he was great to deal with! I'm excited to install this new heavy-duty hitch!
Stephen |
Mathew Zelezen Samba Member
Joined: November 04, 2004 Posts: 547 Location: Graeagle, CA
Posted: Thu Dec 29, 2016 8:06 pm Post subject: Re: Burley Motorsports |
Hey Burley I was just on your site and couldn't find one but do you guys make a straight shaft (driveshaft) for the Syncro? There is a used one in the Classified Section but again didn't see anything on your website.
Cheers!
Mathew _________________ 87 Syncro Tintop
~Rocky J Motor
~Steedle Trans
Of all sad words of tongue or pen, the saddest are these: It might have been. |
Ryan Keating Samba Member
Posted: Thu Dec 29, 2016 11:38 pm Post subject: Re: Burley Motorsports |
Just installed my third spare tire rack I've purchased from Burley tonight. Fit was amazing and easy to install. Over the years I've purchased many parts and quality was always great. plus if I had a question on conversions or crazy idea I had he has always had time to answer me even when I know he doesn't. Did I mention his parts are great. Thanks Burley |
Posted: Fri Dec 30, 2016 10:09 am Post subject: Re: Burley Motorsports |
Mathew Zelezen wrote: |
Cheers!
Mathew |
Hi Mathew , I'm sorry we don't have any drive shafts for sale at the moment.
I may as well announce it now
We did find a new source for nice brand new driveshafts , with replaceable u joints and slip yokes.
At the the moment we have a couple of these new units out in testing and have been very pleased with the results.
I don't think I'm allowed talk price on here but I think its ok to say the price will be attractive
I'm in gear to be releasing the new product in mid Jan 2017.
Will post pics soon too. _________________ Protect your investment !
SyncroNelly Samba Member
Posted: Fri Dec 30, 2016 10:11 am Post subject: Re: Burley Motorsports |
I have always told people about Burley. He is always effusive in his help, and his products are top notch! Team Burley! |
Posted: Fri Dec 30, 2016 10:45 am Post subject: Re: Burley Motorsports |
The world of the Vanagon is about to get a lot bigger..
Thanks for the heads up Burley! I'll be looking for your release with great anticipation. PM me if you need some further road testing. _________________ 87 Syncro Tintop
~Rocky J Motor
~Steedle Trans
dyldebus Samba Member
Posted: Mon Jan 23, 2017 5:47 pm Post subject: Re: Burley Motorsports |
Dang, just installed the Gowesty one.... this looks very nice! |
tjet Samba Member
Posted: Tue Feb 21, 2017 4:38 pm Post subject: Re: Burley Motorsports |
Got my Burley A-Arms & 930 front axle kit installed in my rusty Syncro
Sodo Samba Member
Joined: July 06, 2007 Posts: 9618 Location: Western WA
Posted: Tue Feb 21, 2017 4:47 pm Post subject: Re: Burley Motorsports |
That's some wicked stuff. That dog needs a lift too. _________________
....KTMs, GasGas, SPOT mtb
WestleyTheWesty Samba Member
Joined: October 07, 2015 Posts: 128 Location: Portland, OR
Posted: Wed Feb 22, 2017 11:26 am Post subject: Re: Burley Motorsports 215 tire mount |
I was wondering if you've looked into creating a 2WD version of the under-mount spare tire carrier for oversized tires? A lot of 2WD vans like to run 215/70/15's and it would be nice to have an option to use the regular location, thanks!
burleymotorsports wrote: |
_________________ 1990 Westy, started stock, not anymore! |
