crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 9936 Location: Orbiting San Diego
Posted: Fri Sep 14, 2018 11:48 am Post subject: Re: Burley Motorsports News |
They use the same bolt pattern.
Aircooled axles were slightly longer than wbx axles, both sides.
Might not matter, maybe unless lifted.
Mark
Stuartzickefoose wrote: |
On the high angle axles...
A) are they a stock VW bolt configuration, or the 944 bolt pattern?
B) if they are stock VW, what keeps them from fitting an aircooled transmission? (The joints, not the axle length itself)
I ask to know if I can take the joint and install it on a automatic axle, and put it on an aircooled...
Thanks! |
Stuartzickefoose Samba Post Whore
Joined: February 07, 2008 Posts: 10350 Location: SoCal for now...
Posted: Fri Sep 14, 2018 12:15 pm Post subject: Re: Burley Motorsports News |
crazyvwvanman wrote: |
Mark
Thanks! |
That’s what I figured. So if it’s a stock VW bolt pattern and spline pattern, I can simply swap the joints onto my automatic aircooled axle shafts. Which I may need to do since I sit at 19” in the rear on syncro springs _________________ Stuart Zickefoose
206-841-7324
[email protected] |
burleymotorsports Samba Member
Posted: Sat Sep 15, 2018 12:17 pm Post subject: Re: Burley Motorsports News |
[quote="Stuartzickefoose"][quote="crazyvwvanman"]They use the same bolt pattern.
Mark
[quote="Stuartzickefoose"]On the high angle axles...
Yes the 944 joints will fit your air cooled axles .
Burley Motorsports has high quality 944 joint kits that come with boots and grease etc in stock now.
Will be posting them on our website for sale Monday.
The price is $49 ea for these kits. _________________ Protect your investment !
Buy only genuine Burley Motorsports products
I will not see your PM.
Please email us directly through our website at http://www.burleymotorsports.net . Thank you.
Web: http://www.burleymotorsports.net
Facebook: http://www.facebook.com/burleymotorsports
Instagram: http://www.instagram.com/burleymotorsports |
Posted: Sat Sep 15, 2018 1:38 pm Post subject: Re: Burley Motorsports News |
Sweet!
So to recap:
The joints you sell allow for install on any van axle, auto or manual or air or water, and bolt directly onto a factory VW axle flange? Or will I still need 944 flanges? _________________ Stuart Zickefoose
206-841-7324
[email protected] |
Posted: Sun Sep 16, 2018 9:38 am Post subject: Re: Burley Motorsports News |
Sweet!
So to recap:
The joints you sell allow for install on any van axle, auto or manual or air or water, and bolt directly onto a factory VW axle flange? Or will I still need 944 flanges? |
Yes that is correct , the 944 cv joint and cv flange and the type 2 bus / vanagon flange is the same diameter and bolt pattern etc so they bolt directly on.
I should also mention the 944 axle splines are the same as the type 2 bus / vanangon axle splines so its a direct replacement part with a bonus of some added cv angle articulation.
The 944 cv's have smaller balls inside that allow this added angle articulation.
This added angle is helpful in applications where the van ride height has been lifted.
KEEP IN MIND :
the 944 cv's and axles as stated are great for a reasonably built van .
They are not a substitute for applications that should have the heavy duty 930 axle's installed.
944's are not for extremely heavy or extremely lifted applications.
Its basicly a free upgrade when replacing the stock axle where it fell a little short in performance.
BTW :
BMS has the best 930 kit on the market at the best price for quality of parts and engineering included in the kit.
The BMS 930 kit has superior engineering that keeps the cv bolts tight .
The other kits on the market suffer from cv bolts that continually come loose when installed on heavy vans.
Cv bolts coming loose at the wrong time could be lethal , not to mention a real downer on your family outing. _________________ Protect your investment !
Posted: Sun Sep 16, 2018 9:50 am Post subject: Re: Burley Motorsports News |
And that’s my mistake, I was forgetting 944 vs 930...that’s why I wanted to clarify! Thanks! _________________ Stuart Zickefoose
206-841-7324
[email protected] |
Posted: Tue Sep 18, 2018 9:51 am Post subject: Re: Burley Motorsports News |
And that’s my mistake, I was forgetting 944 vs 930...that’s why I wanted to clarify! Thanks! |
No problem , we are always happy to help with tech support so that folks get the right parts for the correct application.
In the event you would like a 930 kit or 944 parts please email us through our website.
Currently we do have some special offers going on. _________________ Protect your investment !
Syncronoid Samba Member
Joined: January 21, 2012 Posts: 1111 Location: Stanford, CA and Bend, OR
Posted: Fri Sep 21, 2018 5:12 pm Post subject: Re: Burley Motorsports News |
Who wants to see the New Generation Upper Control Arms in Silver? Me!! _________________ '90 Syncro Westy w/GW2.5L |
Posted: Sat Sep 22, 2018 10:24 am Post subject: Re: Burley Motorsports News |
Syncronoid wrote: |
Who wants to see the New Generation Upper Control Arms in Silver? Me!! |
A group buy would allow us enough parts to make a batch in raw aluminum finish that you guys could have custom anodized or powder coated any color.
Or if enough people wanted aluminum color we could have that batch clear anodized. _________________ Protect your investment !
Posted: Wed Oct 03, 2018 1:56 pm Post subject: Re: Burley Motorsports News |
It's out!
We have grabbed a bull by the horns with this one! In our latest newsletter, we describe our bushings and heim joints, what to look for and why, when and where they are needed, and our concerns with other-brand bushings. This has been a hotly contested debate on The Samba, and we hope to clear everything up in this article.
Happy Trails FOREVER!
If you are interested in reading the article in its entirety, along with other articles and BMS special coupons, for the next 7 days we will retroactively send out the newsletter to anyone who is interested:
https://burleymotorsports.net/receive-our-quarterly-newsletter/ _________________ Protect your investment !
SyncroChrick Samba Member
Joined: January 10, 2005 Posts: 1010 Location: San Francisco, CA
Posted: Fri Oct 12, 2018 6:18 pm Post subject: Re: Burley Motorsports News |
Keep up the good work! I haven't had the opportunity to buy from you yet, but I plan to do it in the near future!
Just signed up. |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17154 Location: Retired South Florida
Posted: Sat Oct 13, 2018 4:10 am Post subject: Re: Burley Motorsports News |
I signed up as well. I do have a question about the 944 cv joint kits. What boots come with those kits? Are the bolt flanges bonded or clamped? How are they holding up. Thanks for supporting the hobby. Mark _________________ ☮️ |
Posted: Sat Oct 13, 2018 10:44 am Post subject: Re: Burley Motorsports News |
MarkWard wrote: |
I signed up as well. I do have a question about the 944 cv joint kits. What boots come with those kits? Are the bolt flanges bonded or clamped? How are they holding up. Thanks for supporting the hobby. Mark |
Hi Mark , That's awesome , we'll forward this months news letter to you
The boots are made for us so its our own private label brand , we spent 2 years working with a factory and testing these boots , joints and axles.
We have over 40K test miles on our axle assemblies ( and other new parts offerings ) without issue , testing includes some off roading at Moab
The boot is factory crimped to the flange.
We have tried to cover all the bases on the 944 axle situation.
With the oem VW axles getting older we are now seeing broken axle shafts so we also offer brand new bare axles for those folks that want to build up their own axle assemblies with the cv joints and boots of their choice.
BMS 944 axle offerings :
944 complete axle assemblies
944 cv joint w/boot kit
944 cv boot kits
944 bare axles
All at affordable prices _________________ Protect your investment !
Posted: Sat Oct 13, 2018 11:02 am Post subject: Re: Burley Motorsports News |
Ok, I'm ordering some of dem new axles today!
Mark |
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5911 Location: Tsawwassen, BC
