Okrasa in Ghia, problems with my decklid springs
pbaptist
pbaptist is offline
PostPosted: Wed Jan 07, 2009 2:09 pm    Post subject: Okrasa in Ghia, problems with my decklid springs Reply with quote
Hallo all
I have a question for other Okrasa ghia drivers
I recently installed an original set of the ghia elbows on my Okrasa engine, but still am not able to install the decklid springs. I can install the spring on the right side, but not on the left side.
I have very little space between the springs and my fuel lines. How is this in other Okrasa powered ghia's?
My engine:
space on the left side:
Space on the right side
Pictures of other Okrasa powered ghia's with elbows. All of them has the springs installed. What is wrong with mine?? Confused
Patrick
Dutch Karmann-Ghia and coachbuild lover.
1* Karmann Ghia Coupe (1966 Teak)
2* Karmann Ghia Convertible (1958, 1971)
4* Rometsch Lawrence (nr 534, 555, 558 and 561)
Karmann-Ghia Lowlight page and registry
Karmann-Ghia Collectibles database
water guy
water guy is offline
PostPosted: Wed Jan 07, 2009 9:26 pm    Post subject: Reply with quote
I have no idea's except for a guess. Could the mounts for the tranny cause the engine to sit up to high?
'55 Porsche Continental
'63 Firetruck
sub-hatchtim
sub-hatchtim is offline
PostPosted: Thu Jan 08, 2009 12:31 am    Post subject: Reply with quote
your engine appears to sit higher than the others
Stock Steve
Stock Steve is offline
PostPosted: Thu Jan 08, 2009 2:11 am    Post subject: Reply with quote
Maybe a measurement comparison could be made of the gap between your abarth exhaust pipes and the body, with someone else's early Ghia running the similar exhaust. Might provide additional clues as to what's going on?
Stock Steve
Shoreline Antique Auto Connection
http://www.shorelineantiqueautoconnection.com/
Ich Bin Ein Facebooker: https://www.facebook.com/steve.fromsaac
Join VVWCA: http://www.vvwca.com/
Your source for old school metal tire valve caps: http://www.thesamba.com/vw/classifieds/detail.php?id=1416217
Thanks Veterans
mightymouse
mightymouse is offline
PostPosted: Thu Jan 08, 2009 2:52 am    Post subject: Reply with quote
Others have already beat me to it. Smile
Sure you have the correct bell housing cradle? prob a later one.
Seems your motor sits higher in the bay than any other ive seen.
No frame horn repairs, or torsion housing repairs have been done?
Well await the answer..
Nothing can stop the man with the right mental attitude from achieving his goal; nothing on earth can help the man with the wrong mental attitude.
Thomas Jefferson
Note to EVERYONE.
Know your ZDDP levels or you WILL lose a cam and lifters.
water guy
PostPosted: Thu Jan 08, 2009 8:38 pm    Post subject: Reply with quote
Its gotta be the tranny mounts or related parts. Looking at the pictures, the lower pulley nut is hardly visable. In your photo, its way up by the decklid latch. Very odd! Or could it be the front mount has the front way to low. That could push up the back.
'63 Firetruck
Stock Steve
PostPosted: Fri Jan 09, 2009 6:15 am    Post subject: Reply with quote
water guy wrote:
...Or could it be the front mount has the front way to low. That could push up the back.
Aha, another good thought.
Reminds me a bit of the old "*1960 only* front transmission mount" bugaboo.
Stock Steve
Thanks Veterans
water guy
PostPosted: Sun Jan 11, 2009 11:05 am    Post subject: Reply with quote
Is the problem fixed?
'63 Firetruck
