adriaan pienaar Samba Member
Joined: February 17, 2003 Posts: 692 Location: Sedgefield, South Africa
Posted: Thu Jan 08, 2009 1:17 pm Post subject: Type 3 Rear drum brakes parts interchangability question |
Hi Guys, I hope you can help me with a few answers. I went IRS on my buggy project, with Type 3 drum brakes at the back. Would the connecting link plate (arrowed in the pic) of a Beetle work on a Type 3, are they the same?
Would Beetle rear brake cylinders (with the bleeding nipple below the brake line connector) work on Type 3 rear brakes, and would one be able to fully bleed the brakes? Thanks! _________________ Please say Hi to us at
www.aircooledvwsa.co.za &
http://hotwheelsclubza.freeforums.org |
flyinglow94 Samba Member
Joined: January 17, 2005 Posts: 1164 Location: Las Vegas, Nevada
Posted: Thu Jan 08, 2009 3:05 pm Post subject: |
I pulled this from my other post. 64-65 Wide 5 Type 3 rear drums use the same brake shoes as the 66-74 type 3's and those shoes are the same as the 73 and up super beetle front shoes. You can also use the super beetle front wheel cylinders for type 3 rear replacements. But I would think the plate would be type 3 specific because the drums are a larger diameter than the bug. _________________ "What we obtain too cheap, we esteem too lightly: 'tis dearness only that gives everything its value. Heaven knows how to put a proper price upon its goods; and it would be strange indeed if so celestial an article as FREEDOM should not be highly rated."
"Socialism is a philosophy of failure,the creed of ignorance, and the gospel of envy,its inherent virtue is the equal sharing of misery.." |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21476 Location: Oklahoma City
Posted: Fri Jan 09, 2009 8:01 am Post subject: |
It fits type 4 (411 and 412)as well. I have used in a pinch ones slightly modified from a late bus....about 1976...sorry I can't remember exactly which one. Ray |
Dunebubby Samba Thread Killer
Joined: October 12, 2006 Posts: 882 Location: In my den,throwing darts at a picture of my ex-boss
Posted: Fri Jun 26, 2009 11:36 pm Post subject: |
The only difference in the type 3 rear brakes is the width of the Brake shoes and brake drum. 30mm for the beetle versus 45mm for the type 3.In other words the type 3 rear brakes are half a brake pad wider than the bug brakes.
All of the bug brake hardware should work on the type 3 rear brakes except the (brake shoe),hold down pins. The pins that hold the brake pads down to the brake backing plate,(those need to be longer to accomodate the wider brake shoes).. The diameter of the drum is no larger. The beetle hardware will work great. _________________ "We buy things we don't need,..with money we don't have,...to impress people we don't even like". |
Chris Vellat Samba Member
Joined: April 09, 2004 Posts: 1590 Location: Seattle, WA
Posted: Sat Jun 27, 2009 12:06 am Post subject: |
Dunebubby wrote: |
The only difference in the type 3 rear brakes is the width of the Brake shoes and brake drum. |
The width and radius are different, the brake drum is of course different, the wheel cylinders are different, the two smaller brake shoe retaining springs(at the adjuster housing), as well as the pins. EDIT: duh, I forgot backing plates
Dunebubby wrote: |
30mm for the beetle versus 45mm for the type 3.In other words the type 3 rear brakes are half a brake pad wider than the bug brakes. |
30mm is early Beetle/Ghia - `68+ is 40mm including Beetle/Ghias/Things
Dunebubby wrote: |
All of the bug brake hardware should work on the type 3 rear brakes except the (brake shoe),hold down pins. The pins that hold the brake pads down to the brake backing plate,(those need to be longer to accomodate the wider brake shoes).. |
Actually 'normal' Beetle/Ghia/Thing IRS pins will work fine.
Dunebubby wrote: |
The diameter of the drum is no larger. The beetle hardware will work great. |
The diameter is quite larger. From 9.112" (legal limit) to 9.782(new)-9.822" (legal limit).
Supers fronts use 23.8mm wheel cylinders, while your typical Type III wheel cylinder is 22.2 - I think there's a catch on the very early Type III's. |
RichardinNZ Samba Member
Joined: September 16, 2011 Posts: 280 Location: Auckland, New Zealand
Posted: Tue Apr 14, 2015 3:57 pm Post subject: Brake Springs |
Does anyone know whether the lower (short) brake springs are similar to any other VW springs? I can't get the correct ones here and the shipping cost of a spring kit from the USA is disproportionate to the cost of the springs (about $25)! I can easily get most Type 1 and Type 2 springs, so if any are similar that would help a lot.
Thanks
Richard _________________ Richard
'58 Beetle; NZ Assembled
Dual Carb 36hp
My Car https://www.thesamba.com/vw/forum/album_page.php?pic_id=1750253 |
toddgsanford Samba Member
Posted: Tue Apr 28, 2015 8:04 pm Post subject: |
I have installed type three brakes on several type ones and this part is the same and works just fine.
Also the I of for rear wheel cylinders being same as super beetle front is correct also. I did find out that the rear cylinders for a square back have a wider piston than the fast back or notchback version. Old school vw parts guy said they used to use those in super beetles that customers complained of poor front braking. |
