didget69 Samba Member
Joined: July 22, 2004 Posts: 4925 Location: Raleigh, North Carolina
Posted: Sat Sep 15, 2018 8:18 am Post subject: Re: CLKWRK's build |
CLKWRK: Have you verified that the oil passages from pump to case match up without obstruction?
I've had some pumps with holes that don't line up to the case openings.
bryan _________________ I never found the need to impress people with any mechanic certifications, trophies or track wins... unless it was for Mom to post on the refrigerator door. |
CLKWRK Samba Member
Joined: October 02, 2001 Posts: 566 Location: Toronto
CLKWRK Samba Member
CLKWRK Samba Member
Posted: Sat Sep 29, 2018 6:53 pm Post subject: Re: CLKWRK's build |
Here is an update ...
Looks like the weather is getting too cool to test out the a/c so I am going to let it rest till next season. I think the system is undercharged so I will be adding more refigerant.
I have turned my attention to the turbo, the Garrett TB0382 was always meant to be a place holder, its old (from a 1989 SAAB 900), too small and smokes.
So I have bit the bullet and picked up the correct turbo for my setup, Garrett GT2860RS (aka Disco Potato), its big, and spools fast on ball bearings, however its watercooled so I have to figure something out for it. Probably a simple cooling system
I am also hooking up the a/c and water injection to be controlled by my Electromotive ECU, and setting up proper boost control with my ECU. I am using its general purpose output features (GPO) _________________ 1971 ghia build:
http://www.thesamba.com/vw/forum/viewtopic.php?t=336744&start=0
Type 4 upright build:
http://shoptalkforums.com/viewtopic.php?f=1&t=134056
Instagram:
https://www.instagram.com/vantageaircooled/ |
Posted: Sun Sep 30, 2018 3:46 pm Post subject: Re: CLKWRK's build |
Re: your Turbo water cooling - an option you might consider would be to use a Mercedes or BMW (Bosch) Auxiliary Cooling Pump to run coolant in a closed loop through a small oil cooler with an electric fan. I am not sure of the duty cycle on the Aux pumps, but it's an option to investigate since it's designed for antifreeze/coolant.
Another possibility may be an external fuel pump to circulate the coolant, but I'm unsure of the fuel pump seal compatibility with antifreeze.
I'm working on a similar project, in reverse... I need heated coolant.
Bryan _________________ I never found the need to impress people with any mechanic certifications, trophies or track wins... unless it was for Mom to post on the refrigerator door. |
Joined: August 31, 2013 Posts: 12815 Location: North Carolina
Posted: Sun Sep 30, 2018 3:59 pm Post subject: Re: CLKWRK's build |
didget69 wrote: |
Re: your Turbo water cooling - an option you might consider would be to use a Mercedes or BMW (Bosch) Auxiliary Cooling Pump... |
Also found on ‘02-‘04 Golf/Jetta 1.8t. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
CLKWRK Samba Member
CLKWRK Samba Member
Posted: Mon Jun 10, 2019 6:44 pm Post subject: Re: CLKWRK's build |
So Last weekend I had a dyno day scheduled, my goal was to get 300hp out of a mostly stock type 4 long block.
I had to do some creative fabrication to get the air/water intercooler to fit without cutting the body and keeping my decklid
Even though peak hp was 29 shy of my goal, I think we were doing pretty good until my clutch started to slip (the red line on the graph stops where the clutch slipped)
I am planning on changing my KEP stage 1 clutch to a Stage 3 and returning in a few months, I think I can still hit my goal _________________ 1971 ghia build:
Instagram:
DORIGTT Samba Member
Joined: October 01, 2003 Posts: 257 Location: Forest Grove, OR
Posted: Tue Jun 11, 2019 8:08 am Post subject: Re: CLKWRK's build |
Nice work!!!
Was that horsepower @ the wheels, or extrapolated to crank horsepower? _________________ To err is human, but if the eraser wears out before the pencil does you're a major screw-up. |
CLKWRK Samba Member
Posted: Tue Jun 11, 2019 8:41 am Post subject: Re: CLKWRK's build |
Thanks, thats 271hp and 245ftlbs at the wheels!!
This is a mostly stock vw bus mongrel engine:
71mm stock crank x 94mm 914 2L mahle pistons (7cc dish)
web 86a 112LC camshaft
Unported bus 1.8L "S" cylinder heads
Garrett GT2860RS turbo
Electromotive EFI
23psi of boost
I ordered a Black Magic 6 puck clutch disk and Kennedy stage 3 pressure plate (the clutch was slipping and we had to detune it with electronic boost control)
Its going back to the dyno once that stuff gets the break in, gotta hit that 300 wheel hp goal of mine _________________ 1971 ghia build:
Instagram:
Posted: Tue Jun 11, 2019 10:53 am Post subject: Re: CLKWRK's build |
CLKWRK wrote: |
Its going back to the dyno once that stuff gets the break in, gotta hit that 300 whell ho goal of mine |
Nice!
But, is this Canadian or U.S. horsepower?
Is there a conversion rate?
CLKWRK Samba Member
Posted: Sat Dec 14, 2019 7:18 pm Post subject: Re: CLKWRK's build |
Updates...UPDATES!!!! _________________ To err is human, but if the eraser wears out before the pencil does you're a major screw-up. |
CLKWRK Samba Member
Posted: Wed Jan 01, 2020 10:09 am Post subject: Re: CLKWRK's build |
Here is a Jan 1st 2020 update (Happy New year!), there is lots to cover so I will keep it point form ...
- During the dyno run I noticed some excessive blow by, so shortly after I pulled the engine to address the clutch and investigate the blow by
- Upon disassembly I found that the 40 year old stock #3 Mahle piston ring land had cracked, so I ordered some Weisco pinto pistons (which have 24mm wrist pins), and installed some low compression (11cc) modified bus pistons to finish the season
- I drove it up to the Wolfsgart show in Vermont and managed to spin a rod bearing ... towed it back to Montreal in shame
- Upon 2nd disassembly, I discovered that a 26mm pump will drain the sump dry if you send it for a sustained 7k rpm rev limiter bouncing hooning session, this will lead to oil starvation and spun #1 rod bearings ... its time to start thinking about dry sumps again
- I put the engine is back together with forged pinto pistons and a deep sump, I set my rev limiter to 6500 which is fine since power output drops off after 6500 anyways
- I also chucked the iron clutch disk in the used parts pile because I HATE it, too heavy so it shifts crunchy if you don't baby shift, and makes a loud squealing noise every time it engages. I went with a cushlok disk and KEP stage 3 pp, I had to beef up the pedal cluster and throwout bearing lever ... we will see how this works out
Also during all of this I built two more engines, an identical spec spare engine for quick swaps should I decide to blow the fresh one up, and a 2.5L turbo spec T4 that I plan to upgrade to once the transmission is upgraded
Transmission upgrade
Up until now I have been running a beefed up dual side cover irs bug transmission with a ZF LSD and thing axles, it has the late bug 002 gears in it so it is pretty strong and I am not having any issues with it yet, however I know that I will be pushing the limits of this transmission with 300hp at the wheels and all that glorious torque, radial tires do help keep it alive.
I have an 091 transmission being built to fit in my ghia with weddle gears and a ZF LSD, once that gets installed I will be ready for the 2.5L turbo T4 which is capable of 400hp ... this is a 2021 season goal
(also 228mm clutch disk will be a nice upgrade with this combo too) _________________ 1971 ghia build:
Instagram:
70 140 Samba Member
Joined: September 22, 2002 Posts: 8471 Location: Ontario Canada
Posted: Fri Jan 03, 2020 7:05 am Post subject: Re: CLKWRK's build |
Bonne annee
Cool to see you still at it with this car. |
John Moxon Samba Moderator
Joined: March 07, 2004 Posts: 13943 Location: Southampton U.K.
Posted: Fri Jan 03, 2020 9:00 am Post subject: Re: CLKWRK's build |
As for saving the transmission, I'd run 155R15 tires as a fusable link...
Happy New Year!
will t Samba Member
Posted: Thu Sep 02, 2021 1:45 pm Post subject: wood rig for Ghia body |
CLKWRK wrote: |
Dropped by the shop today and the bodywork has started
I am expecting it to be in its first coat of primer by Friday |
Hi, I would like to make a frame on wheels out of wood like the one in the picture of your car at the body shop. Any idea as to the dimensions of the rig?
Thank you so much,
Will |
sputnick60 Samba Moderator
Joined: July 22, 2007 Posts: 3907 Location: In Molinya Orbit
Posted: Sat Sep 04, 2021 10:13 am Post subject: Re: CLKWRK's build |
Hey Clkwrk,
Any updates on your engine / clutch saga? I'm curious how the Kennedy disc worked out for you, as I've got a similar spec setup and was looking at the sintered metal discs as well. Then saw your post, and since this is primarily a street car, I don't need a God's Grip clutch disc. _________________ To err is human, but if the eraser wears out before the pencil does you're a major screw-up. |
