CiderGuy Samba Member
Joined: December 23, 2013 Posts: 1351 Location: Bucks County, Pa
Posted: Tue Mar 11, 2014 1:29 pm Post subject: Spark Plug question.. |
1970 Ghia motor numbers beginning with AE, would the spark plug be the larger longer thread WR8AP or the WR8AC size?
Thanks
Please see the enclosed picture. It may explain my confusion.
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76940 Location: Sneaking up behind you
Posted: Tue Mar 11, 2014 1:50 pm Post subject: |
Depends on the heads. Original heads are 1/2" but aftermarket could be 1/2" or 3/4". _________________ Glenn
Member #1009
#BlueSquare |
Posted: Tue Mar 11, 2014 2:11 pm Post subject: |
When I started the engine for the first time, the plug in the center shot out of the cylinder with the spark plug wire attached. I shut the motor down at once.
You'll see why I thought it might be a longer plug or thicker thread.... What do you think, or what do I try and do next? I haven't been able to get the plug on the left ( new plug ) started inside the cylinder.
c21darrel Samba Member
Kmolenda Samba Member
Joined: June 18, 2013 Posts: 309 Location: Cottage Grove Mn
Posted: Tue Mar 11, 2014 4:43 pm Post subject: |
Yup, it pulled the helicoil out. Not sure if you can re insert another one. I didn't have one shoot out, but the threads were all bunged up on one of mine, got a tap from napa and it worked great. |
Posted: Tue Mar 11, 2014 6:16 pm Post subject: |
Thanks guys, I do believe that you're correct and it is a helicoil. A buddy of mine just said the same thing. I am not sure how to approach the situation right now. Do I pull the head and take it somewhere? |
Danwvw Samba Member
Posted: Tue Mar 11, 2014 6:28 pm Post subject: |
You might try inserting a new helicoil coil but it would be good to check the heads threads with a the tap for that size of helicoil and if it is too loose your going to have to drill and tap it for a larger one. You can do it in the car but it's really tricky and you will get some aluminum down in the cylinder that will need to blow out on first start up (it may knock a little). Best solution would be to replace the cylinder head. Some shops will weld them up and re-drill them but it's got to be done right and you have to have the head off the car to do that. Spark Plug Hole head Repair, any advice? Is a link to when I did it, but mine failed to hold and I had to pull the head and have it welded a second time. I just changed the plug today: Spark Plug after 3000 miles in the type 1 1800cc engine and the new plug held fine, I used a torque wrench and torqued it to 24 ft/lbs. _________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
scotty timmerman Samba Member
Joined: January 10, 2010 Posts: 1000 Location: gigharbor W.A
Danwvw Samba Member
Posted: Wed Mar 12, 2014 1:12 pm Post subject: |
I would just try inserting a new helicoil first. The problem is finding something that will seal around it. The local VW shop here uses Red Thread Locker but it burns out. There may be a product somewhere made just for this application but I don't know what it would be? Perhaps Loctite 2620 high temperature high strength threadlocker available here at Fastenal. The stuff is good for 650' F! _________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
Posted: Wed Mar 12, 2014 1:45 pm Post subject: |
Danwvw wrote: |
I would just try inserting a new helicoil first. The problem is finding something that will seal around it. The local VW shop here uses Red Thread Locker but it burns out. There may be a product somewhere made just for this application but I don't know what it would be? Perhaps Loctite 2620 high temperature high strength threadlocker available here at Fastenal. The stuff is good for 650' F! |
Yes I think I am going to try and do this first. I will need to at the very least lower the engine to do it. Even after removing the battery, I couldn't see anything when I was trying to replace the spark plug that came out when the engine was first started.
Thanks |
