Alex6373 Samba Member
Joined: August 05, 2007 Posts: 882 Location: Vancouver Island,B.C.
Posted: Sat Jan 17, 2009 9:28 pm Post subject: type three single port manifolds on a type 1- 40 hp |
Question... Will a set of type three single port manifolds work on my 1200 as far as the fit both onto the motor and inside the house,i am looking for a mild upgrade to a stock motor thanks for any help or any positive advise! |
glutamodo The Android
Joined: July 13, 2004 Posts: 26325 Location: Douglas, WY
Posted: Sat Jan 17, 2009 9:56 pm Post subject: |
Do you mean dual carbs? I'm not sure if VW ever offered dual carbs when those very early type 3 heads with the right angle intake ports were in use. Most 1500s had the angled intake ports which are not compatible with 40HP heads. (You could always change to 1300 heads, but then you'd also be able to use a set of Weber SP ICT manifolds if you did that)
-Andy |
Posted: Sat Jan 17, 2009 10:19 pm Post subject: |
Andy thanks for the reply ,i was looking at the classified carburetor section and saw there was a type 3 duel carburetors set for a single port heads and as i am not to familiar with these was wondering if any one had tried to fit this type of manifold to the type 1- 1200 head . if this works on older type threes what would be the problem with using it on a 40 hp 1200 ?
Are they too short ( the Manifolds to install carbs on the top, i have read about problems with balancing pulses from the two sides)
http://i372.photobucket.com/albums/oo169/bml6117/2357340-1.jpg |
Rome Samba Member
Joined: June 02, 2004 Posts: 9653 Location: Pearl River, NY
Posted: Tue Jan 20, 2009 4:23 pm Post subject: |
Won't work. The 2 attachment studs on the 40hp are slightly closer together than those on the Type 3 single-port heads. Also, on the T3 SP heads (same as those on the 1300 and 1500 type 1 single port engines in the USA) the mounting surface on the head where you bolt on the manifold is slanted slightly outward. On the 40hp head the surface is flat/level- That's what glutamodo was referring to. |
Posted: Tue Jan 20, 2009 5:12 pm Post subject: |
Well, I was thinking of the angled/straight manifolds, but also was thinking of the very very early type 3s which I think did have straight-up manifolds... At least they look like it in the 10/1961 owner's manual:
-Andy
Posted: Tue Jan 20, 2009 6:05 pm Post subject: |
Thanks Both of you guys for the help and responses to my question's!!!!! |
