How to Narrow your own Beam !!!
Page: Previous  1, 2, 3, 4, 5, 6
ashman40
ashman40 is offline
PostPosted: Fri Sep 25, 2015 9:00 am    Post subject: Reply with quote
You know that the stock shock towers will probably hit the inner fender well if you cut 4" from the beams. 3" is the most I have heard where you can keep the towers. Even at 3", you may need to chop a notch from the inside of the towers or cut/bend the inner fender sheet metal to get the clearance to fit the beam. This is why you typically see a 2.5" narrowed beam. These fit well w/o any interference.
I think it is around 4" that many consider removing the shock tower all together. The shorter leaf springs make for a much stiffer ride which may be able to go without shocks.
AshMan40
db69
db69 is offline
PostPosted: Fri Sep 25, 2015 9:05 am    Post subject: Reply with quote
Now that's some valuable info! I will do some measuring and see if I can get by with 2.5" or maybe 3". Thanks!
ashman40
ashman40 is offline
PostPosted: Fri Sep 25, 2015 10:24 am    Post subject: Reply with quote
From earlier in this thread...
http://www.thesamba.com/vw/forum/viewtopic.php?t=1...;start=704
It seems to indicate you may be able to cut 4" and still have shock towers. Obviously, you will need some plate steel to weld into place to create the notched area. Another thing to add to your list.
Some aftermarket narrowed beams will have custom shock towers made from thick steel flats:
AshMan40
Frisky72
Frisky72 is offline
PostPosted: Sun Jan 10, 2016 7:33 am    Post subject: Re: How to Narrow your own Beam !!! Reply with quote
Hi, what about the steering lock stop (RHD) do you just cut it off ?
HolyRoller
HolyRoller is offline
PostPosted: Mon Jul 17, 2017 6:55 pm    Post subject: Re: How to Narrow your own Beam !!! Reply with quote
I remain curious with respect to the question of whether anyone knows which bit is best suited to drilling the narrowed torsion leaves?
I have read here or elsewhere that you should use a 90 degree bit rather than a more modern style.
Anyone have a link to Ebay or Amazon bit that would be great for re-creating the correct dimple for the grub screws?
Thanks!
'62 Type 34 Ghia - Major project (sold!)
'71 Type 14 Ghia - Slightly less major project
'67 Type 14 Ghia - Drive-able project (sold!)
amaskedman
amaskedman is offline
PostPosted: Mon Oct 05, 2020 1:57 pm    Post subject: Re: How to Narrow your own Beam !!! Reply with quote
Wont this mess with the two notches for the steering assymbly?
Page 6 of 6
