How to Narrow your own Beam !!!
ashman40
ashman40 is offline
PostPosted: Sat Dec 18, 2010 10:58 pm    Post subject: Reply with quote
mark tucker wrote:
twmcbrid wrote:
at the beginning under one of the pics, it says that he puts the adjusters at the "correct" angle and it shows an magnetic protractor at 15 degrees. is this the "correct" angle?
15 from what? and is that lowered ,raised, or stock? how much movement of the ajuster lowers the car how much?.
The answer to your question varies because not all adjusters are the same.
When you disassemble your beam and prepare to cut, you need to mark where the original (stock) center grub screw was mounted (see white chalk lines below):
When you install your adjusters, you set your adjusters to where you want the stock height to be and line up the grub screw with the line you made. So where is your grub screw in the new adjuster? Look at these two pics and you can see that depending on the maker of your adjuster, the grub screw can be 45-deg off. Notice that the screw that is visible IS NOT necessarity the grub screw. This means the adjuster will be welded differently depending on which of these two adjusters you install.
So the example from earlier pics are specific to that make/model adjuster. You will need to measure and judge based on yours.
If you wanted to change the ride height from a max height of "stock" and anything lower... you would screw in the adjustment screw all the way (max ride height) and align the grub screw with stock. That give you maximum drop.
If you planned on installing 2.5" dropped spindles and wanted to be able to raise the height some so you could get an overall 2" drop, you would need to weld in your adjusters to allow some height adjustment heigher than stock. It all depends on your setup.
AshMan40
mark tucker
mark tucker is offline
PostPosted: Sun Dec 19, 2010 9:17 am    Post subject: Reply with quote
both of those ajusters look the same to me just 1 is fliped over. and if you install it up sidw down it wont work as the pressure wont be on the ajuster screw.
Derek Cobb
Annoying
Derek Cobb is offline
PostPosted: Sun Dec 19, 2010 3:05 pm    Post subject: Reply with quote
You obviously shouldn't be installing them then. They a certainly different. I made the 45 degree mistake installing adjusters in my first beam. Went from 3 inches narrow to 3 1/2 inches just like that. Laughing
mark tucker
PostPosted: Sun Dec 19, 2010 4:42 pm    Post subject: Reply with quote
what does narrow have to do with it??? aparently you my not need to be doing it. I have done it with out any peoblem. first time about 30+ years ago with out any problem. then again with out any problem. but I wasent shooting for any certin hight. I was just raisenig it for baja. and the one 30+ years ago was a giha. no problem with either. but now Im fixen to lower my baja down low with ajsuters and spindles.and narrow itabout 4-6.
ashman40
ashman40 is offline
PostPosted: Sun Dec 19, 2010 5:04 pm    Post subject: Reply with quote
Take a closer look at which screw will lockdown onto the dimple in the torsion bar. In the top pic it is obviously the hex screw that extends radially.
In the lower pic you might assume the same, but that radial screw does not reach all the way to the torsion bars. You can see a "hidden" threaded hole with no external screw. THIS is the grub screw for the lower adjuster. It is 135-deg out from the top one. The angle of install of these adjusters would be radically different.
The point is, there is no one angle that works for all installs.
Mark, I think Derek's comment implied that after building his 3" narrowed beam, he discovered he had overlooked the hidden grub screw (just as you did). He then needed to cut out and reinstall his adjusters. The end result was an even narrower 3.5" beam.
AshMan40
Derek Cobb
Annoying
PostPosted: Sun Dec 19, 2010 5:32 pm    Post subject: Reply with quote
Yeah, what he said. Just like that.
mark tucker
PostPosted: Sun Dec 19, 2010 5:49 pm    Post subject: Reply with quote
ok my eyes cant digitize the photo so I can turn it and see the screw that isant shown in the pic.but I would of seen it in my hand. I presume this is so you can position it so it isant hanging down under the car looking like crap. or for on a raised beam so it isant sofar up you cant get to it to ajust it.( I cant hardly get to mine in my bug ( top one ,somebody else did it before I got the car.
twiggyzappa
twiggyzappa is offline
PostPosted: Mon Jan 10, 2011 8:34 pm    Post subject: Reply with quote
I've got a general idea how how to do this myself. But my main question is what to do about the sway bar if the beam is narrowed more than two in.? Most retailers only sale them for a 2" narrowed beam.
thewreckingsoul
thewreckingsoul is offline
PostPosted: Mon Jan 10, 2011 8:42 pm    Post subject: Reply with quote
get the heavy duty one and narrow it. its much easier with a tig.
Ad
In action
In action again
ashman40
ashman40 is offline
PostPosted: Tue Jan 11, 2011 3:25 am    Post subject: Reply with quote
I thought sway bars are spring steel? If you cut and weld them in the middle won't you end up with a less flexible sway bar? Assuming cut/weld is what you were implying?
AshMan40
mark tucker
PostPosted: Tue Jan 11, 2011 8:46 am    Post subject: Reply with quote
you can sleave them if you like. but yes they will be less flexiable.but that is because you remover part of it. and is that what you want any way??stiffer,less roll.
thewreckingsoul
PostPosted: Tue Jan 11, 2011 11:27 am    Post subject: Reply with quote
it does make them stiffer but it is still functional
Ad
In action
In action again
ashman40
ashman40 is offline
PostPosted: Tue Jan 11, 2011 11:57 pm    Post subject: Reply with quote
Normally people install thicker diameter sway bars to improve handling. Thicker bars are less flexible.
Shorter bars of the same thickness are also less flexible. So the more you narrow the front, the thinner the sway bar should get to maintain the same handling.
Would it be better to shorten a stock diameter sway bar and get the increased "stiffness" from the cut and the shortening... is this enough to act like a thicker sway bar on a normal width front end? Not many thickness choices out there.
I added a 3/4" sway bar w/ urethane bushing to my stock width front end... noticeably stiffer/bumpier. I don think I'd want to use it cut down for a narrower beam... it'd be an even bumpier ride. Shocked
AshMan40
Duane
Duane is offline
PostPosted: Wed Jan 12, 2011 8:17 am    Post subject: Reply with quote
I'll be cutting and narrowing my stock bar next month and reinstalling, and for a 4" beam too. I'll post back and report my findings.
AutoLuxLexES
AutoLuxLexES is offline
PostPosted: Wed Jan 12, 2011 10:56 pm    Post subject: Reply with quote
does the beam ends where the torsion arms go also have grub screws?
sorry for the newb question. i already understand the concept of narrowing and installing adjusters. i dont think the torsion arms have grub screws because the torsion arms wouldnt be able to move, with that said, shortening of the torsion bars should also increase stiffness when narrowing the beam.
Charley
edit, ok just saw the pic above, no more grub screws, so shortening the torsion bars should increase stiffness.
Duane
Duane is offline
PostPosted: Wed Jan 12, 2011 11:27 pm    Post subject: Reply with quote
Charley
yes the torsion arms have grub screws also, thats what keeps them from sliding off the trosion springs and why you will need to redrill after shortening them. Wink
AutoLuxLexES
PostPosted: Thu Jan 13, 2011 12:42 am    Post subject: Reply with quote
ok, i didnt know that, but then again, i haven't done this yet and seen all the car thoroughly through.
but shortening of the torsion arms when narrowing still increases stiffness correct?
Charley
Joey
Joey is offline
PostPosted: Thu Jan 13, 2011 5:45 am    Post subject: Reply with quote
Charley
You shorten the torsion leaves not the arms.
Correct, narrowing increases stiffness.
Joey
60 Kombi - '74 Bus - '79 Panel - '56 Beetle - '65 Beetle
Square73
Square73 is offline
PostPosted: Thu Jan 13, 2011 8:23 am    Post subject: Reply with quote
Any opinions on what the maximum amount you can shorten a beam ? I'd like to make a buggy to run around on the narrow paths in my woods. I'll fab up a frame, so no concerns about body etc.
Thanks,
There's not a pill you can take. There's not a class you can go to. Stupid is fo-evah. Ron White
mark tucker
PostPosted: Thu Jan 13, 2011 8:47 am    Post subject: Reply with quote
just remember that a narrow 4 wheeler likes to fall over go boom.not very stable.get a bike !! offroad cars go wider for that reason.
Page 4 of 6
