djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32632 Location: Reading Pennsylvania
elizer Samba Member
Joined: May 02, 2016 Posts: 1466 Location: Northern Virginia
Posted: Sat Jan 13, 2018 5:16 pm Post subject: Re: Do Eurovan seats fit in Vanagons |
djkeev wrote: |
While I appreciate wanting to keep a VW a VW...... my brothers Eurovan seats are horrible!
Why would anyone want them? Yeah..... maybe better than Vanagon seats but a long way from great!
IMHO
Dave |
I finished grinding down the rails and I test fitted them. I sat in it and the back rest portion has this weird hollow give to it. Like when you lean back the lumbar and back portion has a negative space that just sinks in. I kept switching from my driver vanagon seat to the passenger EV seat and honestly my seats are in excellent condition and the cushion felt better.
I am already committed though. Im 800 in to the seats and sew fine covers. Still 1200 cheaper than recaro seats. I will have to ask the upholsterer to see what he can do with the backrest portion. Other than that the full recline was the big reason I got these seats. |
Zeitgeist 13 Samba Member
Posted: Sat Jan 13, 2018 5:31 pm Post subject: Re: Do Eurovan seats fit in Vanagons |
Have you tried dialing up the lumbar support knob? Mine is fully dialed and there's a solid hump in that area that doesn't give much at all. _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
Gruppe B Samba Member
Posted: Sat Jan 13, 2018 6:33 pm Post subject: Re: Do Eurovan seats fit in Vanagons |
djkeev wrote: |
IMHO
Dave |
Hi Dave,
What model of Eurovan does your brother have?
All of my Eurovan seats are incredibly comfortable.
-fully adjustable backrest with micro adjustment to full recline
-adjustable padded headrests
-adjustable fabric and padded armrests
You can keep the Chrysler k Kar seats (jk)
Posted: Sat Jan 13, 2018 6:41 pm Post subject: Re: Do Eurovan seats fit in Vanagons |
Having just driven a 2017 Grand Caravan rental for two weeks I can state that neither the front nor rear stow n' go seats are even remotely as comfortable as my Vanagon seats, and most definitely not the seats in my EV. _________________ Casey--
y u rune klassik? |
Posted: Sat Jan 13, 2018 7:16 pm Post subject: Re: Do Eurovan seats fit in Vanagons |
Double post? |
elizer Samba Member
Posted: Sat Jan 13, 2018 7:44 pm Post subject: Re: Do Eurovan seats fit in Vanagons |
Lumbar support knob? Maybe I should actually look at the seats tomorrow.
Used a cutting wheel and took off the lips on the rails. Left a bunch of thin shards of metal and a pretty sharp edge.
So I hit it with this sanding wheel and it cleaned it up perfectly and dulled down the edges.
I cleaned up the rails with some simple green and sprayed it with some spray paint.
Now it is time to shop around upholsterers to get the sewfine covers on. I went with vanagon grey inserts with vinyl bolsters. Added a map pocket to the passenger seat... but in retrospect I probably could have done without it and gone with a seatback organizer
I will update when I get them covered and put in.[/img] |
elizer Samba Member
Posted: Mon Jan 15, 2018 7:56 am Post subject: Re: Do Eurovan seats fit in Vanagons |
I scrolled through this thread and saw everyone's install. I noticed everyone still had the stock seat belt receiver. With the added height of the eurovan seats, I imagine clicking in would be more annoying than it already is. When I got my seats they came with the base as well and the seat belt receiver attached. I think I will be replacing the vanagon receiver with the eurovan receiver.
campism Samba Member
Joined: September 07, 2007 Posts: 4492 Location: Richmond VA
Posted: Mon Jan 15, 2018 9:42 am Post subject: Re: Do Eurovan seats fit in Vanagons |
elizer wrote: |
I scrolled through this thread and saw everyone's install. I noticed everyone still had the stock seat belt receiver. With the added height of the eurovan seats, I imagine clicking in would be more annoying than it already is. When I got my seats they came with the base as well and the seat belt receiver attached. I think I will be replacing the vanagon receiver with the eurovan receiver. |
If you have seat swivels that EV belt receiver will limit rotation. If you never spin the seats, no problem. _________________ '87 Westy in Wolfram Grey Metallic |
elizer Samba Member
Posted: Mon Jan 15, 2018 11:06 am Post subject: Re: Do Eurovan seats fit in Vanagons |
Even when tightened down wont I still be able to rotate it downwards? I will give it a test fit when I get the seats in. I wonder if I could enlarge the eyelet on the receiver so it's just a hair larger than the bolt so it has a little more play. |
elizer Samba Member
Posted: Thu Jan 18, 2018 9:34 am Post subject: Re: Do Eurovan seats fit in Vanagons |
Got the seats recovered at Seatco in Springfield, VA. The sewfine seat covers look great. Not sure how I feel about the smaller armrests but it should give a tiny bit more room down between the seats. The covers should tighten up they just had them steamed to put on.
If I were to do it all over again I would not have gotten the vinyl bolsters. Thinking about it going in and out they will probably get wrinkled and worn pretty quickly. I also would not have gotten the map pocket behind the passenger seat.
It is still a lot cheaper than the recaros that the guy from Germany and Poland make. https://goo.gl/zCR7ft It would have been a lot cheaper if I installed it myself but my frustration level with upholstery would have caused some torn seams. I primarily got these seats for the full recline capabilities that gruppe b displayed. If I get over them or want to move on after the first long road trip with them I will probably sell them and shell out the big bucks for those recaros.
[/url] |
Posted: Thu Jan 18, 2018 11:20 am Post subject: Re: Do Eurovan seats fit in Vanagons |
Those look really sharp! If you don't mind, how much did that upholstery combo cost from Sewfine*? We actually use those seatback pockets quite a bit, so I highly recommend them.
*I'm asking because I find their catalog to be difficult to navigate when trying to tease out actual costs of various combos. _________________ Casey--
y u rune klassik? |
elizer Samba Member
Posted: Thu Jan 18, 2018 7:46 pm Post subject: Re: Do Eurovan seats fit in Vanagons |
They up charge the vinyl combo.
I paid 630 including the shipping cost.
The base price for seats alone were 375... headrest 60 and armrest 80. Shipping was 45. So it should have been 560 base price without map pocket.
Posted: Thu Jan 18, 2018 8:19 pm Post subject: Re: Do Eurovan seats fit in Vanagons |
Thanks for the explanation. The fit looks really amazing. _________________ Casey--
y u rune klassik? |
elizer Samba Member
Posted: Thu Jan 18, 2018 9:12 pm Post subject: Re: Do Eurovan seats fit in Vanagons |
No prob. There were some production issues with the sewfine covers that the upholstery shop notified me of. They work in classics and show cars so they wanted to make sure I knew. The vans going to get used so it was not a problem and honestly not noticeable. I'm happy with them but I really hope every thing tightens up because there are some saggy parts. I'll post pictures of the production errors. I probably never would have noticed if they didn't tell me. |
vwwestyman Samba Member
Joined: April 24, 2004 Posts: 5688 Location: Manhattan, Kansas, USA
elizer Samba Member
Posted: Fri Jan 19, 2018 8:31 am Post subject: Re: Do Eurovan seats fit in Vanagons |
The holes are noticeable even if you don't pull back the material. And there is a little cut near the seam as well. Overall satisfied it's on the passenger side so I won't see it as much and get annoyed by it.
rmcd Samba Member
Joined: October 29, 2010 Posts: 1349 Location: PNW - its a dry rain.
Posted: Fri Mar 16, 2018 10:23 pm Post subject: Re: Do Eurovan seats fit in Vanagons |
I’d like to mount Vanagon armrests (or even eurovan armrests) on my eurovan seats.
Searched and read half a dozen eurovan seat swap threads here but apparently I’m the only person to own eurovan seats that didn’t have armrests as a standard option from the junk yard.
I have felt up my eurovan seats and can’t readily feel where the Vanagon armrests might mount. Anyone successful do this? Is there a mount under there I cannot feel? Thanks _________________ VW LT40 build. Like a Vanagon but 30% larger in every direction and 40% slower even in metric.
https://www.thesamba.com/vw/forum/viewtopic.php?t=749359&highlight= |
Posted: Fri Mar 16, 2018 11:00 pm Post subject: Re: Do Eurovan seats fit in Vanagons |
I believe the mounts are welded on to the seat backs, so you'll probably need to dismantle the seats and get to work. _________________ Casey--
y u rune klassik? |
rmcd Samba Member
Posted: Sat Mar 17, 2018 8:53 am Post subject: Re: Do Eurovan seats fit in Vanagons |
Zeitgeist 13 wrote: |
I believe the mounts are welded on to the seat backs, so you'll probably need to dismantle the seats and get to work. |
Auuuuugh. I was hoping I’d missed something. Certainly doable but I don’t want to pull the covers yet. Thanks for confirming. _________________ VW LT40 build. Like a Vanagon but 30% larger in every direction and 40% slower even in metric.
