Gmiee5 Samba Member
Joined: December 06, 2008 Posts: 388 Location: Portland Oregon
Posted: Thu Aug 13, 2009 9:45 pm Post subject: |
While I wait for Gersons replacement pieces .
I decided to start on the long panel
Before:
after the panel was removed
I will need to replace the pillers and outer support
Starting to clean up the area and remove the pillers
mickey86004 Samba Member
Joined: March 27, 2005 Posts: 334 Location: Chula, MO
Posted: Thu Aug 13, 2009 9:49 pm Post subject: |
looking good. Keep the pictures coming. I can't wait to get to that point on the 15 _________________
EverettB wrote: |
No bullet turn signal 15 window qualifies as a parts Bus! |
1959 15 Window
1958 Panel |
Gmiee5 Samba Member
Posted: Fri Aug 14, 2009 11:28 am Post subject: |
mickey86004 wrote: |
looking good. Keep the pictures coming. I can't wait to get to that point on the 15 |
Thanks for the encouragement
Gmiee5 Samba Member
Posted: Wed Aug 19, 2009 11:19 pm Post subject: |
just started Fitting the outer support
If you can tell I chose to run the out side skin up to the middle of the cross brace.
I also trimmed up the lower Dogleg
and started to fit panels
Next final fitting and welding |
Gmiee5 Samba Member
Posted: Sat Aug 29, 2009 8:09 pm Post subject: |
Last week we were able to weld in the pillars.
And start to button it up the long panel. I was very glad that I chose to go up to the inside support verses just 7 inches up. By doing this I was able to remove the body damage
Gmiee5 Samba Member
Posted: Wed Sep 02, 2009 10:08 pm Post subject: |
a little more progress
Gmiee5 Samba Member
Posted: Sun Sep 13, 2009 9:29 pm Post subject: |
Drivers side is done. Finaly starting back on the passenger side.
Gmiee5 Samba Member
Posted: Mon Sep 14, 2009 11:16 am Post subject: |
I have the B pillar the rocker panel below the doors and the cargo floors to install.
Question:
Should I install the floors next and then install pillar and rocker using floor as guide?
OR
Install pillar using rocker as guide and fit floor after? |
hugheseum Samba Member
Joined: February 11, 2004 Posts: 2690 Location: oregon
Posted: Mon Sep 14, 2009 11:25 am Post subject: |
pillars first,actually pillars before rockers _________________ Have a great day! |
Nor_AL_67 Samba Member
Joined: December 18, 2007 Posts: 663 Location: Huntsville,Alabama
Posted: Mon Sep 14, 2009 11:27 am Post subject: |
Gmiee5 wrote: |
Question:
OR
I did the floor last. Install the pillar/rockers, tack to hold, then make sure you check cargo doord fitment.
edit: door _________________ 63 Sedan
61 Rag
67 Type 1 Sedan
63 Type 2 Standard Walk-thru
69 Ghia
68 912
Amateur Versus Rusty Bus! |
Gmiee5 Samba Member
Posted: Mon Sep 14, 2009 11:35 am Post subject: |
Nor_AL_67 wrote: |
Gmiee5 wrote: |
Question:
OR
edit: door |
Did you have problems getting the rocker to fit properly?
It looks like I am going to have to bend the top of the rocker a considerable amount to fit correctly |
Posted: Mon Sep 14, 2009 11:58 am Post subject: |
Gmiee5 wrote: |
Yes, it took me (an amateur) hours to get the best fit. The rocker has to line up with the b and c pillars, inner rocker, short side rocker, floor height, cargo doors and dogleg all at the same time. I didn't have to bend anything, just keep playing with the alignment. _________________ 63 Sedan
61 Rag
67 Type 1 Sedan
69 Ghia
68 912
Gmiee5 Samba Member
Posted: Mon Sep 14, 2009 2:18 pm Post subject: |
hugheseum wrote: |
pillars first,actually pillars before rockers |
Piller rocker and then Floor ? |
Posted: Mon Sep 14, 2009 4:45 pm Post subject: |
yes _________________ Have a great day! |
Gmiee5 Samba Member
Posted: Tue Sep 15, 2009 8:32 pm Post subject: |
This is a beautiful sight the first fitting of the cargo floors
Gmiee5 Samba Member
Posted: Sat Sep 19, 2009 10:21 pm Post subject: |
After drilling over a hundred and fifty holes for plug welding.
It is almost ready to weld in to place
dippedbus Samba Member
Posted: Sun Sep 20, 2009 12:44 am Post subject: |
Fittted a gerson floor myself ,tight fit getting it past spare wheel bulge.
Hardest bit for me was trimming around the heater tubes.
U will find that u need to make up flat floor plates for over the keyholes for the seat fixings( if ur using a middle seat) varies depending on seat legs and a decent catch plate.
Satisfying job to do grinding down all them welds neat is fun,greatwork there buddy _________________ Table top restorer! |
arod Samba Member
Joined: March 07, 2004 Posts: 7322 Location: Pembroke Pines, FL
Posted: Sun Sep 20, 2009 6:16 pm Post subject: |
wow. just awesome work there. and you thought you just needed cargo floors! i myself have KF metal on my bus. |
Gmiee5 Samba Member
Posted: Sun Sep 20, 2009 7:47 pm Post subject: |
dippedbus wrote: |
Satisfying job to do grinding down all them welds neat is fun,greatwork there buddy |
I removed my heater pipe to install the floor.
Also I bought the flat floor plates from Gerson.
kombisutra Samba Member
Joined: October 02, 2003 Posts: 4127 Location: San Anselmo, 10 miles North Of San Francisco
Posted: Sun Sep 20, 2009 9:38 pm Post subject: |
Extremely excellent! |
