slyder Samba Member
Joined: October 24, 2006 Posts: 23 Location: Ontario, Canada
Posted: Fri Oct 26, 2007 5:34 pm Post subject: Gas Peddle sticking on acceleration |
My gas pedal sticks on acceleration, I just changed the throttle spring, it is like the pedal just doesn't return to the normal position. When it happens it has been at the most inappropriate times. I thought of looking at the throttle linkage under the front floor and seeing what is sticking. Has anyone had this happen? Any suggestions?? _________________ '97 Jetta Trek
Looking for Pre-70 Convertible
www.campinginstyle.com
Camping in Style Rv |
TSR53 Samba Member
Posted: Fri Oct 26, 2007 5:38 pm Post subject: |
The same thing happened to my auto when I first bought it. Although, it didn't stick on, just wasn't very smooth accelerating or returning. I fixed by pulling back the carpet near the pedal and spraying Wurth HHS2000 grease in the bellcrank assembly. I'm sure WD40 or similar will work too.
tikibus Samba Member
Joined: July 07, 2006 Posts: 834 Location: Rochester, NY
Posted: Fri Oct 26, 2007 6:57 pm Post subject: |
Great Question!
Wow! Linkage that hasen't been beaten to Death is Samba Land!
Let us start from the front working back.
The assembly that your foot pushes down to make Vanagon go is really easy to understand. There is a pivot point that makes the cable move forward, it is under the plastic cover ( clam shell and tire have to be open to inspect and remove).
Beware: old screws are not your friends and with the design of the cover rust ( for those in Eastern States) the screws can take out more metal than once thought. Nasty and a PITA.
Cable runs above gas tank and weaves to the Right( Your under the Vanagon) with supports at the 2nd sub structure ( cross L beam) next to the split of the Emergency Brake Cables.
Inspect all with good eyes and if all looks good, remember the entire cable should be sheathed in a hard plastic tubing, if not troubles will abound. then attack engine bay.
My .02's after inspecting and routing about is to see if the throttle body is clean.
Think springs. _________________ Happy Trails!
Mark
______________
Founding member of the Empire State VW Camping Club.
http://www.empirevwcamping.org/
1984 Westy - Tiki
1997 Honda Civic -The Green Hornet
1971 Volvo P-1800E- needs TLC |
RicoS Samba Member
Posted: Fri Oct 26, 2007 9:32 pm Post subject: Re: Gas Peddle sticking on acceleration |
slyder wrote: |
My gas pedal sticks on acceleration, I just changed the throttle spring, it is like the pedal just doesn't return to the normal position. When it happens it has been at the most inappropriate times. I thought of looking at the throttle linkage under the front floor and seeing what is sticking. Has anyone had this happen? Any suggestions?? |
While you're under there looking around, install a new throttle cable.
Rich |
Terry Kay Banned
Posted: Fri Oct 26, 2007 10:49 pm Post subject: |
Rico Sabladam is right on the money with his diagnosis.
The cables usually suffer from petrolis neglectis, and a replacement of the cable, with some dry slide applied will cure the problem. _________________ T.K.
slyder Samba Member
Posted: Sat Oct 27, 2007 5:55 pm Post subject: |
I will try and lube everything. I have a cable luber from my motorcycle and will try using it to force lube down the length of the cable. I replaced the throttle spring already but will lube the throttle up as well. _________________ '97 Jetta Trek
embraertech Samba Member
Posted: Sat Oct 27, 2007 7:22 pm Post subject: |
I had a similar problem and found it to be the injector pump (diesel)
As soon as I disconnected it from injector pump the cable slide freely which, in my opinion, ruled out a cable issue. Diesel or gas, it is quick way to find out. _________________ Current
86 Bronze Wolfsberg Weekender
Gone but not forgotten
82 Yellow Diesel Westy
91 Blue GTi 2L
86 Black GTi
74 Blue Super Beetle
'When the going gets weird, the weird turn pro' HST |
slyder Samba Member
Posted: Sun Oct 28, 2007 2:08 pm Post subject: |
I took a look today front and back, everything up front was good. at the throttle was good. Figured out it was the linkage on the transmission from the throttle body that was binding. Lubed it up and all is good as new now. So a quick tip if your peddle is sticking check the linkage at the transmission from the cable up front to the throttle body. _________________ '97 Jetta Trek
mikls63rag Samba Member
Joined: May 13, 2006 Posts: 555 Location: Antioch, CA
Posted: Tue Jan 20, 2009 8:07 pm Post subject: |
Has any one have any photos of that area under the the floor board. Thats where mine is sticking and clicking. its really kinda scary when you are driving in traffic! _________________ Michael
63' Rag
65' Bug
13' Passat S |
insyncro Banned
Posted: Wed Jan 21, 2009 7:31 am Post subject: |
I have had very good success when I pull the entire cable, rig up a very long pipe cleaner and get everything out of the white plastic tube that the cable runs in.
If the cable looks beat up at all I replace it, if good to go I wipe it down and reinstall.
The biggest mistake you can make is to leave any WD or similar in the white tube.
Here in the East it will freeze and lock the throttle open when below zero.
It will also attract any dirt in the area.
Syncro throttle cables are routed above the transmission and sometimes get wedged between the trans and gas tank.
If you have pulled an engine/trans recently, make sure that it is in its appropriate spot with some wiggle room. |
Terry Kay Banned
Posted: Wed Jan 21, 2009 7:42 am Post subject: |
The inner throttle cable will get gummed up inside the outer cover with grease or oil.
This is exactly what the Dri Slide is for.
It's a dry graphite cable lube, slippery as all get out---- and been around for eon's just for this very application-- --keeping inner cables sliding free in their outer cover's, without being a dirt jamming magnet. _________________ T.K. |
Sheesh Samba Member
Joined: October 18, 2007 Posts: 394 Location: New Pine Creek, Orygun
Posted: Wed Jan 21, 2009 7:32 pm Post subject: |
Pull the accelerator cable, clean, inspect, grease, reinstall. A 30 minute job - tops.
Should be done every couple of years as part of anyone's maintenance routine. _________________ 1982 Westy, 2.0L AC CA emissions |
fastwagens Samba Member
Joined: March 01, 2004 Posts: 1028 Location: Michigan (The other west coast)
Posted: Thu Jan 22, 2009 9:53 am Post subject: Re: Gas Peddle sticking on acceleration |
RicoS wrote: |
slyder wrote: |
Rich |
X2 |
