IdahoDoug Samba Member
Joined: June 12, 2010 Posts: 10252 Location: N. Idaho
Posted: Sun Jan 29, 2023 6:11 pm Post subject: Re: Low oil pressure at idle. Only 12,000 miles on new rebuild. |
Nice input on the spring and shim. Agree, at hot idle is the lowest oil pressure an engine sees. And it would be just flat wrong to claim the old spring is not holding the bypass valve shut, so a new spring does hold it shut. Why? It would mean that at a pressure of perhaps 5psi, the spring is so weak it is opening. Which if you apply your noodle(s) you will realize that means at 25 while running down the road, the valve is WIDE open and actual pressure going to the bearings and such would be - what - 15? 18?
So this simply does not pass the sniff test. As xflyer notes, these bypass springs are in virtually every automobile engine on the planet. Since the failure or even weakness of these springs would lower oil pressure, it's safe to say the manufacturers pay more than just casual attention to their quality and lifetime of function or they'd be rebuilding engines left and right. This is a super simple and durable system every single car has - it is not unique to the WBX.
So, don't shim these springs. You are literally INCREASING the chance of damage to your engine by raising the cold max pressure with thick oil. And that is quite literally all you are accomplishing. Zero impact at operating temperature. I want my Samba buds to understand this, so if there are further questions I'm happy to continue. I've had a little experience with production engines as the former WorldWide Engine Planner for GM. _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX, 1982 Toyota Sunrader |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9810 Location: Mt Lemmon, AZ
Posted: Sun Jan 29, 2023 8:35 pm Post subject: Re: Low oil pressure at idle. Only 12,000 miles on new rebuild. |
Yeah, what ^they^ said.
And I believe the case against Fram was further exacerbated by a website where a disgruntled former Allied Signal engineer had an ax to grind. |
michaelasnider Samba Member
Joined: September 27, 2013 Posts: 369 Location: East Kootenays, Canada
Posted: Mon Jan 30, 2023 7:42 am Post subject: Re: Low oil pressure at idle. Only 12,000 miles on new rebuild. |
IdahoDoug wrote: |
As to lengths of springs, old coming out vs new, I have seen replacement springs that produced the exact same pressure but shorter or with more coils, or with thinner wire in a variety of applications over my lifetime, so perhaps the newer factory springs are from a different supplier than the original ones - what - 40 years ago? That would account for side by side differences new vs old.
There is a spec in the Bentley for length. When I pulled out my old spring, it did not meet that spec but the new one did. The spring is constantly under some load as the plug compresses it when installing. |
DanHoug Samba Member
Joined: December 05, 2016 Posts: 4800 Location: Bemidji, MN
Posted: Mon Jan 30, 2023 4:59 pm Post subject: Re: Low oil pressure at idle. Only 12,000 miles on new rebuild. |
here's some photos that should illuminate the situation....
this is the bore of the oil relief plug + spring assembly. if you look closely, you'll see that there is a dual relief channel that runs alongside the piston chamber. these channels begins about 1/8" off of the piston seat and go all the way past the oil relief port, which is about 1/2 way in the bore. so it takes is about 1/8" piston movement before the bypass channels are reached. if the piston was a tight fit in the bore, little oil would flow into the bypass channels if the piston moved against spring pressure less than 1/8". but it is NOT a tight fit, and the sealing appears to be done largely on the seat the piston rests. as soon as the piston lifts off the seat, there is SOME bypass oil flow. time for pictures....
bore showing dual bypass channels located 1/8" above piston seat
this is the stack of parts, note the piston rests on TOP of the spring but goes OVER the guide on the plug
this is how far the spring extends above the plug threads with piston installed. even if the spring is short, there is compression on the spring because they are never THAT short.
now... "I'd like to buy an argument" <Monty Python>
Hooke's Law says that a spring's force is proportional to the extension. this means that as the screw-in plug compresses the spring, additional length provided by adding a washer will result in a proportional increase in pressure of the piston against the seat. i THINK we're all good up to this point.
the question is whether the oil pressure raises the piston off the seat at low oil pressure, because lifting it off the seat just a tiny bit WILL bypass some oil because the piston is loose in the bore. empirical testing by some people on this list has shown that increasing the spring pressure a washer thickness did indeed result in a small increase in hot idle oil pressure. this suggests that the oil pressure relief system has some effect before the piston moves the 1/8" to uncover the bypass channel.
"Time's up. Good day." _________________ -dan
www.thefixitworkshop.com |
3xvanagon Samba Member
Posted: Tue Jan 31, 2023 5:38 pm Post subject: Re: Low oil pressure at idle. Only 12,000 miles on new rebuild. |
Super interesting, so I took the crush washer out today of the plug which effectively raised the seat of the plug and spring by the same height as a washer would and noticed zero change in oil pressure hot or cold. I can't see how a washer on the plug seat (where the spring sits) would have any different effect? |
Posted: Tue Jan 31, 2023 5:44 pm Post subject: Re: Low oil pressure at idle. Only 12,000 miles on new rebuild. |
3xvanagon wrote: |
if everything is skookum, you probably won't see a change. it is surmised that a shortened spring may be providing less force on the piston, perhaps allowing some leakage beyond the piston seat at idle. what is your hot idle pressure? _________________ -dan
Posted: Wed Feb 01, 2023 4:51 pm Post subject: Re: Low oil pressure at idle. Only 12,000 miles on new rebuild. |
Depends on how you define as hot idle. I find a huge discrepancy between hot city driving (30+ minutes) , and a long haul on the highway (30+ minutes)
City
Idle-9 psi
Fourth gear 3000+ rpm 25 psi
Highway
Idle-7 psi
Fourth gear 3000+ rpm 22 psi
Oddly, In both instances it seems very gear dependent, for instance in 3rd gear at 3000+ rpm I see ~5psi higher.
When people speak of "acceptable" psi values, I'm also curious how they are measuring (long highway hauls, city driving, in what year, etc)... At least for me, this provides varying results.
Compression on the engine is fantastic 155-160 across all 4, so I suspect maybe I had a top end rebuild from PO. I did replace the oil pump with a high volume one from gowesty for good measure, which seemed to keep oil pressure higher between 2-3k psi and a maybe 1 psi higher in "hot" scenarios. |
Posted: Wed Feb 01, 2023 5:10 pm Post subject: Re: Low oil pressure at idle. Only 12,000 miles on new rebuild. |
you've got some real data, many don't report to that level! your 3rd gear oil temps are less because the engine is under less working load... your van is going slower for the same rpm so the engine is doing less work.
your oil pressures are getting to the low end... below the 10psi/1000 rpm wear limit (set forth by VW or else 'common wisdom'). i'm rebuilding a motor for a van that runs great but has about 22 psi hot at 3500 rpm and none showing on the gauge at idle but the oil light doesn't flash so it is above the low switch threshold of 2-5psi.
3xvanagon wrote: |
City
Idle-9 psi
Highway
Idle-7 psi
xflyer Samba Member
Posted: Thu Feb 02, 2023 9:25 am Post subject: Re: Low oil pressure at idle. Only 12,000 miles on new rebuild. |
Comparing those oil pressure readings with oil temp will probably explain the differences between the "city" and "highway'' driving.
On a side note to that, I found that running the oil level about 4-5 mm above the "low" mark on the stick lowers the oil temp by about 30 deg F. A lower oil temp will likely increase the sought after oil pressure.
Was the cause of the low pressure on the engine being rebuilt found?
Also my 85 (2.1 conversion) did this once, oil light on at operating temp idle. Turned out the problem was a cam bearing that was falling apart. Used to see that long ago on the 40hp 1200 motors (first ones with separate cam bearings) with a lot of miles and questionable servicing. Replaced bearings and its been fine since then (15 yrs ago). _________________ 1989 Campmobile, 1984 7 passenger beater Vanagon
Both with cool A/C |
Posted: Thu Feb 02, 2023 9:51 am Post subject: Re: Low oil pressure at idle. Only 12,000 miles on new rebuild. |
xflyer wrote: |
Was the cause of the low pressure on the engine being rebuilt found? |
the good running low oil pressure motor is still in the van. i'm rebuilding a spare motor which was the original motor out of my ratty 87. it had 225k miles on it and i'd get the oil light + buzzer sometimes while driving hard or a flashing oil light at idle. tear down revealed a crank in great shape but worn rod bearings, well, wear on all the bearings but rods looked the worse. _________________ -dan
ThinkingD Samba Member
Joined: January 21, 2020 Posts: 130 Location: Ottawa Ontario Canada
Posted: Thu Feb 02, 2023 10:16 am Post subject: Re: Low oil pressure at idle. Only 12,000 miles on new rebuild. |
Just weld a nut onto the oil pressure relief valve cover. No more removal problems, or need for a BMFSD. _________________ 87 Titian Red Westfalia 2.0 VW I4 SOHC manual Ottawa, Ontario |
xflyer Samba Member
Posted: Thu Feb 02, 2023 10:17 am Post subject: Re: Low oil pressure at idle. Only 12,000 miles on new rebuild. |
Hopefully you are replacing the infamous 2.1 rod bolts. _________________ 1989 Campmobile, 1984 7 passenger beater Vanagon
xflyer Samba Member
Posted: Thu Feb 02, 2023 10:19 am Post subject: Re: Low oil pressure at idle. Only 12,000 miles on new rebuild. |
"weld a nut onto the oil pressure relief valve cover."
Good idea. What I learned was to tap the plug with a steel hammer. This loosens it without strange tools, cursing, and bloodletting. _________________ 1989 Campmobile, 1984 7 passenger beater Vanagon
