Points
Adriel Rowley
Adriel Rowley is offline
PostPosted: Fri Jan 23, 2009 10:26 pm    Post subject: Points Reply with quote
Phil suggested a new thread so...
Does mis-adjusted points cause sluggishness? Ever since I left the ignition on, been a bit sluggish, and have not touched them since I bought the Squareback. Thinking it is time to check, but thought to ask for everyone. Wink
Please consider I am Autistic, so I process information differently and still working on social skills. Thanks.
Dad's 1964 Beetle purchased September 1968.
https://www.thesamba.com/vw/forum/viewtopic.php?p=9252810#9252810
1971 Sunroof Squareback with Fuel Injection
http://www.thesamba.com/vw/forum/viewtopic.php?t=219811&highlight=squareback+rejuvenation
atrujillo1991
atrujillo1991 is offline
PostPosted: Fri Jan 23, 2009 10:43 pm    Post subject: Reply with quote
This is a battle I can honestly say I experienced today.
Yes.
Lol my engine's a lot smoother after dialing the points in precisely.
'72 OG Square
'87 Montana Green GTI- EX 3.0L
'92 GTI- 16vABAt 450+WHP
'96 Celebration Jetta- 16vABA
KTPhil Premium Member
KTPhil is offline
PostPosted: Sat Jan 24, 2009 12:02 am    Post subject: Reply with quote
With the ignition left on, and the points not quite closed, I suppose you could get arcing and the pitting might increase resistance and affect the dwell and timing. Have a look!
raygreenwood
raygreenwood is online now
PostPosted: Sat Jan 24, 2009 2:33 pm    Post subject: Reply with quote
Get rid of the points. They are a major detriment to the whole system..especially with D-jet. Just get a pertronix. Ray
blankmange
Type 3 Darksider
blankmange is offline
PostPosted: Sat Jan 24, 2009 2:44 pm    Post subject: Reply with quote
there has been considerable debate as to which Pertronix unit actually fits the FI distributor... any suggestions?
póg mo thóin
Certified DHS Technician
Samba Member # 24517
Russ Wolfe
Russ Wolfe is offline
PostPosted: Sat Jan 24, 2009 3:56 pm    Post subject: Reply with quote
I have had a set of points last from 1985, until last year when I retired the car from service due to rust issues.
They only got replaced, when I sold the distributor out of the engine. I serviced the distributor, and replaced the points and condensor before I shipped the distributor.
Gary: OK. Ima poop.
Adriel Rowley
PostPosted: Sat Jan 24, 2009 7:36 pm    Post subject: Reply with quote
I like the idea of Pertronix, but do not have the bread. There are far more issues further up the list. Points will not let you down, and I do not mind the quality time! Wink Laughing Plus, I have about half dozen, and several in the Squareback.
Rewarded myself, and went to check the points. I had about a millimeter of gap! Um, I wonder if that could be an issue! Think Pulled them, and had a black spot on the metal side, but relatively minor. Cleaned them up, reinstalled, gaped, and greased. Added a bit of WD-40 to the felt, and called it good. Well see if it runs in the morning!
JSMskater
Samba Grease Gorilla
JSMskater is offline
PostPosted: Sat Jan 24, 2009 8:43 pm    Post subject: Reply with quote
I ran a pertronix until my enigne took a dump. , the vacuum advance unit. It works great, and I would say the only noticeable advantage is off the line throttle response. MPG improvement was like, 2. points work fine, but i hated the stupid little hesitations and things that were right off the line. Pertronix fixed that. Not having to diddle with the distributor at valve adjustment time was nice too, but not a selling point in and of itself.
Personally, i feel like points work just fine, and pertronix would be overkill on an old FI motor. if you're building from scratch though, why dick around? its not like they're expensive.
71 Squareback-FI -- 73 Bay (subaru powered)
TOOB Member #3
I make D-jet FI connectors
Adriel Rowley
PostPosted: Sat Jan 24, 2009 9:00 pm    Post subject: Reply with quote
Well 2 miles per a gallon, so 36 miles per a gallon, so 374 miles, versus 281! Shocked 93 extra miles! So, about $6.75 saving! Did I do that right? Still, takes 13 fill-ups to break even, or 4875 miles, or two or three years. So, guess it is not a huge improvement, especially with such loose figures. It is more of a tuning and engine quality application.
The engine is not old! It has about four thousand miles on it, and runs well. No oil burning, good mileage, and good performance. That is why I am looking at a filter, to make it last even longer.
JSMskater
PostPosted: Sat Jan 24, 2009 9:10 pm    Post subject: Reply with quote
13 fill ups!? my pertronix cost me 40 dollars brand new. at 7 dollars savings per tank, that's only 6 or 7 fill ups. and thats at 32mpg.. iv never gotten 36. 40 dollars is peanuts for better throttle response.
TOOB Member #3
Adriel Rowley
PostPosted: Sat Jan 24, 2009 9:33 pm    Post subject: Reply with quote
What? Where? I have seen them at $80-$100! Shocked Might be something to look into. Rust, filter, then Pertronix. Wink
JSMskater
PostPosted: Sun Jan 25, 2009 12:37 am    Post subject: Reply with quote
I bought mine online at CPR. even so, 80-100 bucks is still not that bad for electronic points. you don't have to use the pertronix units either, there are compufire and other companies that make the same kits considerably cheaper.
TOOB Member #3
blankmange
Type 3 Darksider
PostPosted: Sun Jan 25, 2009 7:37 am    Post subject: Reply with quote
so, my original question stands: which model of Pertronix for the FI distributor?
póg mo thóin
atrujillo1991
PostPosted: Sun Jan 25, 2009 10:27 am    Post subject: Reply with quote
x2! I'd like to know as well.
'72 OG Square
JSMskater
PostPosted: Sun Jan 25, 2009 2:06 pm    Post subject: Reply with quote
the vacuum advance one. they only make two kits that work with our VW distributors.
TOOB Member #3
blankmange
Type 3 Darksider
PostPosted: Sun Jan 25, 2009 2:11 pm    Post subject: Reply with quote
I was hoping for a part number...
póg mo thóin
JSMskater
PostPosted: Sun Jan 25, 2009 2:48 pm    Post subject: Reply with quote
part number 1847V. it's listed for 1968-1973 VW T3. it is the vacuum advance unit. I called and specifically asked them, before I bought it, whether it would function in the FI distributor. they assured me it would, and I used it without issues for months.
likewise, the kits offered by other companies (hot spark, compufire, etc) are pretty much identical kits, and they also only come in two varieties- 009/ mech advance, and vacuum advance kits. don't be surprised if you have to file a little here and a little there, I had to take .002 off the corner of my pertronix base in order for it to seat properly.
TOOB Member #3
Erik G
Erik G is offline
PostPosted: Sun Jan 25, 2009 3:12 pm    Post subject: Reply with quote
at best, the pertronix will perform as good as perfectly adjusted points, no better. they will however, outperform mis adjusted or worn points. I have used them on a couple of cars, and I liked them.
JSMskater
PostPosted: Sun Jan 25, 2009 3:21 pm    Post subject: Reply with quote
agreed- it will never be "better" than points- the effect is just that of having a fresh set of points installed, and perfectly gapped, every time you started your car.
TOOB Member #3
raygreenwood
PostPosted: Sun Jan 25, 2009 4:39 pm    Post subject: Reply with quote
Pertronix iss better than points...because points very quickly carbonize...unless they are perfect. That carbonization...closes gap and changes dwell. Carbon is a conductor.
That being said, I have used both Pertronix and compufire. I thought the shielding and harness/grommet assembly on the compufire is sub par compared to Pertronix. Also, the whole module frame and locating lug on the Pertronix was better.
Yes, the vacuum advance model listed for 411/412 and Porsche 914 is correct.
That being said, it is not perfect without mods.
(1) The fit of the magnet disc sometimes slips down too far and is too close to the module.
The magnet disc fit is also sloppy and loose on all module brands. I dropped a thinwall washer made of a slice of metric tube onto theshaft, then put JB weld around the hole in teh disc....slipped it on and let it dry overnight. Don't forget to lube the shaft so it comes off. In the morning I removed it and filed it clean. It fits nice and tight now. I found this can represent about 5 degress of timing change on some distributors. Its the difference in machine work on shaft and cams...not the disc.
(2) The back end of the module needed to be clearanced. It commonly comes up against the wall of the distributor during advance...wedging it so you get incomplete advance.
(3) On some breaker plates....the brass locator pin on the module is just a few thousandths too long. When you tighten the unit down...it pins the two plates together...locking out vacuum advance.
(4) carefully route the wire inside of the dizzy befire you lock down the grommet with the fork and screw on the outside...or it will wear against the edge of the breaker plate everytime you advance...and short out eventually.
Attention to detail I have found.....is what makes most people unhappy with their points replacement module....not the module itself.
If you do not get VERY NOTICABLE smoothness as compared to points on a distributor with high miles on it....then you slop elsewhere in your system (breaker plate slop, spring slop, distributor drive slop, weights sloppy, worn advance arm etc.). This will not fix all of that.
What it does fix...are the minute differences worn distributor lobes give you when added to points that are starting to carbonize.
I always carry points, and condensor as a spare....but I would never purposely go back to points. Ray
