55veedub Samba Member
Joined: May 12, 2008 Posts: 583 Location: North Bay, Ontario, Canada
Posted: Sun Jan 25, 2009 9:26 am Post subject: Keeping it Patina |
Just shopping around for busses and have come across many that need minor repairs, corners, rockers, etc.. the busses are in original paint and look very good. Whats the best way to perform the required repairs but keeping the finish looking original when the areas are repaired? Especially if the original finish is scuffed up and what not.
Photos would be great.
Mike |
GostaBerling Samba Member
Joined: March 11, 2007 Posts: 401 Location: Madison, WI
Posted: Sun Jan 25, 2009 1:13 pm Post subject: |
If it's just simple scuffing and not through the paint or if the paint is just oxidized you can use a buffer and some polishing compound. This brings back the original paint very nicely. If there is some rust stains you can use CLR to clear them up and either repaint the air or just buff out what you can. _________________ "I became an archaeologist because I wanted to drive around in a big Land Rover, smoking, cursing, and finding treasure." - Carmel Schrire
current 1979 fiat spider, 72 Contempo Hightop |
germansupplyscott Samba Member
Posted: Sun Jan 25, 2009 8:31 pm Post subject: |
we have a bus at our shop that is being done in a similar way, however i have to say that the welding repairs on the dry cleaning bus are pretty hacked. the bus in our shop is being done by my assistant and his fabrication and welding are a lot cleaner.
i'll try to post some photos in the next few days. _________________ SL |
Kirk Samba Member
Joined: December 05, 2003 Posts: 5487 Location: North Texas
Posted: Sun Jan 25, 2009 8:56 pm Post subject: |
I think they also used some closely matched rattle can paint. |
borninabus Samba R&D Dept.
Joined: May 18, 2006 Posts: 4539 Location: Arizona Highways
Posted: Sun Jan 25, 2009 11:06 pm Post subject: Re: Keeping it Patina |
55veedub wrote: |
Whats the best way to perform the required repairs but keeping the finish looking original when the areas are repaired? |
X2, Kirk
custom matched spray paint. sorry, no pics. did both my rear vents after a quick sanding. _________________ 88 Van WBX, A/T - 13 JSW TDI 6M/T - 2012 Touareg TDI Sport |
Posted: Mon Jan 26, 2009 11:26 am Post subject: |
So with a little scuffing after the new panel has been welded in, primed and painted, its possible to keep it original. My biggest concern was keeping it as original as possibe. i would think that the closer the respray paint is to the original the better the effect.
The bus i am looking at is not nearly as rough as the laundry bus, its all one color but is just dull/faded. Im sure with a bit of a buff it will be glossy again. I would very much like to keep the original paint on it though after any repais that it will need
gmag69 Type2 Nutcase
Joined: January 13, 2006 Posts: 1941 Location: northwest PA
Posted: Mon Jan 26, 2009 1:24 pm Post subject: |
A good buff and a coat of wax will do that bus wonders. PM VDubTech about this sort of thing. He does it all the time with buses he drags home. _________________ Check out my Westy resto. thread.
http://www.thesamba.com/vw/forum/viewtopic.php?t=230285 |
SGKent Samba Member
Posted: Mon Jan 26, 2009 1:47 pm Post subject: |
If the OG paint is still on the bus, and the bus has been kept out of the weather, you could just buff it and apply a non-silcone wax like carnuba every 3 to 4 months. However finding a OG paint in that condition is rare. Most of the buses I've seen like that are already re-painted and what you are seeing is the re-paint patina. Or, there are spots of rust in between the patina. Afterall, these are 35+/- year old cars. If you decide to repaint it keep good before and after photos so someone will know it is not a Katrina bus hiding under the paint. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
