SQB body swap
RATTRP
RATTRP is offline
PostPosted: Thu Jan 29, 2009 11:15 am    Post subject: SQB body swap Reply with quote
I have a 69' SQB the body is rough (RUST) so I purchased a 68' body, no pan/chassis. Anybody know what kind of work is entailed for this swap? Any suggestions/comments are more than welcome! THANKS!!!
You laugh cause I'm different...
I laugh cause I just farted!!!
69/67 SQB's... That's all I got.
Russ Wolfe
Russ Wolfe is offline
PostPosted: Thu Jan 29, 2009 11:29 am    Post subject: Reply with quote
It should be a pretty much straight bolt on. A lot of work, but all the mountings are the same.
One thing, you will have to add the rear engine hanger mounts from the 69, to the 68 body.
Gary: OK. Ima poop.
Notched
Notched is offline
PostPosted: Thu Jan 29, 2009 11:33 am    Post subject: Reply with quote
How bad can the rust be in Texas??? Shocked
Post pics of rust if you can. I'm curious.
Phillip Bradfield
Current stock: '57 Panel Bus, '63 Rat Notch, '64 Baja, '66 Variant, '67 Convertible Ghia, '68 Squareback, '69 Squareback, '69 Fastback
Southern Oregon VW Club -- http://www.sovw.org
Oregon VW Forum -- http://www.oregonvw.org
raygreenwood
raygreenwood is offline
PostPosted: Thu Jan 29, 2009 12:16 pm    Post subject: Reply with quote
It rains like hell anywhere in Texas but the western part. Houston is a swamp. Dallas and parts north run 75-80% humidity year round. I was stunned how fast things rust in North Texas. Ray
RATTRP
RATTRP is offline
PostPosted: Thu Jan 29, 2009 12:34 pm    Post subject: Reply with quote
I whole heartidly agree with that statement... My rocker panels are swiss cheese and various other parts of the car. I really and truly have no desire to swap the bodies, but looking at the condition of mine vs. the 68... the 68 seems a better option.
Does it matter in the swap that my 69 is an auto and the 68 I believe was a manual? Thanks -
Russ Wolfe
PostPosted: Thu Jan 29, 2009 12:41 pm    Post subject: Reply with quote
The manual/automatic should not be a problem. The differences there are in the chassis, not the body.
Gary: OK. Ima poop.
RATTRP
RATTRP is offline
PostPosted: Thu Jan 29, 2009 1:04 pm    Post subject: Reply with quote
Ok... so aside from adding the engine hanger mounts to the 68 body, it should be a straight forward swap?
I understand that I am to disconnect the steering column, wiring, etc... how many bolts am I looking for and where abouts are they. I apologize for all of the stupid questions and I fully expect sarcastic answers, but I have not torn into this effort yet. Shocked
Notched
Notched is offline
PostPosted: Thu Jan 29, 2009 1:32 pm    Post subject: Reply with quote
My '68 manual body is sitting on a '72 auto pan.
How bad is the pan on the '69? If it needs work, I would suggest fixing it while the body is off. It's wayyyyyy easier!
Phillip Bradfield
RATTRP
RATTRP is offline
PostPosted: Thu Jan 29, 2009 2:15 pm    Post subject: Reply with quote
The pan is in bad shape!!! I will need to replace vs repair the pans... I guess we shall see how well this goes. Maybe I can document my work with photos/video for future morons like myself that would like to swap bodies!
Bobnotch
Bobnotch is offline
PostPosted: Thu Jan 29, 2009 2:59 pm    Post subject: Reply with quote
When you really get right down to it, a body swap isn't any harder than doing a body off resto. I only say that, because you've still got to remove the body from the pan. The number of bolts and stuff has been covered a few times, so itmight be worth doing a search. As for repairing, or replacing pans, you could do a search for that as well, as it's been covered a few times as well. I know I should have pics in my gallery, and Russ had some of his t-34 ghia posted also. I think I've even got them in a thread I started back in 07 called "Tear down has started", showing the old floors cut out, and then the replacement pieces tacked in, and finally welded. The search function is your friend here, and it'll help you out a bunch with these cars. Wink
Here's one of the links I was mentioning.
http://www.thesamba.com/vw/forum/viewtopic.php?t=240540 -tear down
The second one is the build up of the car being torn down in the first thread. I hope this helps.
Bob 65 Notch S with Sunroof
Tram wrote:
Tram wrote:
RATTRP
RATTRP is offline
PostPosted: Mon Feb 02, 2009 10:04 am    Post subject: Reply with quote
Much thanks to all who have replied to this thread... the help/advice is much appreciated!!! Very Happy
