meyervw Samba Member
Joined: January 29, 2006 Posts: 470 Location: Chico, California
Posted: Thu Jan 29, 2009 6:36 pm Post subject: Gear oil for stock 4 speed manual trans. |
Sunday the trans is getting the out put seal done and new oil. I can get Redline MTL or a good quality 80-90w gear oil. The temps here are all over so. The qestion is, is redline that good? I have heard great things about but never tried it. I can get redline but am having trouble finding Castrol gear oil or any other good oil. Not sure why. What are you people running in yours? _________________ Spelling in my post may or may not be correct.
Gustav 1987 Wolfsburg Edition |
Pascal Samba Member
Joined: January 13, 2006 Posts: 825 Location: Fredericton, NB, Canada
Posted: Thu Jan 29, 2009 6:47 pm Post subject: |
Thanks for the link _________________ Spelling in my post may or may not be correct.
westyventures Samba Member
Joined: December 29, 2004 Posts: 2306 Location: Oregon Outback
Posted: Thu Jan 29, 2009 7:11 pm Post subject: |
IMO, Redline MT90 is fine for a van with stock engine. BUT, if it has a more powerful engine with far more torque, I'd lean toward either their std. 75W90 or another other top branded synthetic 75W90. I've seen failures of gearboxes running MT90 that appear to be oil related. I'm now using Royal Purple 75W90 in my TDI rigs. There is one tranny builder that recommends LE Industry's 9919, but at twice the price it has exatly the same test results as RP or RL 75W90. |
Herr Motorspiele Samba Member
Posted: Thu Jan 29, 2009 8:19 pm Post subject: |
Karl,
Can you describe the failures you've seen resulting from MT90? After all the debate I just went with Napa's StaLube GL4 since I couldn't find Redline locally anymore. |
Posted: Thu Jan 29, 2009 8:55 pm Post subject: |
Herr Motorspiele wrote: |
Karl,
These are mainly Syncro trannies I'm working with--I'm seeing the needle bearings inside low gear and the gear carrier housing, the ball bearing next to 4th gear in the same case all wearing prematurely. The low gear double-bearing especially. Daryl at AA says low needs more clearance than is called for in the book. I just regeared a tranny that had Redline in it since being rebuilt 40K ago and it looked filthy inside and the above bearings headed south. After reading more about MT90 I realized it is actually a thinner oil than std. 75W90. Works great for shifting, but IMO not viscous enough to protect the areas where it is most needed. |
Posted: Thu Jan 29, 2009 9:26 pm Post subject: |
I'm glad I stuck with Dino GL4 in my Syncro's front and rear!
However now you have me thinking about Royal Purple.
The plot thickens.... |
presslab Samba Member
Joined: September 29, 2008 Posts: 1730 Location: Sonoma County
Posted: Thu Jan 29, 2009 9:51 pm Post subject: |
Do not use MTL, it's way too thin.
Daryl at AA Transaxle recommended MT90 which is what I am running in his rebuild. I changed the oil at 10k miles and it was a little dirty, just the new parts breaking in and whatnot. It's been working great.
I'm using an EJ22, which doesn't have much more torque than the stock 2.1, although it does rev higher. _________________ 1986 Vanagon Westfalia EJ25
1988 Subaru GL-10 EJ20G --- 2000 Honda XR650L
2010 Titus El Guapo --- 2011 On-One 456 Ti |
insyncro Banned
Posted: Fri Jan 30, 2009 8:21 am Post subject: |
I have tried all the Synthetics and feel Swepco is far superior.
dylan |
Jon_slider Samba Member
Posted: Fri Jan 30, 2009 1:19 pm Post subject: |
Im currently using MT-90 in my 86 syncro, as recommended by my transaxle rebuilder, German Transaxle. It does shift more easily, than when it had gear oil, during these freezing months, temp overnight was 19F.
Due to numerous comments that swepco is better for the hypoid gears, I will change out when its not freezing cold..
fwiw, GoWesty uses MT-90 too
And Daryl at AATransaxle also recommends it. His comments are that if you have an SVX engine, the swepco is a better choice.
otoh, I respect Karl's opinion, as well as that of Seth of Mastercraft motors, both of whom report concerns with MT-90
Im using it because its what the rebuilder told me to use, since its a brand new rebuild, I wanted to respect his warranty.
From what I can tell, the MT-90 is favored by folks who deal with freezing temps.
Jonathan |
Posted: Fri Jan 30, 2009 3:30 pm Post subject: |
I have run last 400K miles I have put on my Syncro, Vanagon, and Bay with 0W-30 synthetic engine oil in the gear boxes. No problems to date. Shift fine when cold, the oil looks good after long use, and very minimal filings on the magnetic drain plug. |
mightyart Samba Member
Joined: March 24, 2004 Posts: 6188 Location: Portland, Oregon
Posted: Fri Jan 30, 2009 4:53 pm Post subject: |
If this thread turns into a fight it will be deleted. |
GWTWTLW Samba Member
Joined: April 22, 2008 Posts: 2174 Location: Portland, OR
Posted: Fri Jan 30, 2009 5:04 pm Post subject: |
mightyart wrote: |
Who's fighting? _________________ 89 Syncro Westy - GW 2.5, now with a double knob job
@gwtwtlw |
Posted: Fri Jan 30, 2009 5:09 pm Post subject: |
GWTWTLW wrote: |
mightyart wrote: |
Who's fighting? |
Nobody, but for some reason gear oil threads turn into fights.
So lets make this one, one of the exceptions. |
Posted: Fri Jan 30, 2009 5:12 pm Post subject: |
mightyart wrote: |
GWTWTLW wrote: |
mightyart wrote: |
Who's fighting? |
IMO, EVERY thread has equal opportunity, just depends on who is involved and how stressed/peeved at the world they happen to be at post time. |
Posted: Fri Jan 30, 2009 5:51 pm Post subject: |
Well IO found Canstrol 80w-90 and thats what is going in. _________________ Spelling in my post may or may not be correct.
vortex2.71 Samba Member
Joined: February 24, 2009 Posts: 2 Location: Seattle, WA
Posted: Tue Feb 24, 2009 4:39 pm Post subject: Climate Matters |
I think a major disconnect when people debate tranny fluid (or even engine oil) pertains the the climate that people are operating the vehicle in. It would be useful if people would post their recommendations with a stipulation about climate. Some of us just don't encounter temperatures below 25 degrees and others don't encounter temperatures above 80 degrees. Since most of the debate centers around cold start vs. running temperature this makes a big impact for cold starts. |
Posted: Tue Feb 24, 2009 7:06 pm Post subject: |
The temps where I live range from 30 deg F to 110 deg F. A big range. _________________ Spelling in my post may or may not be correct.
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17124 Location: Retired South Florida
Posted: Wed Feb 25, 2009 9:09 am Post subject: |
Synchronized transaxles have two requirements. When shifting the brass synchro ring needs to be able to grab the gear and slow it for a smooth shift. If the synchro ring slips you get that "grind" sound. The other requirement is for the gears and bearings to have adequate lubrication for the loads they see. Here is the problem. The better the lubrication for the gears, the harder for the synchro ring to grab the gear. Too thick makes it hard for the synchro to grab the gear. Cold days make any gear oil thicker. I'd say new or rebuilt transaxles have different requirements from high mileage ones. Climate and age should always be considered. Also remember, GL ratings for lube are not the same as for Brake Fluid. GL 5 is not better than the spec'd GL 4. Where DOT 5 brake fluid would have higher boiling points etc over DOT 4 or DOT 3. I will refrain from making a recommendation. If you have a high mileage transmission with grinding gears when shifting cold but seems to improve when warmed up. Perhaps a lower viscosity might give you better results without having the transmission rebuilt. Was that civil yet informative? _________________ ☮️ |
gears Samba Member
Joined: October 28, 2002 Posts: 4391 Location: Tamarack, Bend, Kailua
Posted: Wed Feb 25, 2009 12:11 pm Post subject: |
rsxsr wrote: |
GL 5 is not better than the spec'd GL 4. |
... other than the fact that GL5 generally has 30-40% more EP additives, which are critical in a transaxle with dinky R&P. |
