JoelH Samba Member
Joined: October 16, 2003 Posts: 1312 Location: North Dakota
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24670 Location: Olympia Wash Rinse & Repeat
Posted: Sun Feb 01, 2009 7:15 pm Post subject: |
Never done that, but would tie a stout string to the brake line as you pull it out through the central belly pan. Then once the old brake line is out tie the string to the new brake line going in and carefully pull the new line through with the string while having someone help push the brake line toward you.
Have done simular routine when installing multiple wire cable through for gauges in a 1958 double door walk thru panel. Had to fish a coat hanger through first to run the string, and then pull the cable through. _________________ In Stereo, Where Available! |
mightymouse Samba Member
Posted: Sun Feb 01, 2009 7:25 pm Post subject: |
First off..wheres the leak? or shall i say, why do you want/need to replace them? _________________ Nothing can stop the man with the right mental attitude from achieving his goal; nothing on earth can help the man with the wrong mental attitude.
Thomas Jefferson
Note to EVERYONE.
Know your ZDDP levels or you WILL lose a cam and lifters. |
campingbox Samba Member
Joined: November 14, 2000 Posts: 10192 Location: Petaluma, CA
Posted: Sun Feb 01, 2009 7:38 pm Post subject: |
The brake lines on belly pan busses run under the pans, so you can change every one of them without removing any sheet metal. |
slow36hp scott wimberley
Joined: August 09, 2004 Posts: 3113 Location: mukilteo washington
JoelH Samba Member
EverettB Administrator
Joined: April 11, 2000 Posts: 69733 Location: Phoenix Metro
33 Willys Samba Member
Joined: January 28, 2008 Posts: 344 Location: Alamogordo, NM
Posted: Sun Feb 01, 2009 10:41 pm Post subject: Brake lines |
I would think that there are hangers along the way to prevent the brake lines from vibrating. If there isn't there should be! |
KWZ Samba Member
Joined: July 11, 2004 Posts: 1341 Location: St. Louis, Missouri
Posted: Thu Apr 02, 2009 2:38 pm Post subject: |
Glad I searched before posting a new topic. I was wondering how I was going to do the brake lines on my '57 Standard....
KWZ Samba Member
Posted: Thu Apr 02, 2009 3:00 pm Post subject: Re: Brake lines |
EverettB wrote: |
33 Willys wrote: |
Yes, there are little holders on my '55 23. |
Gerson's center belly pans have 'em. The pans on my '57 don't because Kelly and I fabricated them long before God sent us Gerson. I'm going to have to improvise by concealing the screw head that fastens each holder behind the brake line itself. |
rjonas Samba Member
Joined: July 24, 2004 Posts: 644 Location: Chandler, AZ
Posted: Fri May 11, 2012 10:27 am Post subject: |
I am presently replacing 65 deluxe belly pans with KF made belly pans. I know the hard brake line runs on the outside of the center pan on the drivers side up aginst the flange but...I swear that 3 years ago when I removed the OG pans the hard line was held on with metal clips that were screwed to the flange. Now when I lay under a friends OG 59 DD panel his has small 1/2"x 1" long tabs welded to the center pan an folder over the hard line. Did they change the tabs when they went to shorter pans or is my memory just burnt and they were welded on tabs all along?
Anyone have a picture of 64-67 style belly pan brake line attachment?
I will be welding on the KF pans this weekend and need to know if I should weld on tabs or screw on tabs.
Thanks. _________________ 1979 Type-2 Westfalia “Sandy”
1973 Type-181 Thing "Velma"
1956 Type-1 Beetle Patina Project “Rosie”
www.azbusclub.org |
Jerry Samba Member
Posted: Fri May 11, 2012 6:47 pm Post subject: |
Roy, the line isn't screwed to the pans at all, there should be tabs about 3/4" long that just wrap around the tubing to hold it in place. I think 4 holders are pinched in to the metal belly pans.
I've seen your metalwork, it may take you 10 minutes to punch them in if you see a pic of them.
Unreal job on your skylight fabbing by the way! _________________ Looking for SO34 parts.
thevwcompound *instagram* |
BulliBill Samba Member
Joined: July 09, 2004 Posts: 4561 Location: St Charles, MO
Posted: Fri May 11, 2012 9:28 pm Post subject: |
Roy's metalwork and fabrication skills are incredible! He came over and checked out my original '59 DD panel belley pans today and was just wondering about the changes to the later pans in '65 thru '67. His 21 window Bus will be awesome! I'm hoping that he'll be able to debut it at the upcoming BNNTA event on Labor Day. All of us locals will be jumping on the re-assembly of it all summer. He has a thread on it on the Air-Cooled Missouri site...
Thanks to anyone who can send a few photos of the later pan brake line mounting details.
Bill _________________ I'm looking for these license plate frames for my fleet:
Mission VW - San Fernando
Thornton VW - Stockton
Thanks for any help! |
zimblewinder Samba Member
Joined: January 22, 2004 Posts: 893 Location: Australia
Posted: Sat May 12, 2012 1:25 am Post subject: |
Hi Bill, could you post a pic of the tabs and detail the positions? I have pre-tab Gerson pans to go on again one day.
CHeers
Dale _________________ 58Euro 23 343208 The Ultimate Zimblewinder Machine.
59 mango standard
Wanted- splash pan supports, og pressed bumper coach bolts, ivory blaupunkt knobs (early), armrest alloy strips, NOS door mechanism |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14216 Location: Casa de Oro, California
Posted: Sat May 12, 2012 7:30 am Post subject: |
Here's my '65's keeper-a-rookus'. Looks to be done during the stamping in the die with a cutter. Then the tab is ready to wrap around the brake line without an additional step. Rolling Stones stole their logo from me.
rjonas Samba Member
Posted: Mon May 14, 2012 8:17 am Post subject: |
Bill's 59 DD panel has 4 strips of metal 1/2" wide and 1" long that are tack welded to the pan then folded over the line.
But...my OG pans do have 4 small arched holes (I thought were drain holes because the tabs are gone) like that picture so thats how I'll make them.
Figure I'll make a die and punch to duplicate that brake line tab doodad.
Thanks for the props, info and picture guys...so close to paint time I can almost taste it.
BTW...Jerry, what is your build thread titled on the Full Moon Bus Club? _________________ 1979 Type-2 Westfalia “Sandy”
www.azbusclub.org |
rjonas Samba Member
Posted: Fri May 25, 2012 1:34 pm Post subject: |
Well...I'm a dumbass...my rusty OG pans had one those tabs. Normally OG belly pans have (4) tabs punched in them for retaining the hard brake line to the rear. I made a punch & die from cold rolled steel. Punched tabs into the Klassic Fab center pan that was missing them.
Enjoy!
www.azbusclub.org |
kirbyland Samba Member
Posted: Wed Oct 01, 2014 7:16 pm Post subject: |
pretty sure my '57 had screwed cli/hangers. Gonna have to look at my pics- |
