Viewing feedback for: flat Email: [email protected] Last Visited: April 16, 2024 |
coolrydes Samba Member
Posted: Tue Jan 10, 2012 8:25 pm Post subject: |
Hey, Bob
It might have been just you. Have you ever seen the sign in a business that says "they reserve the right to refuse service to anyone"? Maybe this means you......
We here at Mendeola have been more then happy the way that Lanner has worked with us and our customers on their brake projects. I personaly have never heard or seen him be anything less then professional...... He like a lot of shops that specailize in something, some times takes longer then estimated. This is the nature of custom stuff....
Best of luck to you Bob! _________________ Kevin "Coolrydes" Zagar
COOLRYDES So-Cal CUSTOMS
MENDEOLA SUSPENSION
THE HOME OF STYLE AND PERFORMANCE
www.CoolRydescustoms.com |
MR GAS Samba Member
Joined: October 29, 2008 Posts: 129 Location: Canon City
Posted: Sat Jan 21, 2012 6:22 am Post subject: |
i used Vdubengineering Passat brake caliper bracket kit for my Vanagon. Very nice fit and better function, thanks Lanner! |
petevdub Samba Member
Joined: January 01, 2005 Posts: 205 Location: Toronto, Canada
Posted: Mon Jan 23, 2012 5:27 pm Post subject: |
Lanner's knowledge of manufacturing brake kits for our toys impresses again. I took him a set of Boxster calipers, with my early heart 5.5's and deep 6's, and asked him to make it work for my '65 bus. He made it all work together, told me which rotors to source, and it installed without issues. The welded 944 dropped spindles are by far the nicest, I've ever seen.
One of the best guys in the business. Thanks! _________________ '72 super
'65 21w
'52 split 11C |
danielzink Samba Member
Joined: August 03, 2004 Posts: 282 Location: Lansing Michigan
Posted: Tue Feb 07, 2012 7:16 pm Post subject: |
I've had Lanner do two different brake setups for me.
The first one was about 7 years ago for my bug - he walked me through the entire process as well as doing all the machining. We even met on a dark canadian highway to exchange some brake parts - very clandestine...dangerous undercover stuff
Just this past month - after what seemed like a hundred emails - we finally got the brake system for my Notch figured out - and I placed another order.
If nothing else - this cat is patient......I don't spend my money easily - and I like a vendor to "hold my hand and reassure me everythings gonna be okay" and Lanner was more than up to the task.
I didn't rush him - no sense in that. Machinists are craftsmen - they take time - and you have to be prepared for it. A lot of this is custom work - and your life is riding on what this guy makes for you.
I have every confidence in Lanner. I have kept the original business card he gave me back in the day - and I always recommend him whenever possible.
Dan Zink _________________ 1965 Notchback 2300cc Type4
Subaru Powered Rail
1915 Rail
www.danielzink.com |
vdubzack Samba Member
Posted: Wed Feb 08, 2012 10:38 am Post subject: |
Great machine work. Excelent packaging, and quick turnaround. Very highly recomended. Money well spent. Will be posting pics of build on germanlook forum. |
Clatter Samba Member
Joined: September 24, 2003 Posts: 7537 Location: Santa Cruz
Posted: Tue Feb 21, 2012 7:05 pm Post subject: |
I have had Lanner do a few different things for me.
He took a set of Burt's Type 3 drop spindles and modded them for 944T calipers.
This was likely the only set of these he will ever do,
but yet he did them, and quickly, for a good price.
And they came out sweet...
Lately he sold me just a set of e-brake cable extension tubes.
a PITA for just a little order like that, but the man came through.
He's always been professional, communicated well, and did nice work. _________________ Bus Motor Build
What’s That Noise?!? |
FG1732 Samba Member
Posted: Sat Mar 31, 2012 8:03 pm Post subject: |
Lanner is one of the smartest guys on this website in engineering & design.
I once told him that if he was really that smart, he should stop dealing with cheap VW dreamers and venture into engineering his superb line of products for the American muscle car crowd where the real $$$ is.
Glad he never took my advice.
All of the following is Lanners vision...
^ 4.5s over 986 Brembos
^ Brembos fit swing axle rear no problem. Notice the mounts. 16x7.
^ Lanner kit on upper right, junk on the left.
^ 944 E-brake kit works perfectly because of Lanners calculations.
^ Brembo mounts, front.
_________________________________________________________________________________________
Now here is a challenge for you Mr. Wise Wizard. Design a system where we can install the multilink rear suspension out of a early 996 (as shown below) into a vintage VW ...
lburney Samba Member
Posted: Sun Apr 01, 2012 2:51 pm Post subject: |
After outfitting our 74 Super Beetle with 944 brakes, hubs and struts, we were concerned that the length of the stock VW tie rods was insufficient/and unsafe for proper toe adjustments with our now, slightly wider wheel stance.
Today, Lanner came to our rescue with a set of Super Duty tie rods that are about 60% thicker and an inch longer than stock. Moreover, they were perfectly machined, beautifully finished and reasonably priced. While tie rods are not sexy, go-fast parts, I believe it is important to recognize those sellers who consistently provide a quality product, prompt service with a helpful attitude.
Well done, Lanner.
lin/Ks |
jbbugs Samba Member
Joined: September 16, 2002 Posts: 2152 Location: Behind the wheel
Posted: Tue Jun 12, 2012 7:24 am Post subject: |
Lanner hooked me up with a front brake kit for my ChumpCar Racer. I had a deadline to meet, and was a bit of a rush, Lanner came through! It held up just fine to 14 hours at Daytona, and speeds up 120mph.
no worries buying from Him.
_________________ Drag bus! http://www.youtube.com/watch?v=s2MOVmKdhX4
69 OG paint Transporter
73' Super Beetle Champcar Endurance Roadracer
Patina my ass, that's a Rust Bucket! |
conrad1468 Samba Member
Joined: December 20, 2003 Posts: 1019 Location: Jeannette, PA 15644
jchilders388 Samba Member
Joined: November 06, 2011 Posts: 6 Location: Paso Robles, California
Posted: Fri Sep 07, 2012 2:37 pm Post subject: |
I also bought some fuel pump pins with the circlip. Solved my issues of the old pin wiggling out of the fuel pump. Excellent service. Thanks Lanner! |
Mr_Zed_ZX20 Samba Member
Posted: Wed Sep 12, 2012 7:21 pm Post subject: |
To all,
I just received my brake kit from Lanner yesterday and his work is impeccable. Lanner modified my Mendeola S2 spindles and 944 hubs to accept 2001 Porsche Boxster S brakes and sold me the e-brake swans with spacers for the rear. His customer service is top notch as I started pestering him with constant questions roughly 7 months prior to sending anything his way. He was always quick to reply with helpful responses and kept me up to date on the progress of my parts.
Unfortunately, the Canada Post was a little rough with the box and there were minor blemishes on one of the hubs and caliper bracket because of it. I contacted Lanner just to give him a heads up and he offered to repair the damages at his cost. Repair most certainly is not necessary as everything will be covered when assembled, but the offer is certainly appreciated. If I have another project needing brake work I won't hesitate to utilize his services.
T2 Samba Member
Joined: February 15, 2003 Posts: 187 Location: Yachats, Oregon
Posted: Fri Sep 14, 2012 6:33 am Post subject: |
Great product, fast shipping. I am sure I will need more of these fuel pump parts in the future. |
losinground Samba Member
Joined: September 17, 2004 Posts: 28 Location: Roanoke,Va
Posted: Wed Oct 03, 2012 2:00 pm Post subject: |
I just purchased a strut bar from Lanner. This thing is a work of art! Love it! |
doc hopper Samba Member
Joined: December 08, 2006 Posts: 588 Location: California
Posted: Sat Jan 12, 2013 8:22 am Post subject: Lanner |
I found out about Lanner's stainless fuel pump pivot pins on Samba after my Brosol pump went south leaving me stranded on a busy freeway in my 1970 bug. Talk about designed-to-fail! That fuel pump had a total of 4,500 miles on it when the pin worked its way out, leaving me dodging 5 lanes of traffic going 70+ mph all around me!
The day I got my pin order from Lanner I set about "rebuilding" the very pump that had failed me. One question had me perplexed: the Lanner pin is a very tight fit; it must driven into place, not lightly pushed or tapped. I had noticed that the original circlip equipped pumps had pins that were much looser. My concern was that in their infinite wisdom, perhaps the German engineers who designed the original pumps had intended that the pivot pins be allowed to rotate in place.
I thought this would keep the metal push paddle from wearing a groove in the pin as it pivoted several thousand times per minute. I sent a query to Lanner and got a prompt response that the pin was designed to be rigid in place, depending on the grease packed in the chamber to provide sufficient lubrication. My initial order was for 5 pins and I just ordered 5 more so that every fuel pump in my five vehicle "fleet" will be modernized, and I'll have 5 back up pumps ready to go once the E-10 fuel destroys the diaphragms.
Note: My VW mechanic was so impressed with the pins that he has ordered a bunch so that he can modify customers' stock pumps before they fail. _________________ "Honesty hath no fence against superior cunning" |
67ghiaTIV Samba Member
Posted: Tue Feb 05, 2013 5:09 pm Post subject: |
Lanner is a great guy selling some great products. I recently bought some used parts and am very happy.
Jamie |
rhowde Samba Member
Joined: February 06, 2010 Posts: 12 Location: Puyallup
Posted: Thu May 23, 2013 8:10 am Post subject: |
Might as well keep this one going... I purchased Lanner's kit over a year ago. Due to time restraints, I was unable to do anything with it until now. Well, I just got it all put together. It went together as well as if it was OEM equipment, just higher quality.
What amazed me was mine was a two-fold conversion. First to 944 rotors and then to Boxster calipers. Everything was spot-on!
Dealing with aftermarket or custom machined parts almost always ends up with you having to alter something to make it work. Not his. The fit and finish of his products are second to none. I would recommend his offerings in a heartbeat.
Thanks Lanner!! |
splitidentety Samba Member
Posted: Mon Jul 08, 2013 2:10 pm Post subject: |
I ordered the parts 30-6 and received them on the 8-7 at home in the Netherlands, aim impressed by the speed, the good service and the excellent quality off the parts. they fit very well. Thanks Lanner great job |
oldskool73 Samba Member
Joined: July 06, 2005 Posts: 63 Location: Monterey Park CA,
Posted: Thu Aug 15, 2013 1:04 pm Post subject: |
I'm am glad to hear lanner came through for all of you guys. But Unfortunately for me I am going on to 7 months with no front brake kit and up to 3 months with no response through email or private messages on here and germanlook.net. But would respond when I used a different email ( kind of sketchy). I decided to post a new thread on the buyer and feedback about all of this and he responded to my email saying:
Man, that samba post is my biggest pet peeve. What about good old telephone as a means of communication.?
If your stuff isn't done by Tuesday I'll send it back unmodified.
Lanner
Really?? after 7months my hubs are still not done. What a joke!! If i did contact him over the phone once he found out it was me he would probably ignore my calls as he did my emails/private messages. Send them back unmodified thanks |
Ebeneezer Samba Member
Joined: March 09, 2009 Posts: 7 Location: Nottingham, England
Posted: Tue Sep 17, 2013 5:17 am Post subject: Brake Kits |
Just received the kit for my Porsche brake conversion on my split from Lanner. He has patiently listened to my requirements and spent weeks offering advice before I made a purchase.
He always responds to my emails, however dumb the questions and has been nothing less than superb.
I would highly recommend his services.
Thanks again Lanner. |
