40 horse fuel pump
stede
Location: Buckeye,AZ by way of El Sereno Rifa, Sur Califas 13
stede is offline
PostPosted: Thu Feb 05, 2009 6:21 am    Post subject: 40 horse fuel pump Reply with quote
How do I check if my 40 horse fuel pump is working ? I have three different fuel pump and none of them are pulling the fuel from the tank. I just put my newly rebuilt motor in last night and no fuel. Is it possible that my fuel line may of gotten clogged ? Please advise. Thanks OG !
Harris
Harris is offline
PostPosted: Thu Feb 05, 2009 6:34 am    Post subject: 40 hp fuel pump Reply with quote
Mine did the same thing after an engine rebuild. I put a woven line on the fuel line just before the pump connection and sucked on it and the fuel came through. It was stuck for some reason. No problems since.
Prime the pump also by doing the same thing after the main line is connected to the pump.
stede
stede is offline
PostPosted: Thu Feb 05, 2009 6:46 am    Post subject: Reply with quote
Before I put my new motor in it wasn't getting gas either for some reason . I gonna try what you said Harris. Hopefully that works.
hsosa1
hsosa1 is offline
PostPosted: Sat Feb 07, 2009 12:45 pm    Post subject: Reply with quote
You may need to check the fuel pushrod make sure its the right size. also open up the 40hp fuel pump it might be clogged. on the bottom half mine fuel pump had debri and my carb would just die out. opened my fuel pump and found the problem. good luck
Just Cruzin Sur Califas VW Car Club est♤1998
View user's profile Send private message Visit poster's website Twitter Gallery Classifieds Feedback
vila
vila is offline
PostPosted: Fri Feb 13, 2009 10:41 pm    Post subject: Reply with quote
three fuel is new ?or same size?
__________________________
www.stylelead.com
stede
stede is offline
PostPosted: Tue Feb 17, 2009 2:00 pm    Post subject: Reply with quote
Thanks Homie. I figured that the filter in the gas tank was clogged with rust. Gracias.
PostPosted: Tue Feb 17, 2009 2:55 pm    Post subject: Reply with quote
Like this
My Bus ran with this pump when I bought it but it would die on hills. It wasn't pumping enough fuel to keep up. Smile No sock in the tank and a tank full of tiny rust flakes didn't help either.
hsosa1
hsosa1 is offline
PostPosted: Tue Feb 17, 2009 5:43 pm    Post subject: Reply with quote
Yes exactly like that Everet! Check your fuel pump
