lovethatconvertible Samba Member
Joined: August 22, 2008 Posts: 1434 Location: Las Vegas N. V.
Posted: Wed Feb 14, 2018 7:23 pm Post subject: Re: Official Oval Convertibles thread and Registry |
Yes, the gutter goes towards the outside of the car. No tubes, water drains thru drain stamping's at the bottom of the quarter panel, kinda like at the bottom of the doors. Not very effective if there is a lot of water getting trapped down there from dirt build up. Good window rubber's /scraper's are a must.
If you search quarter panel in the classifieds, on the first page there is a great pick of the weep holes in an add. I'd put a link but i don't know if that's cool to do. _________________ 1960 Convertible |
56Cabrio Samba Member
Joined: May 22, 2008 Posts: 1899 Location: San Fernando Valley, CA
Posted: Wed Feb 14, 2018 9:50 pm Post subject: Re: Official Oval Convertibles thread and Registry |
BulliBill wrote: |
I also have a question about side windows. Okay, concerning the two left and right side roll-down quarter windows for our back seat passengers. There is a horizontal metal "moisture gutter" attached to and below the window frames (below the rubber outer window scrapers) that channel any water that gets past the rubber scrapers the water rearward to a short downward curved metal tube. Does the water just drop from the end of that metal tube into the interior of the quarter panel cavity and drain out somehow from the bottom of the cavity? My '57 Kab is packed full of stuff in storage so I can't immediately see how this works. Also, is there a rubber or plastic tube that attaches to the end of that metal drain tube, and if so, where does it go thru the body or chassis pan? An explanation would be helpful, photos even better to help understand what I'll need to do about this. Thanks for any assistance!
Bill |
Is this what you are asking for Bill ? 63 years of dirt right there
_________________ F#CK CANCER
Make a donation
1956 Rag Top owned since 1988
1963 Hard Top
RIP Dad 4/20/1951 - 2/4/2023 |
aa390392 Samba Member
Posted: Thu Feb 15, 2018 10:03 am Post subject: Re: Official Oval Convertibles thread and Registry |
As I just disassembled, Mine both were clogged with dirt, but no damage to the body..now to reassemble...
The only problem is going to be wing, rusted screws had to be removed with other forces than screw drivers & kryoil..
Tomas _________________ .
getting grumpy & less tolerant!
55 ragtop
56 delux sedan
56 Kabriolet |
BulliBill Samba Member
Joined: July 09, 2004 Posts: 4572 Location: St Charles, MO
Posted: Thu Feb 15, 2018 11:27 am Post subject: Re: Official Oval Convertibles thread and Registry |
Okay, thanks "56Cabrio" for the photos above. Inspired, I got to my Kab and spotted the process for drainage on the Kab quarter panel cavity. Here is a look downward towards the bottom of the quarter panel cavity at my 60+ year old dirt down there. Dig the old wasps nest too (now removed):
So apparently the water that gets past the outer rubber window scrappers collects in the horizontal "gutter" to drain rearward to the round metal curved drain pipe which dumps the water right into the "U" shaped window guide channel directing most of the moisture downward and forward to the forward bottom region of the cavity and dumping it down there. Then the water drains outward of the cavity through three vents or exits dumping the moisture between the running board and the chassis stiffener. Sound right? Photos of this revelation below:
Kinda fun to do the detective work, thanks for the assistance! I'll be vacuuming the crap out of the entire bottom of that cavity and making sure those vents are truly clear before someday sending it off to paint...
Bill _________________ I'm looking for these license plate frames for my fleet:
Mission VW - San Fernando
Thornton VW - Stockton
Thanks for any help! |
theorangeperil Samba Member
Posted: Fri Feb 16, 2018 4:10 am Post subject: Re: Official Oval Convertibles thread and Registry |
Great pictures Bill. Interesting to see what's going on down there.
That will be my next task once I have an understanding on the differences between the frames.
I guess as no one has replied we are all a bit in the dark with that?
With regards removing the frames are there any online resources showing the best approach to removing them from the car?
Here's a picture of my car at BBT on the way to Hessisch Oldendorf last year. It's an early '55 RHD, some of you may know the car.
Posted: Fri Feb 16, 2018 4:25 pm Post subject: Re: Official Oval Convertibles thread and Registry |
Something i never really noticed until looking at Bill's and my pics,the undercoating on the quarter panels. The doors have the same coating. So i took my panels off my 56 Rag top and no undercoating,my 63 hardtop doesn't have the coating either. I guess Karmann applied it ?
Dave
Bill's vert
My Vert
door
Make a donation
1963 Hard Top
AlteWagen Troll
Posted: Tue Feb 20, 2018 9:33 pm Post subject: Re: Official Oval Convertibles thread and Registry |
AlteWagen wrote: |
I like the little coach built things karmann does like the under coat and lower primer dip to the body.
I wonder if they didn't dip the whole body cause all the body work they still had to do on them.
Pics from AlteWagen's & usariemen's gallery
Make a donation
1963 Hard Top
Posted: Wed Mar 07, 2018 10:21 am Post subject: Re: Official Oval Convertibles thread and Registry |
Anyone else see this 1956 Kabriolett, up for sale I think this weekend at the Sothebys auction in FL?
https://rmsothebys.com/en/auctions/AM18/Amelia-Isl...ann/566196
Bill Bowman _________________ I'm looking for these license plate frames for my fleet:
Dukesmojo Samba Member
Joined: September 27, 2017 Posts: 15 Location: Dayton, OH
Posted: Wed Mar 07, 2018 1:29 pm Post subject: Re: Official Oval Convertibles thread and Registry |
I did not see that one listed prior. cool old vert but a little out of my price range. _________________ 1961 - Gulf Blue - Convertible Beetle |
RareAir Samba Member
Joined: May 11, 2002 Posts: 14576 Location: 18 miles North of the border
EverettB Administrator
Joined: April 11, 2000 Posts: 69802 Location: Phoenix Metro
55vert Samba Member
Posted: Sat Mar 10, 2018 11:33 am Post subject: |
New to this thread but our 55 has the OG rear seat strap. |
eth727 Samba Member
Joined: February 21, 2007 Posts: 542 Location: san diego
Posted: Sat Mar 24, 2018 8:08 am Post subject: window wedge installation |
Does anyone know how the front door vert window wedge stays on? It doesn't have any holes for clips. I thought maybe the chrome molding holds it down but it keeps coming off when I close the door. |
bugmandave Samba Member
Joined: December 30, 2005 Posts: 642 Location: Illinois
Posted: Tue Apr 03, 2018 6:59 am Post subject: Re: Official Oval Convertibles thread and Registry |
Use weather strip adhesive _________________ '63 Karmann Cabriolet L456 Rubin (Ruby Red)
'71 Westfalia campmobile tourist delivery
January '59 SWR panel
'63 Karmann Cabriolet L54 Poppy Red |
ngobet Samba Member
Joined: September 04, 2007 Posts: 96 Location: Switzerland / California
Posted: Tue Apr 24, 2018 7:40 am Post subject: Re: Official Oval Convertibles thread and Registry |
Hello everyone,
the back seat on my 56 vert keeps on folding when I am driving on the highway with the top down. Since the car was rebuilt with cheap TMI material, can someone tell me if there should be a kind of lock to prenvent to back rest from folding?
There is nothing of that sort on my car now.
Thank you |
ngobet Samba Member
Posted: Wed Apr 25, 2018 5:14 am Post subject: Re: Official Oval Convertibles thread and Registry |
thank you very much, I don't have the hooks either. Is there one on both sides? Does anyone have a picture how the rubber straps are fixed on the rear seat? |
ngobet Samba Member
Posted: Wed Apr 25, 2018 6:48 am Post subject: Re: Official Oval Convertibles thread and Registry |
ngobet wrote: |
found a pic here
graysky wrote: |
From the gallery thanks to Renderit and 67 Florida Deluxe |
Lars B Samba Member
Posted: Sat Jun 02, 2018 7:36 am Post subject: Re: Official Oval Convertibles thread and Registry |
on my 56.
