vwboop Samba Member
Joined: April 04, 2004 Posts: 716 Location: Langley, BC
Posted: Fri Oct 24, 2014 7:16 am Post subject: |
bubba wrote: |
grailoc wrote: |
let`s say 5 meter required by bus,
5000/5 = 1000 bus |
Sounds like a lot of footage.. But at .15 foot.. Is still worth it... I'm down for a set to do all three tables |
we have two conversations goin on here. I like both of them Let's continue the gold trim one here:
http://www.thesamba.com/vw/forum/viewtopic.php?p=7373375&highlight=#7373375 _________________ "Love and good roads" |
Stocknazi Samba Member
Posted: Fri Jan 23, 2015 2:45 pm Post subject: |
grailoc wrote: |
Here are the dimensions of the rear roof section:
I have a couple questions concerning these measurments for the rear ceiling panel that were posted.
I have an original rear ceiling panel, but it was removed by someone who kindly ripped one side out of the driprail and damaged that side; I can not get a side to side measument.
I see in the diagram above that the front edge near the subhatch hole is 140cm and the rear is 136cm wide. Should the measument be 140 wide until you get to the 92cm mark and then be 136 all the way to the back?
Also, my front to back measument for this panel was 126mm instead of the 122 posted.
Here are a couple pics Jake posted of his rear panel; you can see the gradual curved cut on the side. It does not appear to be 140, come to a point and become 136 like the diagram shows. Not saying the measurments in the diagram will not work, but looking to find out what would be close as possible to the og panel.
http://i61.photobucket.com/albums/h68/itskingsnake/61%20so23/interior%20refinish/P1030661.jpg
http://i61.photobucket.com/albums/h68/itskingsnake/61%20so23/interior%20refinish/P1030659.jpg
http://i61.photobucket.com/albums/h68/itskingsnake/61%20so23/interior%20refinish/P1030654.jpg _________________ WANTED:
"Resistance to tyrants is obedience to God."
Thomas Jefferson
RobzKombi Samba Member
Posted: Fri Jan 23, 2015 3:08 pm Post subject: |
StockNazi wrote: |
grailoc wrote: |
I have ann original rear ceiling panel, but it was removed by someone who kindly ripped one side out of the driprail and damaged that side; I can not get a side to side measument.
Also, my front to back measument for this panel was 126mm instead of the 122 posted. |
No, The way I did it was I measured 136cms up to the 30cms mark then taper it out to the 140cms. When I went to install it, it snapped right into place. Good luck. |
sled Samba Member
Posted: Fri Jan 23, 2015 6:13 pm Post subject: |
my rear roof panel had no curve/angle change whatsoever to the sides, it was a straight cut from the leading edge to the trailing edge. _________________ drive your split. |
earlywesty Samba Member
Joined: May 03, 2004 Posts: 2358 Location: In the woods, Ontario
Posted: Fri Jan 23, 2015 6:16 pm Post subject: |
sled wrote: |
my rear roof panel had no curve/angle change whatsoever to the sides, it was a straight cut from the leading edge to the trailing edge. |
The originals I have seen were also this way. I can't say whether they were 140 at one end and the same at the other or not. It wasn't much of a difference if there was a taper at all. |
Posted: Fri Jan 23, 2015 6:50 pm Post subject: |
buseric wrote: |
sled wrote: |
Thanks for the info.
I think i will use my SO-42 rear ceiling panel as a template and lenghten it to 126mm. Thanks for the imput. _________________ WANTED:
Thomas Jefferson |
Posted: Sat Jan 24, 2015 6:45 pm Post subject: |
Ok, I measured the SO-42 rear ceiling panel width and it is very close to the demensions posted in the diagram.
140cm at the front, 136cm at the back.
I measured the inside driprail of my bus and it is the same width in the area the rear ceiling panel will be.
My plans are to cut the new panel 140cm wide and see how the fit is. _________________ WANTED:
Thomas Jefferson |
Atlantic Samba Member
Joined: July 24, 2008 Posts: 704 Location: Kalifornien
Posted: Sat Jan 23, 2016 7:24 pm Post subject: Re: SO23 Westy - Interior Limba wood restoration - roof / pa |
I know ... years later. But I thought someone who works on a SO23 might find it helpful since there was some confusion before on this thread and I don't want to start a new thread just for this.
I removed an og limba wood roof panel that isn't too bad (good enough to replace my cargo door panel ).
- Only the measurement indicated by the green arrow (length) is constant. All other dimension vary.
- The white measures (width) are somewhat constant - my suspicion is that you could get by with 55" over the whole length.
- The red arrows are showing the placement of the hole for the subhatch. They seem all over the place. I will install the full new panel first and then cut this hole.
- The blue shows the missing wood strip - I am estimating about 1" wide.
... hope this helps. _________________ _______________________
"If we believe absurdities, we shall commit atrocities." [Voltaire] |
johny__utah Samba Member
Joined: September 02, 2008 Posts: 426 Location: Arizona/California
Posted: Thu Apr 21, 2016 10:58 am Post subject: |
How wide are the wood bows top/bottom sides? Also, the 3 main bows the the same width? Thanks!
grailoc wrote: |
I finally finished the subhatch bow assembling today.
The process to redo those bows was very long but I am happy of the end result:
_________________ 1956 L31
1961 L346 L347
1963 L380 L289 |
Posted: Thu Apr 21, 2016 11:06 am Post subject: Re: westy Subhatch bow dimension |
J=X=? Width? Thanks!
grailoc wrote: |
From the picture above, I did some measurement yesterday and I fall on:
B=K=Y= 25 mm.
Could someone confirm my result ?
Thanks. |
1961 L346 L347
1963 L380 L289 |
perello Samba Member
Joined: April 15, 2005 Posts: 829 Location: where social security comes for free
Posted: Sun Jul 10, 2016 11:59 pm Post subject: Re: SO23 Westy - Interior Limba wood restoration - roof / panels |
Just wanted to thank grailoc to encourage me on reproducing the westy side panel. Never did wood working before, and I enjoyed very much doing this.
_________________ Aug '58 pressed bumper SO23
1974 German Thing
1978 Bug 1200
zuggbug Samba Member
Joined: June 17, 2008 Posts: 3479 Location: Anderson SC
Posted: Mon Jul 11, 2016 4:57 am Post subject: Re: SO23 Westy - Interior Limba wood restoration - roof / panels |
Nice long panel _________________ SOUTHERN INTEGRITY AIRCOOLERS
58 15 window
56 westy |
grailoc Samba Member
Joined: March 25, 2004 Posts: 1441 Location: FRANCE and now QUEBEC city
npbusguy Samba Member
Joined: February 08, 2006 Posts: 1658 Location: Budapest, Hungary
Posted: Wed Aug 31, 2016 7:42 am Post subject: Re: SO23 Westy - Interior Limba wood restoration - roof / panels |
I have always enjoyed this thread, but now I will refer to it as an instruction manual. |
Braukuche Samba Member
Posted: Mon Nov 20, 2017 8:11 pm Post subject: Re: SO23 Westy - Interior Limba wood restoration - roof / panels |
Stunning bus all around. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now |
Posted: Mon Nov 20, 2017 9:29 pm Post subject: Re: SO23 Westy - Interior Limba wood restoration - roof / panels |
Braukuche wrote: |
Stunning bus all around. |
X2!! _________________ 1956 L31
1961 L346 L347
1963 L380 L289 |
Posted: Tue Nov 21, 2017 2:09 am Post subject: Re: SO23 Westy - Interior Limba wood restoration - roof / panels |
yup, nothing like a cozy s023 interior
1974 German Thing
1978 Bug 1200
jjjjack Samba Member
Joined: August 08, 2005 Posts: 1013 Location: Gainesville, FL
Posted: Tue Nov 21, 2017 3:21 am Post subject: Re: SO23 Westy - Interior Limba wood restoration - roof / panels |
This is one of my favorite bus restorations, and now I am going to check the forums for status updates every day! Go Jerome! |
