kafer69 Samba Member
Posted: Wed Feb 11, 2009 2:08 pm Post subject: |
the original mirror was broken and I has put another of it, I also have the wrong doors they are ribbed zwitter and early ovali with deflector....I look for 2 doors for split!!! |
franklinunes Samba Member
Posted: Wed Feb 11, 2009 5:36 pm Post subject: |
Allright guys
Thanks for the help, I just wanted to know if the early bumper guards was coming in January 52, since I have 2 splits one from 51 and other from 52 I wanted to know what i should use it in them, it was that.
Guido and 51Kabriolet they know much about this subjects, there is no certain about the real time when they changed for the new ones, they suppose and i suppose it was in January 1952, and there is not registry about this change, so we have to deal with this fact.
Since my cars are both from July, middle of the year there is no such big problem in this, the guard bumper with lips in 51 and the early model in 52.
That ones which have cars from November/Dezember 51 they should care about this, I just wanted to learn, just that
kafer69 u should see if your bumper guards are the correct ones u are in that situation above, when they were prepared to change the bumpers guards, maybe they were using both in the end of 51, maybe they had in stock already to introduce in the end of 51, but this is not a big deal.
Thanks for all this information
Best regards
Frank |
virtanen Samba Member
Joined: January 08, 2006 Posts: 1461 Location: Finland
Posted: Wed Feb 11, 2009 10:49 pm Post subject: |
My split is made on 11th of Jan 1952 and it had newer model guards and I believe those were originals. |
Heb623 Samba Member
Posted: Wed Feb 11, 2009 11:22 pm Post subject: |
Look inside at the crotch coolers of the car!
When the tip of the lever is positioned vertically it means its a 51 and you need the flaired guards!
When the tip of the lever is positioned horizontally it means its a 52 and you need the smooth guards! Normally in this case and also to reduce the draft a backing plate is mounted at the inner wing!!!
ET |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24757 Location: Olympia Wash Rinse & Repeat
Posted: Sun Mar 10, 2019 12:17 pm Post subject: Re: Split bumpers guards from 50-52 |
Doing some research, and found the OP photos are long gone.
Does anyone have images of the two versions and which is which?
TIA! _________________ In Stereo, Where Available! |
sled Samba Member
Posted: Sun Mar 10, 2019 6:57 pm Post subject: Re: Split bumpers guards from 50-52 |
these are 51 guards...
and these are 52 guards...
_________________ drive your split. |
Posted: Sun Mar 10, 2019 7:00 pm Post subject: Re: Split bumpers guards from 50-52 |
Awesome! Thought that was what the 1952 we have should have. Now to find some.
Did not know the other was 1951 only. _________________ In Stereo, Where Available! |
sled Samba Member
Posted: Sun Mar 10, 2019 10:36 pm Post subject: Re: Split bumpers guards from 50-52 |
They’re 51 and older, dating to the ‘banana’ bumpers. I meant 51 as that’s the last year before they switched. _________________ drive your split. |
noheb Samba Member
Joined: October 25, 2005 Posts: 168 Location: Denmark, Europe
Posted: Sun Mar 17, 2019 9:42 am Post subject: Re: Split bumpers guards from 50-52 |
Ribbed bumper guards were used from ca. mid 1949 to 10.1951, then came the thin smooth style. According to earlier discussions on the topic.
Ken. |
Mr. Okrasa Original Old Speed
Joined: May 20, 2000 Posts: 727 Location: Eastside, Costa Mesa. So. Califas...Loco's ;-)
Posted: Sun Mar 17, 2019 10:48 am Post subject: Re: Split bumpers guards from 50-52 |
I've seen all types of split bumper guards. Which is correct for a Hoffman / late April 1950 / 11g Beetle?
See my Instagram: https://www.instagram.com/okrasa/
1959 VW Karmann Ghia Coupe / Bamboo-Green / Denzel 1300cc / OG. owner, paint
Denzel engine running. See this link: https://youtu.be/DgUlsQDTXTE
VW www.Okrasa.com
356 www.PreA356.com
sled Samba Member
Posted: Sun Mar 17, 2019 10:53 am Post subject: Re: Split bumpers guards from 50-52 |
number 4 and 5 are the closest to correct. what do the brackets on the rear look like?
the symmetrical 1 and 2, and large cast number 3 are not original.
I can take some photos of some extra originals I have if you'd like. _________________ drive your split. |
