128vw Samba Member
Joined: April 05, 2006 Posts: 222 Location: Western Massachusetts
Posted: Tue Feb 10, 2009 7:43 am Post subject: Crank balancing |
I sent my 84mm crank out to be banced at my local machine shop and they called this AM and said that they could not do it on their machine.
I then called another shop that specializes in crank work and they say they have the same machine and could not do it. Does this take a special macine or what? Who in my area can do it, Western Massachusetts? |
madmike Samba Member
Joined: July 11, 2005 Posts: 5291 Location: Atlanta,Michigan
Posted: Tue Feb 10, 2009 8:10 am Post subject: |
Nick is kind of close?? _________________ 'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
werka Samba Member
Joined: August 25, 2006 Posts: 1110 Location: Huntsville, AL
Posted: Tue Feb 10, 2009 9:25 am Post subject: |
There are a couple folks on this forum that do this. I believe NSRacing does. I don't know anything about him, but I am pretty sure he does.
Also, I think most folks do the entire rotating assembly (pulley, crank, rods, flywheel, and pressure plate). Everything is balanced together this way.
There was a thread recently on this (it gets a little out of hand towards the end), but NSR has some posts in it.
http://www.thesamba.com/vw/forum/viewtopic.php?t=340458
See page 3 for nsracing posts. you can pm him off these. |
grimace007 Samba Member
Joined: August 30, 2006 Posts: 2673 Location: swampville, florida
Posted: Tue Feb 10, 2009 1:25 pm Post subject: |
to me that doesnt make sense. i was under the impression that a crank balancer is a crank balancer not for any specific type of crankshaft
we will see what the gods say lol _________________ Brian
68 sedan
Dallas Air Coolers
perrib wrote: |
Hey It is The Samba where well thought out rational answers can take a while and getting side tracked is normal. I was just lucky this time. |
cr@M wrote: |
No one has any personal responsibility these days. This country is sue happy. Intelligence is no longer a requirement, just an accessory. |
128vw Samba Member
Posted: Tue Feb 10, 2009 3:26 pm Post subject: |
They tell me that they support the crank on both ends and drive off the center main. With their set up they have no room to get to the center main because their fixtures are too close together.
I found a shop in Greenfield MA about 40 miles away that says they can do it on their machine. I'll find out. They have a good rep around here. Thanks |
Max Welton Samba Member
Joined: May 19, 2003 Posts: 10697 Location: Black Forest, CO
Posted: Tue Feb 10, 2009 5:28 pm Post subject: |
grimace007 wrote: |
to me that doesnt make sense. i was under the impression that a crank balancer is a crank balancer not for any specific type of crankshaft |
That has been my experience. I just took all my rotating parts to the local shop that does V8s for the hot-rod crowd.
But I wouldn't know one balancing machine from another.
Max _________________ 1967 Type-3 Fastback
Home Stretch https://www.thesamba.com/vw/forum/viewtopic.php?t=767836 |
Bashr52 Samba Member
Joined: July 16, 2006 Posts: 5666 Location: On an island in VA
Posted: Tue Feb 10, 2009 7:02 pm Post subject: |
IF they can fit cranks from an 8cylinder, a short little vw crank should be no prob? |
nsracing Samba Member
Posted: Wed Feb 11, 2009 10:31 am Post subject: |
Bashr52 wrote: |
Some older larger balancers have the "underarm" drive belt. It is between the trunnions. With the shorter VW crank, the arm is too large to fit under to drive the crank.
They can set it up so it is "overarm" drive but probably too lazy for that. Or they do not want to swap narrower belt. Or too lazy to move the trunnions closer together. Who knows. |
Ann Mezger Samba Member
Joined: October 13, 2003 Posts: 933 Location: Delaware
Posted: Wed Feb 11, 2009 12:25 pm Post subject: Re: Crank balancing |
128vw wrote: |
VW Cranks have needs of their own & when it comes to most machine shops that can do balancing & other work, it would be cost prohibitive to re-set the machines / tooling to perform one time jobs. The places that can do it, may not find it worth the time unless you're willing to pay additional fees which usually outweigh the cost of shipping the part to someone who is already set up for it.
With that in mind, I have Demello Machine Shop do all of my crank work / balancing on the air-cooled VW stuff. Knowing it will be done right is worth the shipping. _________________ www.vintageperformance.net |
Jake Raby Samba Member
Joined: August 23, 2003 Posts: 7433 Location: Aircooled Heaven USA
Posted: Wed Feb 11, 2009 1:15 pm Post subject: |
The crank is the easiest dynamic component to balance and due to diameter imbalance effects it less than larger diameter components like the flywheel and pressure plate.
I do all my balance work in house, but I won't balance a crankshaft without the rest of the dynamic assembly... Its simply a waste of time. _________________ Jake Raby
Raby Engine Development
www.rabyenginedevelopment.com
"I've never given anyone Hell, I just told them the truth and they thought it was Hell" |
128vw Samba Member
Posted: Thu Feb 12, 2009 11:06 am Post subject: |
Well I had the shop in Greenfield do it. He balanced the pistons, rods,crank, flywheel and clutch all for $200. Did it in 2 days and said that it was not a problem. He couldn't understand what the other shop had for a problem. Maybe they didn't want to take the time to set up their machine for a "little" VW. It's a welded stroker, 84mm, and he said it was not out much at all.
Thanks for the help. Tom |
