palmgreen57 Samba Member
Posted: Mon Dec 19, 2016 6:32 am Post subject: Re: Oval 53 from Belgium |
Thank you for coments guys
Now the nice work is coming !
yan |
RadojewskiPierre Samba Member
Posted: Tue Dec 27, 2016 10:19 am Post subject: Re: Oval 53 from Belgium |
Posted: Wed Dec 28, 2016 8:33 am Post subject: Re: Oval 53 from Belgium |
_________________ 52 microbus
64 singlecab
64 highroof
67 panel |
Posted: Wed Dec 28, 2016 10:20 am Post subject: Re: Oval 53 from Belgium |
Hi,
Today task was to repair the hacked rear apron.
It was cutted in the 70's I guess to fit a double tips muffler.
Now the 53 is back to his original factory condition, my friend Pierre has welded step by step to keep the original paint as much as possible !! The result is nice
Now, I'm working on the paint, next step !!! I'd repaint the apron completely but will try to do only touch up as the paint has not burnt.
New updates soon
Yan
Posted: Thu Jan 05, 2017 1:32 am Post subject: Re: Oval 53 from Belgium |
Hi,
Happy new year 2017
So, the preservation of my 53 continues !
the rear apron is now primered and ready for paint blending
I'm managing to remove the bumps on my front fender with a specialist of this kind of job soon, and we have removed the non correct headlight bucket who was just glued in the fender
So, still looking for correct split bucket, if somebody has it, let me know
Posted: Thu Jan 05, 2017 1:48 am Post subject: Re: Oval 53 from Belgium |
Here is also a new batch of bolts and nuts almost ready for black zinc plating
I'm waiting for the missing bolts I bought from usa
Posted: Thu Jan 05, 2017 6:27 am Post subject: Re: Oval 53 from Belgium |
During christmas holidays I scored this nice straight brake inspection cover and Ate brake reservoir
Posted: Thu Jan 12, 2017 11:36 am Post subject: Re: Oval 53 from Belgium |
Hi,
The paint is now done
Posted: Thu Jan 12, 2017 11:38 am Post subject: Re: Oval 53 from Belgium |
flyingfafa Samba Member
Posted: Thu Jan 12, 2017 11:54 am Post subject: Re: Oval 53 from Belgium |
It's the good way!
Congratulations! |
Posted: Tue Feb 07, 2017 12:55 pm Post subject: Re: Oval 53 from Belgium |
Hi,
The NOS link pin set is now fitted and ready to mount on the front beam.
I'm waiting for order with brake parts and seals to continue
And I'm still stopped on the body with my missing fender headlight bucket... If somebody would help me finding a Oval pair, that'd great
Posted: Mon Mar 20, 2017 12:03 am Post subject: Re: Oval 53 from Belgium |
Hi,
Here some update after fews weeks.
Last week I received the bolts, nuts, small parts I send to black passivation in february, looks like news now I'm happy to see the render !
I also found some nos bolts, I bought from Mika virtanen brand news early style large pan washers that I have also zinc plated.
Now the 53 is almost ready to put the body back on the chassis,
Still waiting for tyres tubes, fit brake pads with rivets and change the broken hubcaps rivets of the wheels
Posted: Mon Mar 20, 2017 12:17 am Post subject: Re: Oval 53 from Belgium |
The 19mm ate 4 bolts cylinders wheels are now ready to fit the car
They received a coat of brown wax as I did on the rear, looks like NOS
I've sourced NOS ate pistons to restore it.
I've found also the missing old style domed screws who hold the brake spring regulator, looks nice !
Posted: Mon Mar 20, 2017 12:27 am Post subject: Re: Oval 53 from Belgium |
Yesterday, we have preparing and fitted the complete brake line, front beam, shocks etc...
Posted: Mon Mar 20, 2017 12:31 am Post subject: Re: Oval 53 from Belgium |
The chassis is now almost finished :
Posted: Mon Mar 20, 2017 12:39 am Post subject: Re: Oval 53 from Belgium |
Next job will be cleaning the fuel tank and cap, change the broken hubcaps rivets, and fit riveted brake pads.
I'm sourcing the last missing parts to finish the 25 hp.
maskinmester Samba Member
Posted: Mon Mar 20, 2017 1:11 pm Post subject: Re: Oval 53 from Belgium |
Looks very nice - just one small note - your locking wire is installed wrong and will not fulfill it´s purpose. It should be fitted so it secures the bolt against rotation in the loosening direction - as it is now it actually pulls in the loosening direction, so you risk that the bolt will work loose over time.
/René _________________ 1954 Beetle - running - Went to HO 17
1961 Beetle in the workshop
1960 Beetle waiting for repair
1956 Unimog 411
30 old farm tractors and stationary engines
1999 Golf - daily driver |
Posted: Mon Mar 20, 2017 1:58 pm Post subject: Re: Oval 53 from Belgium |
Honestly that's what I was thinking too now seeing the pictures !
You confirm it
I'll try to change it
Yan |
Posted: Tue May 09, 2017 3:11 am Post subject: Re: Oval 53 from Belgium |
Hi
here some pictures of this week-end, the brakes are now finished, the brake shoes got a NOS pads set and a layer of yellow clearcoat, they are now ready to fit the chassis.
looks like 64 years ago when the oval left the factory
Posted: Tue May 09, 2017 3:16 am Post subject: Re: Oval 53 from Belgium |
second step was to put back the body on the chassis, very exciting moment
you can see now the rear apron repaired and painted with the paint blend job
