My DIY rear disc brakes (step by step pics)
Page: Previous  1, 2
Franklinstower
Franklinstower is offline
PostPosted: Fri Mar 06, 2009 10:23 am    Post subject: Reply with quote
I say forget Dorman unless that is your only option...
Use Sway-a-Way studs - they have the right knurl diameter - .580" (14.75mm); 14 x 1.5 threads, and come in many lengths. I use the 52 mm studs for my wheels and spacers.
http://www.swayaway.com/WheelStudsAndNuts.php#
just press out the old and press in the new. Also Loogy can provide you with studs that are the correct size etc.
'89 Westy - EJ25/22 Frank 4.44 5mt
'75 Miami Blue Sunroof FI Standard Bug
danfromsyr
danfromsyr is offline
PostPosted: Wed Mar 11, 2009 8:15 am    Post subject: Reply with quote
The Sway-Away site looks good,
though I noticed this *note
sway-away wrote:
Note: Must Drill To 1/2” & Ream Hubs To 9/16” With (.562”) Reamer
Soo do those require additional service like the Dorman brand? or truely a press out-press in replacement stud?
also need to nail down what the length should be.. I guess that depends on if one uses spacers or just thicker Audi aluminum rims.
$4ea can/does add up quick in the project department, but certainly better then $8ea.. and sure who wants to trust a $1 stud..
Dan in NY
Ohh HEY does anyone out there reading this know or have handy a Syncro front Rotor? I need to know the rotor thickness and none of the websites selling them will list it. Thanks
Abscate wrote:
Franklinstower
PostPosted: Wed Mar 11, 2009 9:50 am    Post subject: Reply with quote
No you do not need to ream the hubs. The Sway-a-way studs pressed right in. Maybe it is necessary to ream the hubs on Bugs.
that is my experience anyhow.
JeffRobenolt
JeffRobenolt is offline
PostPosted: Wed Mar 11, 2009 11:14 am    Post subject: Reply with quote
But if you are using Audi rear rotor's the dorman studs center the rotor. If you use a stud with the stock knurl you have to make a hub centric spacer to center the rotor.
So it depends what your doing to decide which studs to use. It's a lot easier to ream 5 holes than make a spacer, that isn't the case if you are using the stock drums, which this post is not about.
Jeff
jfats808 wrote:
Most, some, few is not all. You can always learn something from everyone , even the fool.
danfromsyr
PostPosted: Wed Mar 11, 2009 11:48 am    Post subject: Reply with quote
couldn't I add the retaining screw to hold the rotor in center?
or do we think that would just snap from rotational forces allowed by the slight slop in the rotor to stud fitment?
I'm not against either.. and at the moment I'm leaning the vancafe way.. I've never ordered/recieved cookies Mmmm cookies..
I did get a link from Wellington for Brembo catalog
the Syncro front rotors are 16mm thick with a min spec of 13mm
the Eurovan Rear solid rotors (12mm thick) may be what I need for my Subie E-brake calipers
Abscate wrote:
danfromsyr
PostPosted: Wed Mar 11, 2009 12:09 pm    Post subject: Reply with quote
I'm adding more to this thread but wish to keep stud/nut information consolidated
Here is the AUDI performance guys answer.
www.034motorsport.com Wheel Stud and Nut Kit, M14
034motorsport wrote:
Wheel Stud and Nut Kit, M14 $3.50
Wheel nut and stud combo, M14x1.5 threads, Grade 8.8 with Zinc plating. Supplied in 2 lengths, default is 1.75" (which is fine for most wheel applicaitons w/o a spacer), or 2.5" which would accomodate a spacer. Fits many Audi application with M14 threaded hubs, cone seat for most aftermarket wheels.
For 1.75" stud, lower threads are .4" (10mm) long, upper threads are 1.2" (30mm) long
For 2.5" stud, lower threads are .4" (10mm) long, upper threads are 1.7" (43mm) long
Priced per 1 stud and 1 nut, a 4-bolt car will need a total of 16 pieces, a 5-bolt car will need 20.
Available Options:
Change Nuts to Ball Seat: (+$0.45)
ECS Tuning
has these HUGE CONICAL lug bolts for $13/5
ECS Part # 252735 wrote:
ECS Conical Seat 14x1.5x40mm Wheel Bolt - Set Of 5 $12.95
Conical seat bolts for your aftermarket wheels
ECS own conical wheel bolt set (5). Conical seats fit most aftermarket wheels. Specs:
14mm diameter
1.5mm thread pitch
40mm length
Abscate wrote:
JeffRobenolt
PostPosted: Sat Mar 14, 2009 8:30 pm    Post subject: Reply with quote
Dan you could countersink a set screws to hold the rotor center or drill and use a roll pins.
The washers I used to space the rotors out didn't work. I made a spacer out of AL that was .140" think, I said in a previous post that the washers were 1mm think that was wrong.
With the welded brackets it took a lot of time to get everything to fit good. I have $400 of time into these and could make more for $100, because of all the fine tuning it takes to make them fit good I don't think I would want to sell them.
After it is all said and done,(front and rears) It was worth it, BUT I wouldn't do it again. I would wait til someone mass produced CNC brackets and sorce out the parts. I'm sure it will be happening soon, but I was sick of waiting.
How does the van stop??? The first time I hit the pedal it scared me!! I pushed on the pedal the way I used to and the van stopped so quick. Now I don't even have to press on the pedal very much, before it was both feet on the pedal and gripping the steering wheel to TRY to stop.
It stops as good or better than our car.
Jeff
vwsyncroguy
vwsyncroguy is offline
PostPosted: Sun Mar 15, 2009 1:40 am    Post subject: Reply with quote
How's the emergency brake?
W.C>\?
JeffRobenolt
PostPosted: Sun Mar 15, 2009 6:15 am    Post subject: Reply with quote
Being in Wisconsin the only vehicles that have working e-brake are new cars and old ones that have been used everyday. Normally when you buy a used car it is bad Karma to even touch it, rust and salt sucks.
Most cars with a stick are used enough to keep them working but auto's are most likely seized. Since I have an auto and never used the brake yet, and it was seized I'm in no hurry to hook it up.
When I do hook it up I don't see to much of a problem since it is the same rear caliper that Smallcar and other people are using and they have the ebrake working.
Jeff
danfromsyr
PostPosted: Sun Nov 22, 2009 10:19 pm    Post subject: Reply with quote
getting my hubs turned soon, and have to source the studs still.
I have a pair of VR6 Eurovan rear rotors, that will require thicker shank studs or a hubcentric ring adapter. going with studs option.
will make a nice winter project while I prepare our camper for the VW Sunshine Skyway Treffen we're participating in this april/may
Thanks for the info.
Dan in NY
Abscate wrote:
Wellington
Wellington is offline
PostPosted: Fri Jul 02, 2010 4:34 am    Post subject: Reply with quote
Does anyone know the dimensions of Audi TT 3,2 quatro rear calipers???
The p&p here has a TT, I can get the whole rear set up for $100, I know the rear discs are vented, the hole pattern is 5 x 100, so my real question is , does someone know of a compatible disc to use with these calipers? Maybe the V8 disc?
mozcar78
mozcar78 is offline
PostPosted: Wed Nov 20, 2013 12:04 pm    Post subject: Reply with quote
Grave Bump. I am very interested in doing this upgrade to my van. Thanks for sharing. Now I'm just hoping there is an update on any improvements made on this setup. Also looking for a template for a rear caliper mounting bracket.
Thanks again.
Oscar
89' Vanagon GL 'Free Candy' Edition
81' Rabbit Truck
0cean
0cean is offline
PostPosted: Wed Nov 20, 2013 12:57 pm    Post subject: Reply with quote
x2 on the template for a rear caliper mounting bracket. I will be working on this in 4-5 months for a build.
I'm not a mechanic, I just play one on the internet
Cluster Rebuild:
http://www.thesamba.com/vw/forum/viewtopic.php?t=569920&highlight=
Left for Dead the Resurrection Story Build:
http://www.thesamba.com/vw/forum/viewtopic.php?t=613669
(Number of Different Donor VW Vans Body Parts Used: 12)
(Number of completely different vehicles parts used: 3)
Crankey
Crankey is offline
PostPosted: Wed Nov 20, 2013 3:18 pm    Post subject: Reply with quote
thanks for the info on the studs. I already have new studs in my hubs but might be replacing them with your info about the Dorman studs.
also...you mentioned the e brake
heh, you have read some of the posts regarding e brake function on these calipers...some come out fine, some struggle quite a bit with it.
what about making a scaled up version of something like this to add more pull ?
http://www.parktool.com/blog/repair-help/travel-agent
if this could be mounted before the Y junction in the e brake cable maybe you wouldn't need the bowden cable housings...or need to make two of them.
Page: Previous  1, 2
Page 2 of 2
