GoWesty Sliding Window Screen - anyone have them?
Pascal
Pascal is offline
PostPosted: Sun Feb 15, 2009 3:44 pm    Post subject: GoWesty Sliding Window Screen - anyone have them? Reply with quote
I'm considering buying one of the sliding window screens for my Westy that GoWesty makes:
http://www.gowesty.com/ec_view_details.php?id=3991&category_id=141&category_parent_id=
Does anyone have these? Are you satisfied with them?
Thanks
'84 Westy - 2.2wbx
'91 Cabby
'17 Crosstrek
djs94124
djs94124 is offline
PostPosted: Sun Feb 15, 2009 6:02 pm    Post subject: Reply with quote
I have one of these on the sliding-door window of my '87 camper. The frame is aluminum as compared to the plastic original, so it won't disintegrate from UV over time. Also, the frame and screen are black (at least mine is), in case that matters to you. Looks to be a high-quality piece.
Was fairly easy to install, just follow the directions.
-Dan
1987 2WD Westfalia
Modifications: GoWesty 2300 engine & rebuilt transaxle, 16x7.5 tire/wheel kit, South African "Big Brake" kit, Bilstein HD shocks, Whiteline front sway bar, 2WD Lift Springs, 2nd deep-cycle battery.
Pascal
Pascal is offline
PostPosted: Sun Feb 15, 2009 6:18 pm    Post subject: Reply with quote
So you are satisfied with them? Any rattles? Did you have to modify your window frame? Thanks
'84 Westy - 2.2wbx
'91 Cabby
'17 Crosstrek
djs94124
djs94124 is offline
PostPosted: Sun Feb 15, 2009 6:35 pm    Post subject: Reply with quote
No rattles, nice tight fit. No modification of window frame is required, no drilling or anything. Just a screw driver is all that is needed.
Very happy with this item!
1987 2WD Westfalia
Sigeats
Sigeats is offline
PostPosted: Sun Feb 15, 2009 8:12 pm    Post subject: Reply with quote
I have them too . . . awesome. Very solid. Great fit.
'84 Westfalia
VWGeorge
VWGeorge is offline
PostPosted: Sun Feb 15, 2009 8:14 pm    Post subject: Reply with quote
Great fit, good product.
binger59
binger59 is offline
PostPosted: Mon Feb 16, 2009 5:15 am    Post subject: Reply with quote
I have them and I am pleased. I like the fact that you can replace the screen material. Mine seem to whistle on the highway at speed. When I replace the screen materail I'm gonna go with vinyl to seeif that eliminates the whistle.
Binger
1984 Westy
1986 7 Pass R.I.P. Donor van
2016 Jetta
2014 Passat
2006 Passat
1998 Jetta R.I.P.
1984 Vanagon R.I.P.
tarandusVDub
tarandusVDub is offline
PostPosted: Thu Sep 29, 2011 10:10 am    Post subject: install issue with screws... Reply with quote
I know this is an ancient thread, but I just got one of these and can't get the screws to loosen to install. It looks like the paint has them frozen, and I'm starting to strip them! Shocked Anyone have that problem, or have an idea of how to loosen the screws? Thanks!
blakeck2
blakeck2 is offline
PostPosted: Thu Sep 29, 2011 12:13 pm    Post subject: Re: install issue with screws... Reply with quote
Lay them flat on the table with troublesome screw facing upwards, apply downward pressure and slowly try to turn screw.
1986 Vanagon Syncro GL, westy interior, GW 2.4 and all locked up
1973 Thing
View user's profile Send private message AIM Address Facebook Classifieds Feedback
BadgerSnakeEyes
BadgerSnakeEyes is offline
PostPosted: Fri Sep 30, 2011 7:52 am    Post subject: Reply with quote
Wise words blake. You have alot of experince removing screws, with how many you turned to get all your parts off and painted orange...see you after class by the flagpole!!! Twisted Evil
DrTwee
DrTwee is offline
PostPosted: Mon Nov 21, 2011 5:00 pm    Post subject: GW Window Screens Reply with quote
I agree with all of the above. Good quality product and, yes, the screws are tight.
1982 Vanagon Westy 1.9 Diesel NA (Mello Yellow)
Pascal
Pascal is offline
PostPosted: Mon Nov 21, 2011 6:42 pm    Post subject: Reply with quote
I did buy one and I'm very satisfied with it after 2 years of use. I had a bit of a hard time with the screw too. Smile
'84 Westy - 2.2wbx
'91 Cabby
'17 Crosstrek
HB_Westy
HB_Westy is offline
PostPosted: Sat Jul 19, 2014 11:33 am    Post subject: Reply with quote
I know this thread is old, but I was wondering if anyone had the screen from eurocampers.com. Here is the link:
http://www.eurocampers.com/Vanagon-Westfalia-Passe...p_606.html
Gowesty is out of stock and I found this when searching around.
kalispell365
kalispell365 is offline
PostPosted: Sat Jul 19, 2014 5:00 pm    Post subject: Reply with quote
They are one and the same...
1983 Diesel Vanagon Westfalia chassis with Subaru 2.2l
jobenaus
jobenaus is offline
PostPosted: Mon Jul 21, 2014 6:48 pm    Post subject: Reply with quote
Can anyone tell me what the difference between a Westfalia sliding window and tin top slider is? These sliders say they are for westfalia only?
syncrodoka
syncrodoka is offline
PostPosted: Mon Jul 21, 2014 7:39 pm    Post subject: Reply with quote
The westy slider latch is positioned more towards the middle with different pieces of glass and it clears the screen. The passenger van sliding latch is positioned at the front and will not allow the full time use of the screen like the westy version. The removal of the screens more than a few times will find them broken pretty quickly.
jobenaus
jobenaus is offline
PostPosted: Mon Jul 21, 2014 8:26 pm    Post subject: Reply with quote
Thanks syncrdoka! I see that now that I've had a look at mine. Looks like there really is no way to have a full time screen on a passenger van then. I guess the Velcro has to stay.
goffoz
goffoz is offline
PostPosted: Tue Jul 22, 2014 7:35 am    Post subject: Reply with quote
If you have the older grooved window seal, You can pull out the ugly trim
and use weed wacker string to install regular fiberglass screen directly onto the seals....use a narrow screen roller and lots of soapy water.
Mines been on for a year now, love it, easy to do easy to fix,or remove.
You can even run at freeway speeds,windows open, no issues Very Happy
Bruce Wayne
Bruce Wayne is offline
PostPosted: Tue Jul 22, 2014 8:13 am    Post subject: Reply with quote
a more permanent solution. $2.99 each at Lowes.
