62 in progress Samba Member
Joined: September 21, 2008 Posts: 74 Location: Hesperia
Posted: Sun Feb 15, 2009 4:39 pm Post subject: 40hp oil pump |
Question???
Will the stock oil pump do the job for a 40hp motor with 69 crank and 83 pistons? Or do I need to upgade to something better? |
vwsteve Samba Member
Joined: March 18, 2004 Posts: 1047 Location: Virginia
Posted: Sun Feb 15, 2009 5:30 pm Post subject: |
yes. Just wondering though, are these 40 hp big bore 83's or stock 1500? Did you use 1200 rods or 1300-1600 rods? |
Posted: Sun Feb 15, 2009 6:08 pm Post subject: |
Thanks...
I'm still in the process of getting everything I need (I have 69 crank and bearings already). I'm using 1200 connecting rods (I plan on dropping rods off this week to get turned). Then I will be ordering the 40hp big bore 83's hopefully next weekend. |
Posted: Mon Feb 16, 2009 2:40 am Post subject: |
62 in progress wrote: |
Thanks...
You will need to use shims between the case and cylinders. I think about 2.5 mm thick. (Whatever you increase the stroke by, you need shims half of that if you are not using "stroker" pistons or rods.) |
Posted: Tue Feb 17, 2009 6:04 pm Post subject: |
10-4 VW Steve...
I dropped off my connecting rods today and they charged me 80 bucks to stamp 1-4 on "tangs", hot tank and turn .020 off eash side.
Did I over pay or is this about right? |
