420GOAT Samba Member
Joined: March 31, 2006 Posts: 3343 Location: Wilmington, CA on a nice quiet street but still in the 'hood
Posted: Mon Feb 16, 2009 3:04 pm Post subject: How Much Gas do i have if I can see it? |
approx how much do i have? my guage does not work but when i go to the station can see gas? do i have a lot or not necessarily? whats your take? _________________ once you realize im not impressed we will get along just fine |
danfromsyr Samba Member
Posted: Mon Feb 16, 2009 3:08 pm Post subject: |
i du knoe thet wen te pump kikz, its neer phull _________________
Abscate wrote: |
melville Samba Member
Joined: August 09, 2006 Posts: 1246 Location: Just Outside the Redwood Curtain
Posted: Mon Feb 16, 2009 3:16 pm Post subject: Re: How Much Gas do i have if I can see it? |
420GOAT wrote: |
approx how much do i have? my guage does not work but when i go to the station can see gas? do i have a lot or not necessarily? whats your take? |
Are you sure that you see it? Perhaps you should strike a match to shed some light on the situation.
VW says 15.9 gallons. I presume that means when it starts to go up the filler pipe. Keep a logbook, figure out what your MPG is, and see whether that gets you 200 or 250 or 300 miles between necessary fillups. _________________ 2000 M Roadster
79 R100RS
78 R100/7
75 R75/6
65 Standard Micro
57 Sedan |
theizzardking Samba Member
Posted: Mon Feb 16, 2009 3:28 pm Post subject: |
simple fill it all the way up, fill up a jerry can, clock milage per gps or old fashion way (counting the mile markers on the freeway) run it tiill it dies and then you know fill with jerry can and head home haha _________________ "Democracy is two wolves and a lamb voting on what to have for lunch.
Liberty is a well-armed lamb contesting the vote." - Benjamin Franklin
'71 westie "the wanderer" |
Bloog Samba Member
Joined: April 11, 2007 Posts: 484 Location: Over yonder
Posted: Mon Feb 16, 2009 3:33 pm Post subject: |
Aren't you supposed to work for some big parts house?? Why not just fix the damn fuel gauge?? _________________
Bob Hoover wrote: |
Listen to what the ENGINE has to say. It won't take your money and it's incapable of lying. All you have to do is learn to speak its language.
-Bob Hoover |
chabanais wrote: |
Ah... you buy from Sum Ting Wong Distribution Company. |
Posted: Mon Feb 16, 2009 3:37 pm Post subject: |
i need to pull the tank which is something i dont like to do. i found a stashed used og sender. i think the sender is jamed with rust or something. but i went 80 miles when i could see gas in the neck. but the guage read in a place that left me empty in my driveway. ill read the mileage but the question was how much gas do i have if i still see it , at the very least estimated? _________________ once you realize im not impressed we will get along just fine |
Vanhag Samba Mortician
Joined: June 29, 2003 Posts: 2606 Location: Desert Coast
Posted: Mon Feb 16, 2009 3:48 pm Post subject: |
Damnit dude, put down the f-ing bong! _________________ CU05 w/HBB
HOODRIDANCE |
Posted: Mon Feb 16, 2009 3:49 pm Post subject: |
420GOAT wrote: |
i need to pull the tank which is something i dont like to do. i found a stashed used og sender. i think the sender is jamed with rust or something. but i went 80 miles when i could see gas in the neck. but the guage read in a place that left me empty in my driveway. ill read the mileage but the question was how much gas do i have if i still see it , at the very least estimated? |
Fill it, and be confident that you have at least 15 gal. On late Bays, I can't see gas when it's full due to the bends in the filler. On the Kombi, I've never checked it between fillups. _________________ 2000 M Roadster
79 R100RS
78 R100/7
75 R75/6
65 Standard Micro
57 Sedan |
krimpoo Banned
Joined: December 06, 2008 Posts: 355 Location: gabriola island
Posted: Mon Feb 16, 2009 3:53 pm Post subject: |
why pull the tank?
Take some air controlled snips and cut a nice box above the tank...replace the sending unit and put a nice door where you cut the hole for future needs.If you dont have an air compressor drill four holes in each corner of the box and skill saw out the rest.
The box only needs to be 5 or so inches square. |
Posted: Mon Feb 16, 2009 3:56 pm Post subject: |
krimpoo wrote: |
why pull the tank?
And you think he'll find it on the first try? _________________ 2000 M Roadster
79 R100RS
78 R100/7
75 R75/6
65 Standard Micro
57 Sedan |
Bloog Samba Member
krimpoo wrote: |
why pull the tank?
So...you are the dreaded PO we've all heard horror stories about! _________________
Bob Hoover wrote: |
-Bob Hoover |
chabanais wrote: |
PicklePickle Samba Member
Joined: February 24, 2008 Posts: 933 Location: Gonzales, LA
Posted: Mon Feb 16, 2009 4:00 pm Post subject: |
melville wrote: |
krimpoo wrote: |
why pull the tank?
And you think he'll find it on the first try? |
There are pictures in the gallery that show exactly where it is located and where to cut. Here's one from the forum:
_________________ "Aircooled VWs are like roaches in that if you let one in, they'll soon be nesting all around you in great numbers."
1970 Yellow Beetle aka "Melbourne" |
Posted: Mon Feb 16, 2009 4:18 pm Post subject: |
PicklePickle wrote: |
melville wrote: |
krimpoo wrote: |
why pull the tank?
And cutting that hole is just step one of the SO refusing to ride in the Bus. He'll hear these words, "Honey, I smell gas. Is it safe?" _________________ 2000 M Roadster
79 R100RS
78 R100/7
75 R75/6
65 Standard Micro
57 Sedan |
Posted: Mon Feb 16, 2009 4:20 pm Post subject: |
melville wrote: |
melville wrote: |
krimpoo wrote: |
why pull the tank?
And cutting that hole is just step one of the SO refusing to ride in the Bus. He'll hear these words, "Honey, I smell gas. Is it safe?" |
Not if he takes any time to seal it at all. And what does that matter, his SO--like everyone elses, says that anyway! _________________ "Aircooled VWs are like roaches in that if you let one in, they'll soon be nesting all around you in great numbers."
DaveKingston Samba Member
Joined: October 12, 2008 Posts: 47 Location: Overland Park, KS
Posted: Mon Feb 16, 2009 5:35 pm Post subject: |
What do you use for a door? Is there something at an RV store or marine supply that is "air tight" and would be recommended by someone who has done this? |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Mon Feb 16, 2009 5:53 pm Post subject: |
Go to the salvage yard, and get a cover from a Rabbit. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
dansbus88 Samba Member
Posted: Mon Feb 16, 2009 6:10 pm Post subject: Re: How Much Gas do i have if I can see it? |
melville wrote: |
420GOAT wrote: |
VW says 15.9 gallons. I presume that means when it starts to go up the filler pipe. Keep a logbook, figure out what your MPG is, and see whether that gets you 200 or 250 or 300 miles between necessary fillups. |
Posted: Mon Feb 16, 2009 6:12 pm Post subject: Re: How Much Gas do i have if I can see it? |
melville wrote: |
420GOAT wrote: |
Posted: Mon Feb 16, 2009 6:13 pm Post subject: |
good idea |
Posted: Mon Feb 16, 2009 6:25 pm Post subject: |
This is one I did, out of galvanized sheet metal. Others I have done are a little nicer, as I used thinner metal that was easier to shape. I used a fire stop sealant to glue it down.
Quote: |
I actually found in the Official VW Type 2 Repair Manual the recommended location for cutting a hole in the rear deck to access the fuel sending unit. At one time VW appearently actually even sold a special cover plate for closing off this hole. The hole needs to be 1.25 inches to the right of center and as far forward as it can go on the flat part of the rear deck. VW shows a hole that is 2.75 x 3.125 inches, but this seems a little small. To give better working room the hole needs to be about 4 inches wide (across the width of the vehicle) and 3.5 inches long (with the length of the vehicle). The book shows an oval shaped hole, but several mechanics that I talked to say they cut a retangular flap, leave one edge of it attached, and just bend it back down when they're done.
I cut my hole using tin snips, but there is plenty of room under the deck (about 2.5 inches clearance) for using a sabre saw if you wish. If you've got any fuel leaks I would not use a sabre saw!!! Which ever way you choose to go be sure to clean all the filings off so that none get in your tank. |
