dillon schuh Samba Member
Joined: July 21, 2003 Posts: 343 Location: Sacramento
Posted: Tue Feb 17, 2009 9:25 pm Post subject: I want camber! |
So here is my just painted
This is how it sits now.
it has a adjustable front beam
but the rear has a type one rear end and tranny !
i have adjusted the spring plate as much as i can with out cutting
but i want camber!
what should i do ?
mightymouse Samba Member
Posted: Tue Feb 17, 2009 9:44 pm Post subject: |
dude, your bus is bad ass. color scheme and wheels, Its my new fav pez bus.
Screw camber, your bus is perf height. to get neg camber, your gonna have the back lower than the front. Youll need to notch those plates anyway for suspension travel. otherwise its gonna bottom out all the time.
Thats my dos centavos.
Lates, nice bus. _________________ Nothing can stop the man with the right mental attitude from achieving his goal; nothing on earth can help the man with the wrong mental attitude.
Thomas Jefferson
Note to EVERYONE.
Know your ZDDP levels or you WILL lose a cam and lifters. |
Posted: Tue Feb 17, 2009 9:48 pm Post subject: |
thanks man
And i just put the motor back in last night for the first time in months it runs like a champ one of the best running vws i have ever own !!
so would it just be a good idea to get a pre done spring plate? |
VWsArent4Hippies Samba Member
Joined: April 13, 2005 Posts: 3079 Location: The Bull City
Posted: Tue Feb 17, 2009 10:01 pm Post subject: |
dillon schuh wrote: |
thanks man
Just take your spring plate off and notch it accordingly, nothing special _________________
aeromech wrote: |
in my opinion you don't know shit |
Andrew Samba Member
Joined: October 27, 2000 Posts: 5865 Location: Who in the what now?
Posted: Tue Feb 17, 2009 10:02 pm Post subject: |
You're going to need to notch the spring plates either way, like mightymouse said. The first time you start driving around, your spring plates are going to be bottoming out on every bump. It will drive you insane. _________________ -Andrew |
Posted: Tue Feb 17, 2009 10:04 pm Post subject: |
ok how would i go about doing this
And i am have a hard enough time trying to get my tired in and out of the wheel well
here is another photo (The engine is not in )
C.C.C. Samba Member
Posted: Tue Feb 17, 2009 10:36 pm Post subject: |
Roughly like this,
Radius the corner, I use a .75 drill bit. Then get out your grinder and cut out the line. |
zao Samba Member
Joined: December 29, 2004 Posts: 281 Location: Yucaipa/Calimesa
Posted: Wed Feb 18, 2009 12:09 am Post subject: |
Yup, just drill a hole where those two lines intersect that CCC drew and use a verticle bandsaw to cut it out, if you have access to one. Or you can use a grinder with a cut off wheel, then flapper wheel it after you are done to smooth the cuts out.
I leave my rear wheels on the drums when I take them off. I stick a jack handle in between the springplate stop and the frame, then I either sit on it or have a helper push down on it so the wheel clears. Then reverse the process to get it on. _________________ -Kevin |
Posted: Wed Feb 18, 2009 2:07 pm Post subject: |
so i have to force the plate down to clear the tire ?
and how much lower could i go after cutting that notch out? |
zao Samba Member
Posted: Wed Feb 18, 2009 2:35 pm Post subject: |
Yes, the lower the rear, the harder it will be to clear remove the wheels. On a swing anyways. How low it can go depends on how much you cut out of the springplate. You don't want to cut too much, but if you cut too little, you may still bottom out the plate when you hit bumps.
Look for the tech articles on lowering and modifying the plates. There is a great write up on how and where to cut.
I'm running late, so I don't have the time right now to find the links. Head over to the SBS forums. Lots of great info there! _________________ -Kevin |
der58SC Samba Member
Joined: September 15, 2006 Posts: 1359 Location: Oceanside, CA
