Denture Dan Samba Member
Posted: Wed Feb 18, 2009 9:18 am Post subject: led dash lights |
Just purchased dash light bulbs for my 72, wow nice and bright light instrument panel great they are
Product: 74-xHP Wedge Base LED Bulb $ 2.49 (each)
Options: White 74-WHP
website superbrightleds.com |
i_am_cool_fred Samba Member
Joined: June 26, 2004 Posts: 1743 Location: Benton, AR
Posted: Wed Feb 18, 2009 9:22 am Post subject: |
if you have an alternator i hope you didn't put one on the battery idiot light _________________ proud owner of a defunct 1979 sunroof kombi
Brian Denning, as seen on Gearz TV |
Posted: Wed Feb 18, 2009 9:30 am Post subject: |
nope left that one the regular bulb! |
russwiththebus Samba Member
Joined: September 25, 2007 Posts: 930 Location: Chattanooga, TN
Posted: Wed Feb 18, 2009 9:51 am Post subject: |
Pictures? |
Posted: Wed Feb 18, 2009 9:53 am Post subject: |
Denture Dan wrote: |
cool, just wanted to make sure, i've read to many threads advising against it _________________ proud owner of a defunct 1979 sunroof kombi
busmania Samba Member
Posted: Wed Feb 18, 2009 10:17 am Post subject: |
Quote: |
cool, just wanted to make sure, i've read to many threads advising against it |
Curious as to why? Im no electrical guy and just curious. Thanks. |
Posted: Wed Feb 18, 2009 10:20 am Post subject: |
can u send link to the thread reguarding this, like to read it again thaight i read it a while ago |
WhirledTraveller Samba Member
Joined: January 09, 2008 Posts: 1399 Location: Cambridge, MA
Posted: Wed Feb 18, 2009 11:02 am Post subject: |
I couldn't find the thread either. My search skills are not up to par I guess. However I do know that the way the alternator light works is by "opposing positives". Basically it gets positive on one side all the time with the ignition on. If the alternator is not running then the other side is grounded and current flows. When the alternator is running then the voltage regulator puts positive on that side and no current can flow (positive on both sides) so the light is out.
LED's work in only one direction of current flow unlike a regular bulb which works in both directions.
I don't really see the problem though... these LED's are diode protected against reverse polarity. Perhaps someone can enlighten me. The only pitfall I see to mounting an LED is that, if you use an LED and lose power to the instrument cluster for some reason you will have no indication that this has occurred. In essence you will not have any warning lights working but you will have no knowledge that they are not working. With regular bulbs, failure of the wiring to the instrument cluster might (?) cause the alternator light to come on, warning you that there is a problem. _________________ 1977 Westy, Automatic. Big Valve heads, CS Cam. |
PicklePickle Samba Member
Joined: February 24, 2008 Posts: 933 Location: Gonzales, LA
Posted: Wed Feb 18, 2009 11:17 am Post subject: Re: led dash lights |
These are the right ones?
http://www.superbrightleds.com/specs/74.html
Anyone know if they are the same bulb type for a 74 bus? _________________ "Aircooled VWs are like roaches in that if you let one in, they'll soon be nesting all around you in great numbers."
1970 Yellow Beetle aka "Melbourne" |
Posted: Wed Feb 18, 2009 11:20 am Post subject: |
you know how that gen light comes on when you first turn your key on and then it goes off. the idiot light is setup like that to tell the alternator it's time to work. if you have an led in there it has no way of knowing...lemme see if i can find the thread
http://www.thesamba.com/vw/forum/viewtopic.php?t=259715&highlight=led+idiot+light
that shows how you can use leds and mentions the problem
http://www.thesamba.com/vw/forum/viewtopic.php?t=152455&highlight=led+market+alternator
this kinda touches it here:
Ga69VW wrote: |
Are You aware that a Bosh Alternator MUST have the warning lamp for the current to excite the Alternator? No LED or after market lamp with a different OHM value. One possibility for a eratic charging is a loose conection or a defective lamp? |
that's all i've been able to find evidently you can use led if you do it right. but the reason to not is a regular bulb sends current to the alternator letting it know to turn on (rough crappy unmechanical description anyway) _________________ proud owner of a defunct 1979 sunroof kombi
Posted: Wed Feb 18, 2009 11:41 am Post subject: |
Thanks for that. The first thread says it'll work fine if the polarity is correct.
The second thread says ohms must match to excite the alternator.
Don't know who's right, but I suppose you could put a resistor of the correct ohms in parallel with the LED to make the system think there's a regular bulb there. Solves the problem for sure. _________________ 1977 Westy, Automatic. Big Valve heads, CS Cam. |
Emeritusx Samba Member
Joined: June 20, 2008 Posts: 2775 Location: 12 inches behind the wheel
Posted: Wed Jun 03, 2009 9:59 am Post subject: Re: led dash lights |
I wanted a little more light so I did this. Will try to snap a shot tonight to show the difference in the look... LED's are soooo cool
_________________ 82 Westy ☢, 66 Splitty ☮, 73 Type 181 ✠ |
enjoispammy8 Samba Member
Joined: December 26, 2007 Posts: 1984 Location: Long Beach, CA
Posted: Wed Jun 03, 2009 3:31 pm Post subject: |
ive been looking for this thread, but my searching skills suuuck.
it would be nice to see my speedometer at night. _________________ 1969 Westy, 1690cc. montana red and cloud white.
1969 Standard Beetle [sold]
Watch My Movies: https://www.youtube.com/user/taylorlikesacdc
Desertbusman wrote: |
Is there a message here? Enjoy Spammy Ate |
EZ Gruv wrote: |
Way to fuck up some little kids riding in the car next to you. |
hazetguy wrote: |
you need to be doing better drugs. |
Joined: January 01, 2007 Posts: 16878 Location: sticksville, ct.
Posted: Wed Jun 03, 2009 5:49 pm Post subject: |
enjoispammy8 wrote: |
it would be nice to see my speedometer at night. |
take the speedo housing apart, carefully clean the green plastic domes with some windex and a Q Tip and make sure the white paint on the gauge bezel is clean too. (actually, i painted mine with a highly reflective silver paint, much like 'bumper chrome', made a difference too!)
personally, i like the eerie glow of the green lights. adds to the charm of it all |
Posted: Wed Jun 03, 2009 10:29 pm Post subject: |
Used my daughters camera for these, I am not that good at using it yet tho...
No Flash:
Thumb over flash:
Had it running so the voltage gauge would show too, it has a blue led for a bulb and it just comes on with the gauge (easier wiring)
I like the softer white light as compared to the yellow. I still have 2 bulbs to convert and the tach also. But this lets you see them side-by-side to compare
edit: BTW the gas gauge works, but only shows upper 5 gallons, I am at about 8 down from full _________________ 82 Westy ☢, 66 Splitty ☮, 73 Type 181 ✠ |
bugdaddy Samba Member
Posted: Sun Mar 07, 2010 12:28 am Post subject: |
odd, it runs more RPM with a little flahs |
Air_Cooled_Nut Samba Member
Joined: March 27, 2004 Posts: 3040 Location: Portland, Oregon
Posted: Sun Mar 07, 2010 8:56 am Post subject: |
skills@eurocarsplus wrote: |
Then you must be in love with the Mk.III lighting _________________ Toby http://www.aircoolednut.com/
Did I mention that I'm an original Darksider?
'72 VW Squareback, 2007cc, GB 5-speed, rag top; '76 VW Riviera Penthouse Sundowner 2.0L; 2015 Audi S5 Cabby w/Stage II APR; '06 Ducati Sport Classic 1000; '14 Ducati Diavel Strada
The First Invasion |
Posted: Sun Mar 07, 2010 8:57 am Post subject: Re: led dash lights |
Emeritusx wrote: |
I wanted a little more light so I did this. Will try to snap a shot tonight to show the difference in the look... LED's are soooo cool |
Just those 3 LEDs illuminated that much of the gauges? Wow, nice! _________________ Toby http://www.aircoolednut.com/
SGKent Samba Member
Posted: Sun Mar 07, 2010 9:57 am Post subject: |
how do you adjust how bright they are? Aren't LED's on or off? _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Sun Mar 07, 2010 2:02 pm Post subject: |
I have LED's for my gauge lighting (green ones from Superbrightleds.com that have 3 LED's in one light).
The lighting is just about perfect IMHO. You do lose most of the dimming function. The dimmer still works but has a mild effect, you can basically turn them from "high" to "medium". This could probably be fixed with an appropriate resistor. _________________ 1977 Westy, Automatic. Big Valve heads, CS Cam. |
