Sunroof53 Samba Member
Posted: Wed Feb 18, 2009 11:07 am Post subject: Crankcase cleaning and camshaft bores |
Hello,I am Building another engine for my 53 as my case had corrosion at the sump plate.I have found a 58 case with some external corrosion but the inside is good .If i have the case vapour blasted (water and fine medium) will it affect the coating on the camshaft bores as they appear to have a coating on them which i am not sure if it is special as they run in the case.
Thanks |
azaircooled Samba Member
Posted: Sat Feb 21, 2009 5:17 pm Post subject: |
i would only clean the outside |
Posted: Fri Feb 27, 2009 4:09 pm Post subject: cleaning |
Thanks for reply .i have now removed the oil galleie plugs and despite a thorough clean with solvents before ,i am amazed at the build up still in there.
I am going to fit an external filter.I am not convinced that those period fram filters are much good as the oil lines look way too small.I have noticed though that they are mostly fitted on the return side from the oil switch and back into the case where maybe there is not so much problem.
I intend to take the feed from the pump cover and back in so would need the original 9mm lines to and from the case.I have got an aftermarket spin on filter adaptor and was going to fit it under the back wing.
Will the standard pump be able to cope with pushing the oil through a modern filter ?
Thanks |
