Tram Samba Socialist
Joined: May 02, 2003 Posts: 22711 Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Posted: Thu Feb 22, 2018 5:46 pm Post subject: Re: Eberspacher BN4 info and help FAQ |
Oh yeah, and:
IIRC the fuse box layout in all the wiring diagrams is messed up. I think I was looking at it in the beginning going all "WHATHEFUCK!!" then it occurred to me to look at the 1970 diagram in the owner's manual section on here and it was a match. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Posted: Fri Feb 23, 2018 2:20 pm Post subject: Re: Eberspacher BN4 info and help FAQ |
Shit- I hope I am not too late but I just thought of a way easier way to switch your heater power from the aux. battery to the main one. Just go in the jumpseat and take the wire that feeds the heater out of the top of its fuse holder and couple it with the wire that connects the starter battery to the switchover solenoid- the terminal with the wire going down through the floor. Remove the plastic protective cover on the solenoid and add it to the terminal by just lifting the cover up- it slips off. Add an inline fuse.
Bada bing, bada boom. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
D/A/N Samba Member
Posted: Mon Feb 26, 2018 12:32 pm Post subject: Re: Eberspacher BN4 info and help FAQ |
notchboy wrote: |
And the BN4 in my 77 Westy keeps the chill away
Good to see it getting sorted Dan! |
I noticed something yesterday about the functioning of the 181 switch and I'm wondering if it's normal or is happening because of how I wired the switch (there are still 2 unused terminals on it).
With the engine running and the knob turned just to on (without timer) the heater and the light both work. However, the light goes out when the fuel pump stops clicking and combustion stops. It comes back on when combustion resumes. It's not a problem, but this is my first BN4 experience and I don't know if that's just how it works or not. |
notchboy Samba Member
Joined: April 27, 2002 Posts: 22449 Location: Escondido CA
Posted: Mon Feb 26, 2018 2:34 pm Post subject: Re: Eberspacher BN4 info and help FAQ |
Dude. I didnt know most of how it actually worked till I hooked it up.
Like the run time and cycle. I thought when it went of, it was off. Not cooling down then starting up again.
My light stays on when its on. Not with the pump like yours.
Dont get me going on the timer clock That logic threw me at first. _________________
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
scrivyscriv Samba Electrician
Joined: October 04, 2011 Posts: 2922 Location: Memphis
Posted: Tue Oct 09, 2018 4:08 pm Post subject: Re: Eberspacher BN4 info and help FAQ |
Trying to keep the bus BN4 questions in one main thread -
does anyone know how the wires were routed in the bus engine bay? All the BN4s I have use a 6-blade female connector.. one of them came with a pigtail and the male side, but I don't recall seeing anything about how it was wired up. Other than the manuals posted to the site.. which don't get very deep on this particular topic.
_________________ Robert in Memphis
Engine rebuild thread
If you're ever in the Memphis area, you are welcome to stop by for advice and help. |
Posted: Tue Oct 09, 2018 5:56 pm Post subject: Re: Eberspacher BN4 info and help FAQ |
How I did all mine.
Gray - wire from the switch all the way back to the heater.
Red - straight to battery.
Brown - to the tail light grounding spade on body. _________________
t3kg wrote: |
1964 1500 S
Posted: Tue Oct 09, 2018 5:58 pm Post subject: Re: Eberspacher BN4 info and help FAQ |
I’m talking about the actual wire routing in the engine bay. _________________ Robert in Memphis
Posted: Tue Oct 09, 2018 6:01 pm Post subject: Re: Eberspacher BN4 info and help FAQ |
The Red was just hung up and over the top attached to the underside of the engine bay. _________________
t3kg wrote: |
1964 1500 S
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51128 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Tue Oct 09, 2018 6:07 pm Post subject: Re: Eberspacher BN4 info and help FAQ |
On factory M coded heaters the wires were in the same harness that goes across the shroud to the coil and oil switch, the red and grey wires continued on towards the heater in thier own small black tube. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Tue Oct 09, 2018 6:45 pm Post subject: Re: Eberspacher BN4 info and help FAQ |
Awesome, I was going through the manuals and I found where service installations say to wire it.. it follows the engine harness too. Thanks yall.
Now another question, where do you find info on the different year dash switches? _________________ Robert in Memphis
Posted: Tue Oct 09, 2018 7:19 pm Post subject: Re: Eberspacher BN4 info and help FAQ |
scrivyscriv wrote: |
Now another question, where do you find info on the different year dash switches? |
For a 71 this one will do everything you need: https://www.thesamba.com/vw/classifieds/detail.php?id=2201984 _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Manfreds78bay Samba Member
Posted: Fri Nov 09, 2018 10:16 am Post subject: Re: Eberspacher BN4 info and help FAQ |
This has been a great thread! I'm working on a pre 1970 BN4 now! I just got the fan to come one. For some reason the overheat switch just needed to be adjusted.
I'm planning on removing my heat exchanges and the flapper boxes. They are useless. I've never got them to work right.
I'm thinking about hooking my heater lever in the dash up to the thermostat on the BN4. Any thoughts on that?
I also need to figure a way to put the heat to front cabin. I'm not planning on camping in the winter and the defrost is way more practical. I'm wondering if I can pipe it directly from the back to the front without cutting into the rear fire wall. Thoughts? How crazy would it be to hook this thing up under the driver's pan? _________________ 1978 2.0L FI Campmobile
1982 AMC Eagle SX4 4.2L FI |
Posted: Fri Nov 09, 2018 10:45 am Post subject: Re: Eberspacher BN4 info and help FAQ |
Manfreds78bay wrote: |
I also need to figure a way to put the heat to front cabin. I'm not planning on camping in the winter and the defrost is way more practical. I'm wondering if I can pipe it directly from the back to the front without cutting into the rear fire wall. Thoughts? How crazy would it be to hook this thing up under the driver's pan? |
A dash lever would work for the thermostat, maybe re purpose one of the heat flapper cables?
Tapping into the main duct without cutting will be a challenge, and it can't handle being mounted under the bus, maybe you should be working on a BA-6 instead? It'll bolt right in to a 78 and do everything you need. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Fri Nov 09, 2018 11:22 am Post subject: Re: Eberspacher BN4 info and help FAQ |
busdaddy wrote: |
Tapping into the main duct without cutting will be a challenge, and it can't handle being mounted under the bus, maybe you should be working on a BA-6 instead? It'll bolt right in to a 78 and do everything you need. |
If I come across a nice BN-6, I will think about it. The BN4 pop up locally, so I figured I'd give it a go. Sounds like ill need to do the dead and cut into the bus. Maybe Ill just put a blower up front and enjoy the heating coming from the cabin and call it good. _________________ 1978 2.0L FI Campmobile
orwell84 Samba Member
Joined: May 14, 2007 Posts: 2536 Location: Plattsburgh, New York
Posted: Fri Nov 09, 2018 6:16 pm Post subject: Re: Eberspacher BN4 info and help FAQ |
I have considered installing a BN4 under the bus to tie into the main heating tube, but abandoned the idea in favor of rebuilding the stock heating system. A stock system in working order should do a decent job for defrosting the windshield. I have seen some threads where people have installed a BN4 in the cargo area, though it doesn't tap into the main heater tube. |
vwwestyman Samba Member
Joined: April 24, 2004 Posts: 5688 Location: Manhattan, Kansas, USA
Posted: Fri Nov 09, 2018 10:34 pm Post subject: Re: Eberspacher BN4 info and help FAQ |
I'll quote myself on the heat output specs from my install thread on putting an Espar D2 heater in my Westy.
It sure seems like a lot of work to plumb a BN4 into the stock heating system, and I don't know if the BN4 fan could handle pushing the air that far. You'd probably want a booster fan to help it out. (On my Thing, I've added a flexible duct to the heat output and on occasion it'll blow the fuse as if it is overheating.)
I think Manfried is in the PNW so maybe it doesn't get all that cold, but on a late bay, the factory heater system is the single component that puts out the most heat. The other heaters are boosters/additional heat. (But good ones.)
vwwestyman wrote: |
The Espar heater is rated for quite a bit less BTUs than any of the original heaters for the Buses.
From the Eberspacher manuals:
Heat from a Type IV moter blasting down the interstate: close to 50,000 BTU
BN4: 4000-16000 BTUs
BA6: 24000 BTUs on high
The Espar is rated for 7500 BTUs.
(I cannot find a spec for what BTUs could be expected from a Vanagon rear heater, which I'm using for my two heater cores.)
Therefore it is easy to see why it just doesn't stand up to any of the old heaters. However, that isn't the intention of the heater I used. They are all sold as "parking heaters" and are intended for use in heating up a parked semi to not need to sit and idle for heat as well as use in camping vans.
As I said, it'll warm the Bus just fine while sitting there and lots of people have used them for such. I think a big part of it is you simply don't get as much heat loss when the bus is just sitting there vs driving down the road. Maybe if everything was perfectly sealed, but that is unlikely for most of us.
And it'll add a little extra heat while driving down the road, which is a nice option to have.
But it simply won't replace the stock heater system, which was my point. I have seen threads where posters have asked about this as an option.
It is significantly smaller than a BN4, and while it likely runs more efficiently per size, you simply can only extract a certain amount of heat from a given size heater. |
_________________ Dave Cook
1973 Wild Westerner
My Thing |
D/A/N Samba Member
D/A/N Samba Member
Posted: Sun Jun 09, 2019 2:20 pm Post subject: Re: Eberspacher BN4 info and help FAQ |
So.....I guess I'm the only one who has needed help with one of these things in 2019? It's been very quiet over here since January.
In any case, I have my motor out and while waiting for parts I figured I'd look at the heater ducting. I had a suspicion that some of it had become disconnected during the winter because air output volume changed and the area over the gas tank got really warm when the heater was on. Turned out I was right. The middle duct became disconnected from the one under the back seat.
It also looks like our thermostat control cable is way too long. It's for a Stewart Warner heater and the way it's currently set up, it's hard as hell to operate the control knob under the front seat and when looking at it by the gas tank today I noticed the lever doesn't fully open when the knob is at maximum extension.
Here's the question: Rather than continue to make the wrong cable work with the right heater parts, can I just safety wire the thermostat control lever to be fully open and touching the set screw? I don't think we'll ever want anything less than full heat so I don't mind losing the adjustability of the knob. _________________ '69 Fuel Injected Squareback. "B" D-jet. 1600 with balanced rotating assembly and lightened flywheel. Full flow and external filter.
'70 Riviera. 1904cc w/ 40mm Dellortos, 019 distributor, Steve Tims “super stock” 37x32 heads, Web Cam 218, Vintage Speed SS143 Super Speed exhaust, 1 1/2” heater boxes |
Posted: Sun Jun 09, 2019 2:54 pm Post subject: Re: Eberspacher BN4 info and help FAQ |
D/A/N wrote: |
Here's the question: Rather than continue to make the wrong cable work with the right heater parts, can I just safety wire the thermostat control lever to be fully open and touching the set screw? I don't think we'll ever want anything less than full heat so I don't mind losing the adjustability of the knob. |
That will work, you may find you miss the thermostat later, but there's always the switch on the dash. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
D/A/N Samba Member
Posted: Sun Jun 09, 2019 3:37 pm Post subject: Re: Eberspacher BN4 info and help FAQ |
busdaddy wrote: |
D/A/N wrote: |
That will work, you may find you miss the thermostat later, but there's always the switch on the dash. |
Thanks for affirming that. The last 2 winters, we've just left the knob pulled fully out and have regulated the temperature with either the on/off switch or a window. What we really need is the right cable.....we've had a WTB ad up since November and haven't gotten a single hit.
https://www.thesamba.com/vw/classifieds/detail.php?id=2226560 _________________ '69 Fuel Injected Squareback. "B" D-jet. 1600 with balanced rotating assembly and lightened flywheel. Full flow and external filter.
