notchboy Samba Member
Joined: April 27, 2002 Posts: 22460 Location: Escondido CA
Posted: Sat Jun 22, 2019 8:12 am Post subject: Re: What did you do for your Type 3 today? |
Tough spot for a repair like that. Looks decent enough and should hold you for a bit.
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
DQDan Samba Member
Joined: October 24, 2016 Posts: 351 Location: Cleveland OH
Posted: Thu Jun 27, 2019 1:02 pm Post subject: Re: What did you do for your Type 3 today? |
I STARTED UP MY FRESH REBUILT ENGINE!!!
Woo Hoo!!!
https://youtu.be/Iq_JkwimqYI |
catbox Samba Member
Joined: May 16, 2007 Posts: 865 Location: Portland, Oregon
Posted: Thu Jun 27, 2019 1:29 pm Post subject: Re: What did you do for your Type 3 today? |
Working on rebuilding my enthusiasm for my car.
That is a big thing to restart again as it has all but been lost for a couple of years.
_________________ "...these cars were preferred by the racers because the strut front suspension results in far superior handling than the regular torsion bar front end..." - Keith Seume. |
DQDan Samba Member
Posted: Mon Jul 08, 2019 11:54 am Post subject: Re: What did you do for your Type 3 today? |
Well, I danced the Vermont Shuffle, and scored a title for my 69 SB project. If you are not aware of the procedure, it works like this. Vermont did not have titles for cars in the 60's, and still does not issue them. You can register a 60's car there with just a bill of sale, pay the tax and you can have plates and a registration. Take that registration to your own state DMV and they will recognize you as the rightful owner and should grant you a valid title. It all sounded to good to be true, and it was.. In Vermont they tax you on NADA value of a car, not what you paid for it. The NADA book is a dealer guide, and probably is used to find out how much they can lend/borrow on a car. Anybody want to guess the NADA value on a 69 SB with no engine, sat for 45 years? Yep, you were right. They politely informed me that my car was valued at $12,450 USD and I should submit 6% of that for my $23.00 plates.
Just when you think you've got them, you turn around and zing!! Really, though, now I can move on with the car. The option was to open a case ($300) in local court and plead my case to a judge for a court ordered title. That would take time, driving, and may not even work. At least this way I get a cool single $770 Vermont plate! |
.65vw Samba Member
Joined: August 06, 2008 Posts: 117 Location: Washington - East of Seattle
Posted: Sat Aug 10, 2019 3:40 pm Post subject: Re: What did you do for your Type 3 today? |
catbox wrote: |
Bummer, motivation comes and goes.
My Notchback's idle speed/RPM seemed to be way to low and the notchback was almost stalling when I would stop at a light or stop sign when I took the notch out earlier this summer.
I found/read the Look, Listen, Do it Better twin carb booklet and read up and was all set to do a little first time tweaking of a dual carb setup (I have the tools/flow gauge given to me by the previous owner).
Today as I removed the air cleaner to focus on the carb settings I found that the intake manifold on the drivers side was loose and able to move back and forth, the bolts holding the manifold to the head were both loose.
The front bolt was a pain to get to but with both bolts tightened down the notchback idles like is should again.
A small victory but I know the dual carb adjustment is going to come up some day |
FartsMcFarty Samba Member
Joined: August 18, 2017 Posts: 39 Location: Austin, TX
Posted: Sun Aug 11, 2019 7:52 am Post subject: Re: What did you do for your Type 3 today? |
Adjusted valves on my 69 Fastback yesterday afternoon. First time for me doing valves by myself. I am so grateful for that tattered copy of John Muir's guide which was included with the purchase of a project Beetle still pending completion. I once tried to adjust valves on a Beetle myself about eighteen years ago. Now I know why and how I messed that one up, a bit embarrassing but I'm laughing today. "If I had known then..." I waited until the Fastback was driven approx. 3000 miles to perform this task. John Muir wrote that if we drive in dirty/dusty areas, over bumpy/harsh roads, then we ought to be doing valve jobs every 1500 miles or maybe every 2 months. I do look forward to the next adjustment with the confidence gained yesterday.
Pulled out my speedometer which stopped working about two months ago. Been using the GPS on my phone for the MPH info. but the battery gets drained fast and the wireless service throttled my service. I was disgusted to find a brand new speedometer cable had snapped, it was approximately 4 months old. Installed the original speedometer cable that came with the car, noticed the original cables are thicker and stronger than the new eBay cable.
Oil replaced with Red Line 10w40. Forgot to order an oil filter gasket so this is a priority for the next session.
_________________ Current VW projects:
1966 Standard Beetle
1972 Standard Beetle
1969 Type III Fastback
1971 Type II |
sjbartnik Samba Member
Joined: September 01, 2011 Posts: 5998 Location: Brooklyn
Posted: Sun Aug 11, 2019 12:42 pm Post subject: Re: What did you do for your Type 3 today? |
New shoes
_________________ 1965 Volkswagen 1500 Variant S
2000 Kawasaki W650 |
DQDan Samba Member
Posted: Mon Aug 19, 2019 9:40 pm Post subject: Re: What did you do for your Type 3 today? |
https://www.youtube.com/watch?v=2HDCBL721W8
I drove my 69 SB for the first time it has moved under its own power for the first time in 45 years. 1974 the engine was removed and the car parked. |
Absoluteyeti Samba Member
Posted: Tue Aug 20, 2019 6:25 am Post subject: Re: What did you do for your Type 3 today? |
had the new pan dropped off at my house and started removing old burnt dynamat.
Posted: Tue Aug 20, 2019 8:31 am Post subject: Re: What did you do for your Type 3 today? |
What? Already! Thats sweet!
Good job. Little tuning needed? Sounds like its making popcorn. _________________
t3kg wrote: |
1964 1500 S
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22422 Location: Kimball, Mi
Posted: Wed Aug 21, 2019 11:04 am Post subject: Re: What did you do for your Type 3 today? |
Continued scrapping burnt Dynamat and sanding rust off the new pan I picked up. Looking to coat the pan in the next week or so so i can bolt on the suspension and put the body on it. |
bobbyblack Samba Member
Joined: May 21, 2015 Posts: 4351 Location: United States, Iowa
Posted: Sun Sep 15, 2019 6:17 pm Post subject: Re: What did you do for your Type 3 today? |
After more than two decades apart, I was able to finally get the original engine back under the same roof as the Notch that I've had for 11 years! Hope I can get it together in fewer years to come!!!
_________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
old_man Samba Member
Joined: June 19, 2018 Posts: 1381 Location: Newfoundland
Posted: Thu Sep 19, 2019 2:12 pm Post subject: Re: What did you do for your Type 3 today? |
I installed a alternator. I then played with colour schemes fro my new to me rims I am eventually going to mount. I am unsure about the red, I feel like it might be a bit much.
nogoodwithusernames Samba Member
Joined: November 10, 2014 Posts: 599 Location: CA, USA
Posted: Thu Sep 19, 2019 3:24 pm Post subject: Re: What did you do for your Type 3 today? |
nogoodwithusernames wrote: |
I personally like Pedrini's in black, haven't gotten around to doing mine yet. Also are your rims polished or is that the rough as cast finish? |
I'm thinking black as well a gun metal grey. Not polished yet. Crappy silver paint from the PO. I still have to actually refinish them. The red was a 5 min rattle can job to see what it looks like. |
Posted: Fri Sep 20, 2019 11:08 am Post subject: Re: What did you do for your Type 3 today? |
old_man wrote: |
Black or gun metal will look gook good on them. The red isn't doing it for me though. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Fri Sep 20, 2019 11:53 am Post subject: Re: What did you do for your Type 3 today? |
I like them gray like Glenn has his.
_________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
BornMexican Samba Member
Posted: Fri Sep 20, 2019 7:26 pm Post subject: Re: What did you do for your Type 3 today? |
Got this ‘71 a few weeks ago. Nice and stock. Just taking her out to get to know her.
