axeman569 Samba Member
Posted: Fri Aug 05, 2016 6:06 pm Post subject: Re: What did you do for your Type 3 today? |
I have been stockpiling parts for a couple months now. Today was the day I took all of them to be made into a motor. Building a 1915 with Dual 40 Dells. Mahle 94 P and C's. Can't wait to get it back. Still going to take a while to drive it but that's half the fun. |
TROY WALTERS Samba Member
Joined: April 15, 2007 Posts: 21 Location: spokane wa
Posted: Fri Aug 05, 2016 11:05 pm Post subject: Re: What did you do for your Type 3 today? |
Well i just pushed my new to me 1967 squareback home. my neighbor had it in his back yard for years. paid 400.00 with no motor and boat load of part will start build thread soon
wanda Samba Member
Posted: Tue Aug 16, 2016 1:38 pm Post subject: Re: What did you do for your Type 3 today? |
I gave Wanda her new license plates and took her for a nice ride after a very long time
Rick Christensen Samba Member
Joined: June 22, 2005 Posts: 200 Location: Beaverton, Oregon
Posted: Tue Aug 16, 2016 10:02 pm Post subject: Re: What did you do for your Type 3 today? |
Interesting fog lights. Never seen before. Actually a good match to your late model car. Looks great. _________________ Rick Christensen
Beaverton, Oregon
'65 Notch, '66 Type 34, '68 T-34 sunroof (3rd owner), '88 Doka Syncro, '90 Golf Country, '70 280 SL (second owner), 72 Ford F-100 (original owner), ‘72 280 SEL
'65 Vespa VBB
'48 Aeronca Sedan 4 passenger airplane |
wanda Samba Member
Posted: Wed Aug 17, 2016 12:51 pm Post subject: Re: What did you do for your Type 3 today? |
Rick Christensen wrote: |
Interesting fog lights. Never seen before. Actually a good match to your late model car. Looks great. |
Thank you. The fog lights are "Bosch"-units. I found them at a swapmeet some years ago. |
Posted: Fri Aug 19, 2016 6:33 pm Post subject: Re: What did you do for your Type 3 today? |
Local type 3 guy gave me a truck load of squareback part. A rust free pan / door lot of engine tin a 1600 motor like I said a truck load. |
KTPhil Samba Member
Posted: Sat Aug 20, 2016 9:55 pm Post subject: Re: What did you do for your Type 3 today? |
Replaced a broken shift rod bushing. Kinda a PITA on a Type 3, but I'd done it before years ago so I knew the greasy drill. Went well, and the shifting feels tighter now. Hopefully this will solve my occasional major grinding when trying to find second. More road testing tomorrow.
EDIT: Shifts great now. No slop in the lever while in gear, and now both up and downshifts are positive.
Before, it had enough slop I think it was trying to engage another gear (reverse or 4th) when I was trying to hit 2nd. The grinding hasn't shown its face in two days of driving!
Aaaaaarrrrrgggggg!! The slop and grind is back! Looks like I'll be R&R'ing that bushing again. Not sure if the new one broke, slipped off the bracket, or what. Messy job! Not what I had in mind for my holiday weekend!
Type3Noob Samba Member
Posted: Mon Aug 22, 2016 1:33 pm Post subject: Re: What did you do for your Type 3 today? |
YYesterday, I flushed out fuel lines on my green 73 square and fired her up hoping to attend NYC air cooled show next weekend. Went inside to register for the show only to discover that the show was yesterday. |
ALLWAGONS Samba Member
Joined: June 03, 2000 Posts: 4190 Location: Pasadena CA/DTLA soon China
Posted: Mon Aug 22, 2016 4:44 pm Post subject: Re: What did you do for your Type 3 today? |
Moved the type 34 to the backyard as a nosy neighbor complained to the city, that there was an eyesore in the community and it was called a non running Ghia. _________________ I'd be UNSTOPPABLE if not for Law Enforcement and PHYSICS.
NON INFLUENCER APPROVED |
squaretobehip Samba Member
Joined: August 23, 2004 Posts: 3695 Location: San Jose, CA
Posted: Mon Aug 22, 2016 9:25 pm Post subject: Re: What did you do for your Type 3 today? |
ALLWAGONS wrote: |
Moved the type 34 to the backyard as a nosy neighbor complained to the city, that there was an eyesore in the community and it was called a non running Ghia. |
Dicks. _________________ 1963 Notchback - Ruby Red
1963 Squareback - Pearl White
1965 Squareback - Baltic Blue
Follow ISP West on:
Instagram - @ispwest - www.instagram.com/ispwest |
KTPhil Samba Member
Posted: Sat Aug 27, 2016 5:46 pm Post subject: Re: What did you do for your Type 3 today? |
Gas tank was leaking at large fill hose, especially after gassing up and on left turns. Turned out to be the thin "rubber band" seal between the tank inlet and the fat filler hose. It had torn and was leaking. That part of the filler is actually immersed if the tank is very full, so it has to seal really well, probably why VW added those bands.
I was able to replace it, normally a PITA because the filler hose is so inflexible, and it tends to drag the band out of position or even fold it over when installed.
After sliding the band on the tank inlet dry, I used a very light smear of "spa lube" on the outer surface. Not what you think! It's for lubing pool equipment O-rings and such. Doesn't thin out like vaseline when hot. Anyway, it let the filler hose slide on easy and still seal.
Just filled up. No leaks, no fumes! |
superalex Samba Member
Joined: December 10, 2008 Posts: 60 Location: tavira, algarve, portugal, europe
Posted: Fri Sep 02, 2016 9:36 am Post subject: Re: What did you do for your Type 3 today? |
what is the better thing that you can do for your type 3?
it's to buy it
just did that yesterday
... my second fasty |
Air-Cooled Head Samba Member
Joined: October 15, 2002 Posts: 4070 Location: Chicago Suburbs
Posted: Thu Sep 08, 2016 10:51 am Post subject: Re: What did you do for your Type 3 today? |
Finished installing my ragtop yesterday. 😆
Still lots of other work to do.😩 _________________ Everything known to man has been written.
Readers are Leaders! |
olliek Samba Member
Posted: Fri Sep 23, 2016 1:16 pm Post subject: Re: What did you do for your Type 3 today? |
Painted my Fuchs 2.0 with Porsche correct Würth satin black.
Before:
Afrer:
Knoxxy. |
StephenDerek Samba Member
Joined: June 16, 2013 Posts: 157 Location: Charleston West Virginia
Posted: Sun Oct 30, 2016 3:00 pm Post subject: Re: What did you do for your Type 3 today? |
FINALLY got Farny started..............had to drain all the gas and replace it with fresh and he fired right up
glutenfree Samba Member
Posted: Sun Oct 30, 2016 6:52 pm Post subject: Re: What did you do for your Type 3 today? |
StephenDerek wrote: |
Nice fasty. Cool project name btw
I am refurbishing my generator today. Just have reassembly left and I am done.
Cheers! _________________ 1971 Fastback Build
VW/Type 3 Parts for sale
Instagram
my Shapeways store |
ataraxia Samba Member
Joined: March 19, 2010 Posts: 4504 Location: Illinois
Posted: Mon Oct 31, 2016 12:23 pm Post subject: Re: What did you do for your Type 3 today? |
olliek wrote: |
Before:
Afrer:
Knoxxy. |
These wheels look SO much better when they're all one color! |
LandalftheGray Samba Member
Joined: April 10, 2016 Posts: 52 Location: Rancho Cucamonga
Posted: Sun Nov 06, 2016 6:19 pm Post subject: Re: What did you do for your Type 3 today? |
New Hella style reverse light/third brake light, new brake pressure sensors, new wiring for the horn, new refurbished stock front beam, new shocks all around, and lowered/leveled front and rear.. it's been a super productive weekend
_________________ 2017 Golf R
1969 Squareback
"Part of the ship, part of the crew.."
Last edited by LandalftheGray on Fri Nov 25, 2016 6:22 pm; edited 1 time in total |
Burnz Samba Member
Posted: Sat Nov 12, 2016 8:53 am Post subject: Re: What did you do for your Type 3 today? |
I have been working on the restoration of my 1966 type 3 and decided to remove the body from the chassis. The passenger side pan is completely shot and driver side is on its way. Pretty cool experience lifting the body several feet in the air. Take a look!
_________________ A-A-ron Burnz |
Posted: Sat Nov 12, 2016 12:30 pm Post subject: Re: What did you do for your Type 3 today? |
Ordered my new wiring harness and got my motor built for my '63 type 34.
Two things off the list
Cheers! _________________ I'd be UNSTOPPABLE if not for Law Enforcement and PHYSICS.
