What did you do for your Type 3 today?
Page: Previous  1, 2, 3 ... 201, 202, 203 ... 222, 223, 224  Next
Stevo Wide 5
Stevo Wide 5 is offline
PostPosted: Wed Mar 22, 2017 4:15 am    Post subject: Re: What did you do for your Type 3 today? Reply with quote
Installed new rear hatch seal, engine lid seal and the small seal to close off interior at the back to keep out engine and exhaust fumes! What a difference! Money very well spend!! Also installed a german weave rear carpet to preserve the brittle gray rubber mat!!!
62 Type 3 Notchback
Check out my Aircooled blog @ http://stevo.skyblogs.be
Wide 5 Vintage Volkswagen Club
http://www.wide5.com
JONSMITHBUG
JONSMITHBUG is offline
PostPosted: Sun Mar 26, 2017 8:50 pm    Post subject: Re: What did you do for your Type 3 today? Reply with quote
drilled out the jets and found my problem,drank a beer and looked at her and told her i loved her and felt some relief after a week of hair pulling,,,now ill do it all over again tomorrow because i traded my nice 2001 daily for it,,,my new daily,,,yay
73 beetle w 70 eng 1600sp daily driver,72 squareback
stonecoldcars
stonecoldcars is offline
PostPosted: Mon Mar 27, 2017 9:00 am    Post subject: Re: What did you do for your Type 3 today? Reply with quote
Installed a new upper steering column bushing so I know longer having a floating steering wheel. Soooo much nicer. Also scored a super nice wood steering wheel from my dad he purchased back in 1968 while he was stationed in Germany. I haven't installed it yet cause I'm still working on the new interior, but It will look killer in my fasty.
My build thread(The desert Rat). http://www.thesamba.com/vw/forum/viewtopic.php?t=653395
JONSMITHBUG
PostPosted: Mon Mar 27, 2017 8:45 pm    Post subject: Re: What did you do for your Type 3 today? Reply with quote
tires!
Rustwagon88
Rustwagon88 is offline
PostPosted: Fri Mar 31, 2017 1:24 pm    Post subject: Re: What did you do for your Type 3 today? Reply with quote
Did a bunch of work on the front end today...
NEW:
upper ball joints
lower ball joints
rotors
wheel bearings
calipers
brake pads
fluids
brake lines
Refitting those metal brake lines from the master cylinder to the reservoir is a huge painnnnnnn
savannanotch
savannanotch is offline
PostPosted: Fri Apr 14, 2017 12:41 pm    Post subject: Re: What did you do for your Type 3 today? Reply with quote
Question , Can anybody out there comment on the origin of this oiled foam that is located above the trunk latch bolt on my 69 Notchback. I suspect it is very old as it is somewhat deteriorated. It still is soft and obviously saturated with oil for a reason. Just seems unusual to me .
Question
Mike Fisher
Mike Fisher is offline
PostPosted: Fri Apr 14, 2017 4:44 pm    Post subject: Re: What did you do for your Type 3 today? Reply with quote
That foam doesn't belong there I don't believe. I've found it under the rear fenders, on the air intake box corner.
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Evilgtiguy
Evilgtiguy is offline
PostPosted: Fri Apr 14, 2017 7:27 pm    Post subject: Re: What did you do for your Type 3 today? Reply with quote
Started putting my pan together
66 sunroof Fastback http://www.thesamba.com/vw/forum/viewtopic.php?t=590530
84 Rabbit GTI (gone and missed)
80 Rabbit (gone and missed)
92 Nissan 240SX turbo
Stevo Wide 5
PostPosted: Sat Apr 15, 2017 12:01 pm    Post subject: Re: What did you do for your Type 3 today? Reply with quote
Got the rest of the squareweave carpet set from Fabrik Mike to complement the interior!
62 Type 3 Notchback
Typ3nut
Typ3nut is offline
PostPosted: Sat Apr 15, 2017 6:41 pm    Post subject: Re: What did you do for your Type 3 today? Reply with quote
That Foam is probably from the spare tire block/wedge that came on the '68/'69 models to keep the spare tire from rattling.
savannanotch
PostPosted: Sun Apr 16, 2017 3:39 pm    Post subject: Re: What did you do for your Type 3 today? Reply with quote
It's on the rear hatch lid.
Stevo Wide 5
PostPosted: Mon Apr 17, 2017 10:39 am    Post subject: Re: What did you do for your Type 3 today? Reply with quote
Adjusted the valves today and she runs like new again!!Purrs like a kitten!!
62 Type 3 Notchback
Bobnotch
Bobnotch is offline
PostPosted: Mon Apr 17, 2017 11:59 am    Post subject: Re: What did you do for your Type 3 today? Reply with quote
My guess is one of the PO's added it there to stop a rattle, as normally there isn't anything like that there.
Bob 65 Notch S with Sunroof
Tram wrote:
Tram wrote:
savannanotch
PostPosted: Mon Apr 17, 2017 9:31 pm    Post subject: Re: What did you do for your Type 3 today? Reply with quote
Thanks for the input Bobnotch . Its still a bit of a mystery to me ,the previous owner was an Italian Dentist I don't see him even putting a wrench to the car . He sent it to the shop for any and all work . But I suppose a sloppy mechanic could have been looking for a short cut . The latch is solid ,never rattled.
My best guess is it was used as a convenient spot to keep something to wipe the dipstick. That would explain why it is well oiled.
notchboy
notchboy is offline
PostPosted: Mon Apr 17, 2017 10:20 pm    Post subject: Re: What did you do for your Type 3 today? Reply with quote
Stevo looking sick Cool What's the 411 with Fabrik Mike? Does he make full kits?
t3kg wrote:
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
1977 Westfalia Camper pop-top
Bobnotch
Bobnotch is offline
PostPosted: Tue Apr 18, 2017 10:22 am    Post subject: Re: What did you do for your Type 3 today? Reply with quote
Except normally there's a vinyl covered panel over that opening, so you wouldn't see the latch assembly.
Tram wrote:
Tram wrote:
squareback66
squareback66 is offline
PostPosted: Sun Apr 23, 2017 12:58 pm    Post subject: Re: What did you do for your Type 3 today? Reply with quote
Took a sawzall to it.
OKType3Tim Premium Member
OKType3Tim is offline
PostPosted: Fri Apr 28, 2017 6:46 pm    Post subject: Re: What did you do for your Type 3 today? Reply with quote
Finally got back to working on the T34 (Miss Molly) front end restoration.
The caliper restoration started months ago:
Rebuilt calipers, using Ray's excellent write up on the subject are now installed:
The new master cylinder is installed and plumbed to all four corners:
I uninstalled the steering box, that I rebuilt last summer when that whole rabbit trail started. Now that I can rebush the cover; I tore it completely down and started over.----much better:
State of the front section now with refurbished beam, steering box, calipers. And new tie rod ends, steering damper, and master cylinder:
Tomorrow, figure out the plumbing between the master cylinder and the reservoir.
'69 Squareback restoration
'69 Fastback restoration
'66 Type34
djbeverly
djbeverly is offline
PostPosted: Sun Apr 30, 2017 6:30 am    Post subject: Re: What did you do for your Type 3 today? Reply with quote
Picked up my narrowed front end from autowerks....and almost got the motor ready! Excited!
Bobnotch
Bobnotch is offline
PostPosted: Sun Apr 30, 2017 10:46 am    Post subject: Re: What did you do for your Type 3 today? Reply with quote
Tried to move the 70 Square closer to the shop, only to bury it in the soft ground. Then hooked up a tow strap, to see about getting it out, only to try and bury the tow car. Called it a day, after covering 1 side of the Square in mud. Sorry no pics, as I'm too embarrassed to show the mess we made. Embarassed Laughing
On the plus side, we moved Rob's car into the shop, so he can get back to working on it. Yesterday we even dropped the engine, so we can get some room to weld the rear bumper mounts on. I didn't take any pics, but he did. Very Happy
Tram wrote:
Page 202 of 224
