Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22358 Location: Kimball, Mi
Posted: Tue Nov 14, 2017 12:18 pm Post subject: Re: What did you do for your Type 3 today? |
OhHerrooo wrote: |
Kai4130 wrote: |
Not today but last week.
Fitted my remotec A's.
I dig the look of those fender flares |
Same here. I was thinking a slightly lower profile tire work great on it too. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
blues90 Samba Member
Joined: March 14, 2009 Posts: 1912 Location: Hollywood ,CA
Posted: Wed Nov 15, 2017 9:50 pm Post subject: Re: What did you do for your Type 3 today? |
OhHerrooo wrote: |
USPS man delivered my super-clean OG hurst shifter!
What year is that kit. I remember getting on in 1970 for a 66 bug I owned . The one I got was a bronze color with a walnut wooden knob. I haven't checked if they still make these. |
Posted: Wed Nov 15, 2017 10:25 pm Post subject: Re: What did you do for your Type 3 today? |
I spent the last few weeks on and off fixing grounds on the FI and the dash trying to figure out why on earth the fuel gauge has always jumped when under 1/2 tank and a few raps to the old dash pad would tell me when it didn't move up at all I needed to get fuel . Before some clown ran a red light in mid 2012 it always acted up a bit above 1/4 tank.
Then there is the horn that only works when the engine is running then I find the T/S switch wiper has a small hole worn in. All I started out to do was just fix the plastic horn pad . It was fine until I pulled up on the left top it's a 73 of the pad and it would not snap back down . I was able to find the small plastic piece , one of the three tabs each of the 4 pad mount holes has to snap over 4 plastic posts. I found testors liquid cement smells like acetone would melt the plastic and fuse it back together. Then I snap it on and it held strong now I wish I had removed the wheel and dealt with the horn wiper and ring . I don't want to pull the pad thinking my glue work might , Oh well. Has to be done . The right side same tab had a few small cracks , both sides in just the one spot L&R top two have no good support at that point. I let the solvent glue get in well both so they should hold coming off . not about to pay $65 for a repop one. |
OhHerrooo Samba Member
Joined: September 12, 2010 Posts: 1291 Location: Costa Mesa, CA
Posted: Thu Nov 16, 2017 10:36 am Post subject: Re: What did you do for your Type 3 today? |
blues90 wrote: |
OhHerrooo wrote: |
Not 100% sure on year, I don't have any documentation on it. _________________ '67 Squareback
'69 Squareback
'68 Westfalia
'68 Squareback
OCT3 - Orange County Type 3's
www.evenkeelsurfshapes.com |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13247 Location: Tejas!
Posted: Thu Nov 16, 2017 11:01 am Post subject: Re: What did you do for your Type 3 today? |
Yeah I really lucked out with mine. The repro plastic base covers don't fit as well as the originals and typically you'll find them with missing springs, cracked poly blocks, etc.
To anyone looking, Jeff (glandnut) does amazing rebuilds/custom work for Hurst shifters (first link). _________________ '67 Squareback
'69 Squareback
'68 Westfalia
'68 Squareback
ataraxia Samba Member
Joined: March 19, 2010 Posts: 4504 Location: Illinois
Posted: Thu Nov 16, 2017 12:16 pm Post subject: Re: What did you do for your Type 3 today? |
I wish I'd had the foresight in my early 20's to hang on to the Hurst shifters I had back then...had two 5 gallon buckets of them and damn near gave them all away.
I have a Hurst in my current car - I like the way they function much better than the stock shifter. |
Kai4130 Samba Member
Posted: Fri Nov 24, 2017 3:04 pm Post subject: Re: What did you do for your Type 3 today? |
Bobnotch wrote: |
OhHerrooo wrote: |
Kai4130 wrote: |
Same here. I was thinking a slightly lower profile tire work great on it too. |
I’m hear on The Samba.... of all places and your telling me I need lower profile tyres hahaha. |
Posted: Fri Nov 24, 2017 3:31 pm Post subject: Re: What did you do for your Type 3 today? |
Kai4130 wrote: |
Bobnotch wrote: |
OhHerrooo wrote: |
Kai4130 wrote: |
What size are they? _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Wed Nov 29, 2017 2:12 am Post subject: Re: What did you do for your Type 3 today? |
Bobnotch wrote: |
Kai4130 wrote: |
Bobnotch wrote: |
OhHerrooo wrote: |
Kai4130 wrote: |
What size are they? |
It’s more about what sizes are available.... here in the UK. 16” tyres are very limited in sizes.
The rears where the limiting factor for me. Rears are 245/45/16, as I wanted to maximise the amount of rubber at the rear end.
Fronts are 205/55/16 ( I recall )
I’m not into the cal look, nor am I after stretched tyres which is what they came with when I bought them. 205/50/16’s all round.
StephenDerek Samba Member
Joined: June 16, 2013 Posts: 157 Location: Charleston West Virginia
Posted: Wed Nov 29, 2017 9:19 am Post subject: Re: What did you do for your Type 3 today? |
Finally got all the engine tin and thermostat linkage installed. Now he will sit for the cold months counting down to spring and warm weather.
Posted: Wed Nov 29, 2017 9:20 am Post subject: Re: What did you do for your Type 3 today? |
PS In the last pic I posted it looks like something is missing......am I right or??? |
Posted: Wed Nov 29, 2017 9:33 pm Post subject: Re: What did you do for your Type 3 today? |
StephenDerek wrote: |
There is an opening at the front tin on the firewall section forward of #1 as if it was cut off . The rear lower under cylinder tin bolts to it. |
Posted: Thu Nov 30, 2017 9:52 am Post subject: Re: What did you do for your Type 3 today? |
Once you install the under sled tins, and big heat exchanger boxes, most of that hole will be covered. Some heat boxes have a capped cover plate on them. This is so you can remove the plate to use with single carb engines. VW kept the upper tin shapes pretty consistent over the years, but they also offered different engine combos as well. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
KreepaZoid Samba Member
Joined: December 11, 2014 Posts: 3 Location: Henderson, NV
Posted: Thu Nov 30, 2017 12:34 pm Post subject: Re: What did you do for your Type 3 today? |
Finally got my fasty back on the road after having to pull a head and fix SP thread damag from PO. She's still a work in progress but now I can at least drive her.
notchback Insensitive Jerk
Joined: December 16, 2003 Posts: 7024 Location: Behind the Zion Curtain
Posted: Fri Dec 15, 2017 10:14 pm Post subject: Re: What did you do for your Type 3 today? |
Sold it. _________________
zeen wrote: |
Arguing with johnnypan is like mud-wrestling a pig. After a while you realize he just enjoys playing in the mud, winning the contest is not the point. |
FU#3 |
dannyX24 Samba Member
Joined: August 05, 2016 Posts: 82 Location: Simi Valley, California
Posted: Sat Jan 13, 2018 12:00 am Post subject: Re: What did you do for your Type 3 today? |
Rolled it out to see daylight after mounting up some Rivieras!
sparkywig Samba Member
Joined: July 26, 2008 Posts: 54 Location: Bristol, England
Posted: Sun Jan 21, 2018 9:47 am Post subject: Re: What did you do for your Type 3 today? |
Swapped the front brakes and wheels.
Nikon-User Samba Member
Joined: September 13, 2017 Posts: 33 Location: Switzerland
Posted: Mon Jan 22, 2018 6:56 am Post subject: Re: What did you do for your Type 3 today? |
Some "cleaning" & painting to be ready for sound isolation and new carpet...
