Insaniac Samba Member
Joined: February 13, 2009 Posts: 594 Location: Nor/So Cal
Posted: Thu Feb 19, 2009 3:48 pm Post subject: 3-point and rear seat belts |
Hello again,
I recieved 3 point seat belts, and belts for the rear today, and I'm just wondering a few things.
For the 3 point seat belts, where is the hole at on the b pillar? I've searched, but I usually only find pictures of the earlier years mounting point. Mines is a 1965, and I was wondering if anyone can show me a picture of where there seat belts are mounted. There's padded liner along the sides, and I don't want to be poking holes and destroying it.
With the rear seat belts, I found all the mounting points, but I have a question about these bolts:
Do they connect to anything underneath the car? Are they held on by some nuts? I crawled underneath the car to look, but I couldn't see anything. They sure don't want to budge tho. |
johnanddes Satellite Wrangler
Joined: October 17, 2004 Posts: 692 Location: Orcutt CA
fluxcap Samba Member
Joined: February 07, 2006 Posts: 1969 Location: Newnan GA
Posted: Thu Feb 19, 2009 4:19 pm Post subject: Re: 3-point and rear seat belts |
Insaniac wrote: |
Hello again,
For the 3 point seat belts, where is the hole at on the b pillar? I've searched, but I usually only find pictures of the earlier years mounting point. Mines is a 1965, and I was wondering if anyone can show me a picture of where there seat belts are mounted. |
Here's a pic from an owners manual (i think it's from a manaul)
And here is another pic from the gallery. The circle and arrow is for the rear shoulder mount, but look next to the assist strap, and you'll see the plastic plug where the front shoulder mount is.
_________________ Eric - 1966 camper bus
"It's like, how much more black could this be, and the answer is none.......none more black." |
Posted: Thu Feb 19, 2009 4:38 pm Post subject: |
For the picture in the manual, is the arrow pointing towards the back corner referring to the bolt that holds the back rest up? |
Kafer66 Samba Member
Joined: November 01, 2008 Posts: 201 Location: Tacoma, WA
Posted: Fri Feb 20, 2009 1:34 pm Post subject: |
i have a 66 and after drilling new holes for the seat belts i found the mounts for the outer back belts under the interior rear quarter panels. they have the same plastic srew plug thingamijiggers that the center mounts have. the 3rd mounting point for the front is right about the middle of the edge of the window. when i figure out how to post pics i will.[/img] |
stevenestel Samba Member
Joined: November 12, 2018 Posts: 1 Location: Ogden, UT
Posted: Mon Jun 17, 2019 9:04 pm Post subject: Re: 3-point and rear seat belts |
I was installing new shoulder belts on my 67 and couldn’t find the b pillar mount. After visiting my local air cooled shop I made a few measurements and found them. Here are some photos showing the location as measured from the inside upper corner of the door opening. The mount is a little over 7 inches down and toward the back edge of the b pillar.
