jroymcd Samba Member
Joined: April 18, 2005 Posts: 1053 Location: Bay Area
Posted: Sun Feb 22, 2009 7:20 pm Post subject: im stuck, ( think problem solved ) |
lowered my 67 square about 3 up front. seems like I have no travel. My buddys 66 is at the same hieght and has 3 or 4 inches of travel.
my bump stop arms are cut off and I even pulled the shocks off to make sure they were not bottoming out.
To lower it we just took off the bolt on the oposite side we were lowering, pulled the arm off til it was just about level and put it back togeher. did not mess with the ball joint or upper arm.
what could have gone wrong? _________________ www.cultwagen.com
mufins13 Samba Member
Posted: Sun Feb 22, 2009 7:25 pm Post subject: |
top arm or bottom? |
Posted: Sun Feb 22, 2009 7:34 pm Post subject: |
mufins13 wrote: |
turned the lower arm. _________________ www.cultwagen.com |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Sun Feb 22, 2009 7:36 pm Post subject: |
Did you remove the bump stops?? _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
Posted: Sun Feb 22, 2009 7:37 pm Post subject: |
the top arm could be resting on the stop. theres ttwo one for the bottom and one for the top. post some pics im 3 down |
Posted: Sun Feb 22, 2009 7:40 pm Post subject: |
Russ Wolfe wrote: |
Did you remove the bump stops?? |
cut the arm off _________________ www.cultwagen.com |
Posted: Sun Feb 22, 2009 7:48 pm Post subject: |
my 67 is in the front, the 66 behind is about the same in front and still has travel.
KTPhil Samba Member
Joined: April 06, 2006 Posts: 33991 Location: Conejo Valley, CA
Posted: Sun Feb 22, 2009 7:50 pm Post subject: |
Maybe a ball joint is out of travel? |
Posted: Sun Feb 22, 2009 7:53 pm Post subject: |
KTPhil wrote: |
I do have a upper ball joint with some play. I thought that would make the front end looser not tighter and both sides seem like they are out of travel _________________ www.cultwagen.com |
Adriel Rowley Samba Member
Joined: October 12, 2006 Posts: 4748 Location: Mesa, Arizona
Posted: Sun Feb 22, 2009 11:03 pm Post subject: |
so talked to a few people. from what I understand. because I did not loosen the ball joint like the one on the you tube video, or move the upper arm, the arms are binding. when the car is on the ground the top arm is not alowing the bottom arm from moving down when the suspension compreses.
anyone? _________________ www.cultwagen.com |
gixxer 711 Samba Member
Joined: August 17, 2007 Posts: 589 Location: houston, tx
Posted: Mon Feb 23, 2009 1:08 pm Post subject: |
the upper arm follows the lower arm _________________ Danny |
Posted: Mon Feb 23, 2009 1:25 pm Post subject: |
gixxer 711 wrote: |
the upper arm follows the lower arm |
so if i did not loosen or remove the ball joint could that be whats binding? _________________ www.cultwagen.com |
Posted: Mon Feb 23, 2009 1:35 pm Post subject: |
thinking about it, probably a good chance. since the top arm is the sway bar, you were fighting it to twist the lower arm up. i would undo the bottom arm and the rebolt. _________________ Danny |
Posted: Mon Feb 23, 2009 6:17 pm Post subject: |
I think I got it!
I loosened the all four ball joints. with them hand tight I put the car back on the ground. have plenty of travel.
Think i just needed to let the car re-index it self so the ball joints were at the correct range of motoin. when I go to tighten the ball joints back up I will do it with a jack under the spindle. _________________ www.cultwagen.com |
KTPhil Samba Member
Posted: Mon Feb 23, 2009 8:09 pm Post subject: |
Those ball joints are used to set camber, so they may bind after an alignment.
But then with it lowered that much, who cares about alignment, it'll handle like $hit anyway! |
Posted: Mon Feb 23, 2009 8:16 pm Post subject: |
KTPhil wrote: |
actaully feels pretty good where its at now. way better than any other lowered Vw I've had and I have had a few.
Not a daily driver for sho. maybe drive it once a week to the local Starbucks then to local shows in the summer. _________________ www.cultwagen.com |
KTPhil Samba Member
Posted: Mon Feb 23, 2009 8:33 pm Post subject: |
Read up on the right initial position of the ball joints prior to alignment. Also see that only the lowers are to be used to align. This applies to stock height, but it might also apply to yours. I think Bentley covers it.
Also, see if the car pulls on the freeway, a sign of bad camber. |
Posted: Mon Feb 23, 2009 8:45 pm Post subject: |
KTPhil wrote: |
cool.
might go up a little in back. going to tweak it til I get that perfect stance Im looking for, I still have to replace a bad upper ball joint then i'm going to try to get the alignment as close as possible. _________________ www.cultwagen.com |
