Bay Window Steve Samba Member
Joined: July 13, 2006 Posts: 280 Location: Van Alstyne, Texas
Posted: Sun Feb 22, 2009 8:03 pm Post subject: Which gauges? |
I want to add some gauges inside of my driver, wondering what your thoughts on which would be the most important to have are. Limit yourselves to three. What would you pick? Oil pressure, head temp?
Thanks! _________________ '73 Transporter - Driver
'69 Deluxe
Member: WTKHABG
Original Air Cooler Member |
dbo550 Samba Member
Joined: August 28, 2008 Posts: 365 Location: Kentucky
Posted: Sun Feb 22, 2009 8:12 pm Post subject: |
Add the oil temp and you've got your trifecta. _________________ 1985 Westy
2001 Audi Allroad
1999 Volvo v70 xc
1995 Volvo T5-R, Yellow
1998 Jetta GLX |
Posted: Sun Feb 22, 2009 8:23 pm Post subject: |
Sounds good. Do most people just use an under the dash thing like this?
http://busdepot.com/details.jsp?partnumber=240804 _________________ '73 Transporter - Driver
'69 Deluxe
Member: WTKHABG
CatfishCalhoun Samba Member
Joined: August 04, 2007 Posts: 364 Location: Way to the LEFT
Posted: Sun Feb 22, 2009 8:27 pm Post subject: |
Oil Pressure - CHT - Volt Meter _________________ ". . . In beer there is freedom,
in water there is bacteria." -Ben Franklin |
vw76westy Samba Member
jah_B Samba Member
Joined: March 18, 2008 Posts: 1147 Location: Tempe, AZ
Posted: Sun Feb 22, 2009 9:35 pm Post subject: |
I can't remember how many mounting options I saw when I "looked around the forum" for VDO AND gauges. Some I saw when I did that were done well, and some could be considered hacked. (wait to see mine...lol)
I've seen 4 in the dash where the clock/tach would go, (kind of cool) a real nice set of cut outs below the radio using an extremely well done template and a sharp hole saw, (there's almost no room for error, so it has to be done with great skill and care) the standard three in a plastic under-dash mount, some mounted on top of the dash in the same kind of module, one with a CHT in the steering column mount....etc. etc, limited only by imagination....There's even a digital one for avionics that mounts in the clock hole with an all in one all four cylinder CHT readout, as well as OP, OT, Amps, tach, vacuum, fuel pressure, the shyt gets damn near esoteric if you don't stop reading about it. make yer freakin head spin......
I'm personally going with the altogether obvious 3 under the dash for now, until I have time to screw around cutting up the new un-cracked dash I'll buy later.
So...the most obvious and most useful are CHT, oil temp, and oil pressure, maybe an ammeter, and maybe a tach in place of the clock hole, for those who cannot HEAR their engine....but really dude, in the nicest possible way......there's a LOT of threads on this.
I did not use the S word. God forbid. _________________ 1984 CABRIOLET 6spd, quaife diff, Neuspeed springs, sway bars, tie bar, short shift kit, bilstein shocks, 16X7 RSE 3pc wheels, BFG TA 205 40s
1972 tintop P30 CAMPMOBILE: M/T, 1.7L, dual kadrons, 019 diz. Sunny the S'kool Bus
You gotta know what you don't know. That's the key to wisdom. man. |
Hippopotabus Samba Member
Joined: May 27, 2004 Posts: 1600 Location: Miwuk Village, CA
Posted: Sun Feb 22, 2009 11:00 pm Post subject: |
I like my basic set up. CHT, OT, OP, and Tach. _________________ Celer, Silens, Letalis
www.2dreconbn.net |
Dr. Gonzo Samba Member
Joined: February 17, 2009 Posts: 56 Location: Orange County, CA
Posted: Sun Feb 22, 2009 11:02 pm Post subject: |
Hippopotabus wrote: |
I like my basic set up. CHT, OT, OP, and Tach. |
where did you get the new dash parts??? I'm looking to do the same type of deal |
EvolveES Samba Member
Joined: June 18, 2008 Posts: 261 Location: longmont CO
Posted: Sun Feb 22, 2009 11:12 pm Post subject: |
IF mounting a tach where the clock goes counts as a gage then i would go with a tach, oil pressure and oil temp, if the tach is viewed as a must have item that the factory just happened to leave out (how i think of it) then i would add a oil pressure, oil temperature and volt meter. |
El_Güero Samba Member
Posted: Sun Feb 22, 2009 11:38 pm Post subject: |
i always like looking tach versus vacuum, it helps you learn how to drive your beast in all conditions best; cooler and more fuel efficient, |
Traveling Writer Samba Scribe
Joined: May 07, 2006 Posts: 1112 Location: Florence, Italy
Posted: Sun Feb 22, 2009 11:45 pm Post subject: |
I think you should look at this if you haven't already for your CHT gauge. http://www.dakotadigital.com/index.cfm/page/ptype=...prd347.htm
Analog looks better, but as far as I could determine from a lot of research, they have nothing on the accuracy of this CHT gauge. Watch the temps move up and down one degree at a time, just by thinking about downshifting on that hill...it's very very addictive). If you like, JB weld its sender to the fins next to #3 and you're set (http://www.thesamba.com/vw/forum/viewtopic.php?t=304732&highlight=cht+sender++weld).
Apart from CHT, I've just ordered an Oil Pressure, Oil Temperature, and Tach in the clock hole, so that should cover it. If I had more money, the gauge in the above thread (stratomaster aircraft all-in-one) would be a cool thing, so check it out. Fuel Pressure up front would be handy too.... _________________ Cheers,
Davi
1977 2.0 FI Westy
2011 1200cc Yamaha Super Tenere
1976 Feet (they work surprisingly well) |
Posted: Sun Feb 22, 2009 11:52 pm Post subject: |
[quote="Fuel Pressure up front would be handy too....[/quote]
if its a phisycal reading i don`t think its a good idea to run gas all the way to the front, if your not carefull you can have a live BBQ right at your feet |
Posted: Mon Feb 23, 2009 12:07 am Post subject: |
I know what you mean, El Guero... I was thinking of a sender like for OP and just running the wire... _________________ Cheers,
Davi
1977 2.0 FI Westy
Desertbusman Samba Member
Posted: Mon Feb 23, 2009 2:40 am Post subject: |
With your pancake engine, a CHT gauge is very important from what I read here on the Samba about T-4's with a lot of head problems. With an upright engine I don't think it's a concern and much need for a CHT gauge because of very few problems with heads. Oil Pressure is a must with any VW engine. Oil Temp is also a should have. However it can be misleading and get you in trouble. Once you get super familiar with your engine the OP gauge tells probably more about engine temps. A Volt Meter tells a lot more about the entire electrical system. Not just the charging rate like an amp meter does. A Tach is cool and fun. But actually it doesn't do squat for you once you get intimate with your engine. A bus isn't the kind of vehicle John Force drives at the strip. The speedo does everything you need to know about shift points. Just get familiar with different shift MPH's under the different load conditions. Shift earlier under no load such as going down hill. Let it wind tighter to a higher MPH when it is under a greater load. With a Tach there are no magic numbers. You have to "learn" your engine anyway. The owners manual has info about shift speeds.
Gauges are by far not a total substitute for your natural senses.
Polly didn't want a radio so we put 3 gauges (OP, OT, Volt) in the radio hole by making a mounting panel. That was a nice location. I have 4 in the gauge console just to the right of the speedo. What is real obvious is that if they are right in front of you they are much easier to monitor all the time. Off to the side by the radio they easily get ignored. Either that or a sore neck.
That was kind and accomidating of Jah B to not use that nasty "S" word. However by not using the "S", there is a lot of gauge info and pics that you won't see. _________________ 71 Superbug
71 Westy |
hazetguy Samba Member
Joined: April 06, 2001 Posts: 10773 Location: iT StiNgeD iTseLf tO dEAd
