Front upper grille screws
VisPacem
VisPacem is offline
PostPosted: Fri Feb 27, 2009 11:18 am    Post subject: Front upper grille screws Reply with quote
Hello does anyone know where I can find new, the plastic "screws" that hold the (upper) grill to the body, or a suitable replacement.
Mine seem worn and more and more difficult to lock.
Thanks
LG aka VisPacemPB, *The* party Pooper
No Regrets (Nothing to do with Vanagons)
madspaniard
madspaniard is offline
PostPosted: Fri Feb 27, 2009 11:31 am    Post subject: Reply with quote
here
http://www.van-cafe.com/home/van/page_934_164/upper_grill_mounting_kit.html
and here
http://www.gowesty.com/ec_view_details.php?id=2232&category_id=219&category_parent_id=
Vanagon Nut
Vanagon Nut is offline
PostPosted: Fri Feb 27, 2009 12:39 pm    Post subject: Reply with quote
Because I drilled new grill mounting holes for my conversion: http://tubaneil.googlepages.com/cuttingholeforrad this may not apply, but I used parts from my FLAPS. Nylon (teflon??) "blocks" with a hole in the middle inserted in holes, and black metal screws with hand shaped washers made of doubled over HVAC "tin". (screw head too small for grill holes)
1981 Westy DIY 15º ABA
1988 West DIY 50º ABA
VE7TBN
Terry Kay
Banned
Terry Kay is offline
PostPosted: Fri Feb 27, 2009 10:52 pm    Post subject: Reply with quote
You'll find the new grill screw's, the rubber bungs to retain them to the grill, and the grill clips all available here at the samba.com Vanagon classifieds section very resonably priced.
Or go to;
http://community.webtv.net/VanagonUsedParts/VanagonParts
T.K.
msinabottle
msinabottle is offline
PostPosted: Fri Feb 27, 2009 11:16 pm    Post subject: A suggestion... Reply with quote
I found a sort of 'collapsing rivet' that you held in place with a cheap special wrench, while the screw within it clamped it around the hole into which you inserted it. You end up with a threaded metal opening.
I cut off the 'lips' of my old plastic screws, the rectangular portions, which weren't holding, and then ran the metal screws through that through the threaded rivets. With a Makita to do your screwing and unscrewing, it's a stronger installation.
Best!
'Winston,' '84 1.9 WBX Westy
many ways, but never, never, never in silence."
Terry Kay
Banned
PostPosted: Fri Feb 27, 2009 11:25 pm    Post subject: Re: A suggestion... Reply with quote
<<I cut off the 'lips' of my old plastic screws,>>
What I'm having a hard time undertsandig here--and it's been mentioned twice about "Plastic grill screw's"
They aren't plastic at all.
The are black annodized aluminum.
The stock one's from VW are anyway.
Kinda like a Zeuse or Hilti fastener.
T.K.
msinabottle
PostPosted: Sat Feb 28, 2009 11:36 pm    Post subject: My Bad! Reply with quote
My apologies, I did that on the LOWER GRILL. It's been a long time since I got into that. On the upper, it's as Terry described.
Best!
monstersteve
monstersteve is offline
PostPosted: Tue Jul 30, 2019 8:01 pm    Post subject: Re: Front upper grill screws Reply with quote
I replaced my stock setup with an inexpensive fix with stuff from the hardware store. https://www.thesamba.com/vw/forum/viewtopic.php?p=9134685#9134685
