icekoffee Samba Member
Joined: March 14, 2005 Posts: 1239 Location: DeSoto, Missouri
Posted: Mon Mar 02, 2009 6:25 pm Post subject: Loss of Power in third gear- back again...3-11-09 |
Ok I have a 1960 Single cab, 1600 single port, vacuum advance dizzy with the stock trans mission.
I have been driving it daily with out any trouble for a few weeks straight. I have not has any trouble except now I am losing power in third gear. Fist and second gears are great and the truck pulls great through those but as soon as it hits third gear it cant pull the softest incline. On big hills i can get a run at it but it will soon drop speed to about 20mph and i have to downshift back to second. On flat or slight down hill I can shift into third and things seem fine.
I have replaced the fuel filter already thinking maybe it was all gunked up and restricting the flow.
Any ideas? _________________ 1952 Zwitter
1959 23 Window
1963 Doubleturd
1958 Patina Beetle EJ25
1984 Vanagon Westfalia EJ25
1964 Lifted Mouse Grey Standard
1967 21 Window
1968 Double Bubble
1969 Westfalia
1961 Ragtop Beetle
1984 GTI
1961 Kombi
TyeDyeBug Samba Member
Joined: February 27, 2006 Posts: 236 Location: Coos Bay
Posted: Mon Mar 02, 2009 6:40 pm Post subject: |
check your valve adjustments, you might have a valve problem that making you loose compression in one of your cylinders |
Fish Samba Member
Joined: December 05, 2000 Posts: 5563 Location: OB. It's beside the point.
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24764 Location: Olympia Wash Rinse & Repeat
Posted: Mon Mar 02, 2009 7:09 pm Post subject: |
Definitely full tune up first off.
After that
Check transaxle oil level or change if unknown when last done. Wiggle testing the lower axle for too much play. When changing transaxle oil do a tea leaf reading for any metal chunks from each of the drain points can show a problem before a tow truck is needed.
You did release the E-brake, right???
Check wheels for one that is warmer that may indicate dragging brake problem.
Good to jack up front wheels and see if they spin by hand about the same. Could be bearings in there going bad. When were front bearings cleaned, inspected and repacked with new grease? If unknown do them up!
Remove fan belt and spin gen/alt by hand. Should spin a few seconds after you let it go.
Had a generator get hard to turn. Causing belt squeal at shifting points. _________________ In Stereo, Where Available!
AlteWagen Troll
Posted: Mon Mar 02, 2009 7:12 pm Post subject: |
bad vacuum canister??? |
Fish wrote: |
Stock wheels & tires or big rear wheels & tires? |
stock tires and wheels yeah...
I am hoping that it is not my tranny. It wasnt showing any signs before this and the first two gears pull fine _________________ 1952 Zwitter
1959 23 Window
1963 Doubleturd
1967 21 Window
1968 Double Bubble
1969 Westfalia
1961 Ragtop Beetle
1984 GTI
1961 Kombi |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14269 Location: Casa de Oro, California
Posted: Mon Mar 02, 2009 7:28 pm Post subject: |
Bad fuel pump is my first guess then tank screen then leaky dual-port boots if it's a dual-port. |
Posted: Mon Mar 02, 2009 7:31 pm Post subject: |
BarryL wrote: |
Bad fuel pump is my first guess then leaky dual-port boots if it's a dual-port. |
I have one of the clear fuel filters between the pump and the carb.... it never seems to empty out completely. Single port motor _________________ 1952 Zwitter
1959 23 Window
1963 Doubleturd
1967 21 Window
1968 Double Bubble
1969 Westfalia
1961 Ragtop Beetle
1984 GTI
1961 Kombi |
bc59bus Samba Member
Posted: Mon Mar 02, 2009 8:23 pm Post subject: |
Tune up!!!!!!!!!!!
Time , Points , cond , cap , roto , pulg wires , plugs , vavle adjust - carb
##FUEL Pump## |
Campy Samba Member
Joined: January 10, 2005 Posts: 4933 Location: Chico, CA
Posted: Mon Mar 02, 2009 11:45 pm Post subject: |
What about fourth gear?
The ignition timing may be off (retarded), and the grade and the taller gear is causing it to lose power. Give it a full tune-up, including adjusting the valves. Also, check for vacuum leaks. _________________ Don't worry; be happy. (Baba) |
Posted: Tue Mar 03, 2009 6:29 am Post subject: |
going to start today after work....
going to:
change oil
new plugs and wires
valve adjustment
new points
going to see where those things place me.... if no change i will do a new fuel pump... if nothing then...
thanks for the ideas guys i will keep you posted
here is the turd at hand
1959 23 Window
1963 Doubleturd
1967 21 Window
1968 Double Bubble
1969 Westfalia
1961 Ragtop Beetle
1984 GTI
1961 Kombi |
DeadEndVW Samba Member
Joined: March 23, 2005 Posts: 543 Location: West Side, burning some trash.
Posted: Tue Mar 03, 2009 7:27 am Post subject: |
icekoffee wrote: |
going to:
change oil
new plugs and wires
valve adjustment
new points
Did Rick have same problem? Fuel pump is suspect to me. From a standing stop romp on it hard, shift into second quick and stomp it to the floor. If your pump is bad youll lose power there. |
Posted: Tue Mar 03, 2009 7:42 am Post subject: |
DeadEndVW wrote: |
icekoffee wrote: |
going to:
change oil
new plugs and wires
valve adjustment
new points
thanks for the ideas guys i will keep you posted |
It wasnt happening to rick. The truck has been trouble free since i bought it... untill this of course. That is totally what is happening though. romping into third it just craps out.... maybe i will just just in and do the pump first _________________ 1952 Zwitter
1959 23 Window
1963 Doubleturd
1967 21 Window
1968 Double Bubble
1969 Westfalia
1961 Ragtop Beetle
1984 GTI
1961 Kombi |
Dewayne Samba Member
Joined: October 05, 2003 Posts: 332 Location: Oklahoma
Posted: Tue Mar 03, 2009 8:39 am Post subject: |
Another thought..
I once had the same problem and it turned out to be loose heads. Ended up having to put in case-savers and all was fine.
Does it have an odd 'worbler' sound when it's loosing power? That's it loosing compression around the cylinders/heads... It only shows up when you have the engine under a lot of load.
I hope it is just a tune-up... But if that doesn't fix it..... _________________ "My ex-wife had a hint of a beard and she looked like a manly-girl... that made no difference..."
Drive 'em if ya got 'em, and don't brag if you didn't do the work yourself...
'64 SO34
'60 SO23 |
crofty Judas of the North
Joined: August 09, 2000 Posts: 19672 Location: Land of Whine and Phonies
Posted: Tue Mar 03, 2009 8:52 am Post subject: |
I doubt it's a transaxle problem. Do a tune up _________________ Your Vanagon sucks, Stop waving at me.
HamburgerBrad wrote: |
I slept on crofty's tent once. I passed out drunk from two bottles of Everett's brother's wine. |
Posted: Tue Mar 03, 2009 9:13 am Post subject: |
icekoffee wrote: |
DeadEndVW wrote: |
icekoffee wrote: |
going to:
change oil
new plugs and wires
valve adjustment
new points
It wasnt happening to rick. The truck has been trouble free since i bought it... untill this of course. That is totally what is happening though. romping into third it just craps out.... maybe i will just just in and do the pump first |
Definitely worth a shot, especially if youre running a bocar/brosol pump.
We like to run rebuilt german pumps if possible. |
Campy Samba Member
Posted: Tue Mar 03, 2009 11:32 am Post subject: |
Maybe I am missing something but why would the problem only occur when it's in third gear if it is the fuel pump causing the problem?
Make sure that the ignition timing is set (free and easy to do) and you can tell by looking at the spark plugs if it has been running rich. Make sure that the carburetor's choke is opening up all of the way. _________________ Don't worry; be happy. (Baba) |
Posted: Tue Mar 03, 2009 7:44 pm Post subject: |
Had a chance to work on the truck today.
First i changed the fuel pump- no change
new points- no change (points were spanked though)
new carb- no change (but needed to be done... started dripping gas)
new plugs- TADA solved the problem
thanks everyone for your help. It feels good to know that i can roll the truck tomorrow since its going to be 65 degrees out. get to try out my new safaris
THanks again everyone _________________ 1952 Zwitter
1959 23 Window
1963 Doubleturd
1967 21 Window
1968 Double Bubble
1969 Westfalia
1961 Ragtop Beetle
1984 GTI
1961 Kombi |
pandanom Samba Member
Joined: March 16, 2005 Posts: 1166 Location: Lexington, S.C.
Posted: Tue Mar 03, 2009 7:56 pm Post subject: |
Good work! Don't take this in the wrong way but next time start with the simple or easiest things and work toward the more complicated.
You fixed it! That's the important thing. _________________ It is never too late to have a happy childhood! |
highaltidude Samba Member
Joined: July 18, 2005 Posts: 219 Location: Colorado Springs, CO
Posted: Wed Mar 04, 2009 7:54 am Post subject: |
icekoffee wrote: |
Careful....
Sometimes bad plugs are the problem, sometimes they're just a symptom of a problem someplace else.....
Carry a spare set for a while until you know which you had.
Chuck _________________ 66 Double Cab
83 Vanagon Westfalia, Vanistan'd |
