Lair Samba Member
Joined: January 20, 2009 Posts: 859 Location: The Monkey Ranch
Posted: Wed Mar 11, 2009 9:58 am Post subject: |
Have you tried swapping the carb? |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14271 Location: Casa de Oro, California
Posted: Wed Mar 11, 2009 10:03 am Post subject: |
When your engine is behaving at it's worse, open the gas cap as Ronnie suggested; see if there's a vacuum sound. The fuel filter view is not consistent so don't be freaked out by a full, empty, or part full one. Sometimes a full one means the gas is just pouring into the carb and not being stopped by a full float. If it were doing the problem, and you were over on the side of the road, and you held the throttle wide open what would you describe happens: dies, sputters, starts to rev then dies, backfires, etc. |
pandanom Samba Member
Joined: March 16, 2005 Posts: 1166 Location: Lexington, S.C.
Posted: Wed Mar 11, 2009 11:00 am Post subject: |
icekoffee wrote: |
New piece of info.... I just had the same issue with the truck at my destination after limping along i took a look at my motor. The mine from my pump to my car is FULL and so is the filter there... it is so full that there is absolutely no air in the filter at all. seems like the carb isnt letting gas in... wtf |
I think there should be some air in the filter. I would remove or loosen the tank cap so I know it is vented and try it again. _________________ It is never too late to have a happy childhood! |
LittleThunder Samba Member
Posted: Wed Mar 11, 2009 8:27 pm Post subject: |
icekoffee wrote: |
ok I am back at it again. The truck is running awesome. Good power. climbs hills nicely. etc
although every once in a while it will feel like it is starving out in fourth gear. I will lose power (on hill or flat) and it will sputter and i am forced to down shift. I pull over and sit for a second and i can take off once again without any problems. Its almost like the carb bowls empty out and have to fill up again or something like that. The truck doesnt die just loses power and i have to down shift.
so far i have....
changed the oil
cleaned oil screen
adjusted valves
replaced carb
replaced plugs
replaced plug wires
replaced points
replaced condenser
replaced fuel filter
replaced fuel pump
replaced coil
Drained my gas tank. (there is not screen in my tank) put new gas in
any other ideas? lol |
I don't see timing on the list. |
bugcollections Samba Member
Posted: Thu Mar 12, 2009 7:45 am Post subject: |
One possibility that has already been sort of mentioned is vapor lock. Check your fuel line where it passes the #3 exhaust port and make sure it is where it is supposed to be and not dropping down too close to the exhaust port. Also check your oil temp to make sure the engine is not running too hot. A hot engine compartment can lead to overheating of the fuel line with resulting vapor lock. |
splitpile Samba's Worst Speller
Joined: May 03, 2000 Posts: 5927 Location: back to living where hell meets the suface
Posted: Thu Mar 12, 2009 8:11 am Post subject: |
Is the engine overheating? I didn't see what dizzy you're using? If it's a vac advance, maybe the advance isn't working or sticking? Also if your timing is to far retarded that will cause an engine to overheat and lose of power.
009 set the timing at 30 degrees total at 3000 rpm _________________ Stocking distributor of "The Funky Green Panels"
"no more hacking my sig line" |
Emeritusx Samba Member
Joined: June 20, 2008 Posts: 2775 Location: 12 inches behind the wheel
Posted: Thu Mar 12, 2009 8:15 am Post subject: |
Does it smoke black when its dying?
Also did you change your distributer cap? I reread the list and did not see that. A bad cap can cause intermittent problems. Carbon trailing and such.
Heat is a big issue, My splitty started running like crap when I first took it to the swap meet, but an old timer told me to fix the latch and it would run cooler. I was worried that I wouldn't get home (never took the splitty this far before) But I wedged the door shut and by golly it never sputtered once. _________________ 82 Westy ☢, 66 Splitty ☮, 73 Type 181 ✠ |
