How to chop your Beetle by Clark Customs
Clark Kustoms
Clark Kustoms is offline
PostPosted: Tue Apr 20, 2010 9:51 am    Post subject: Reply with quote
Heres one I've been working on for a customer. We chopped it 5'' and
sunk the top down and forward to meet the windshield frame. I like
how, with the top down, there's no baby buggy shape above the
decklid. And look how fast it can go just siting there (see speedo).
chop your volksrod
http://www.thesamba.com/vw/forum/viewtopic.php?t=345410
https://www.facebook.com/pages/Trailer-Park-Limo/177483138941476
gixxer 711
gixxer 711 is offline
PostPosted: Sun Mar 13, 2011 10:26 pm    Post subject: Reply with quote
bringing back an old topic. did this vert above ever get finished? i was just thinking about chopping the top on my 64 vert and turning it into a fenderless rod.
Danny
Clark Kustoms
PostPosted: Fri Mar 25, 2011 11:53 am    Post subject: Reply with quote
He's workin on it, but top isnt finished yet...
chop your volksrod
R-Baja
R-Baja is offline
PostPosted: Wed Apr 06, 2011 11:22 am    Post subject: Reply with quote
Brilliant idea on moving the convertible top forward and down to match the chopped windshield!!! BTW, on chopping a sedan, keeping the lower body stock (no rat rod look) how would you keep the rear window as large as possible on a 58 and later Bug and how would grafting in an oval section be done on a "flattened" roof line? I am racking my brain on this!
Budreaux
Budreaux is offline
PostPosted: Wed Apr 06, 2011 3:03 pm    Post subject: Reply with quote
A cappella style chop will keep the rear window the same size as stock. I'm assuming you mean the rear window and not the rear side windows. Basically, you are doing a wedge cut at the rear and lowering the front to the hieght you want. The rear pivots at the wedge cuts and is welded back up, keeping the rear window frame untouched and stock. You'll have to do several pie cuts at the upper and lower A pillar to get the alignment right at that point.
RMC66
RMC66 is offline
PostPosted: Sat May 07, 2011 1:57 am    Post subject: Reply with quote
What a great write up! and it leaves me with just one question, what's a guy to do for similar chop while retaining fenders and rear deck lid as is. and no, not wanting a slant chop. it just doesn't look right... sorry not trying to offend those that have it or do it... i just don't like it for the look I'm after
thanks
Budreaux
Budreaux is offline
PostPosted: Mon May 09, 2011 7:22 pm    Post subject: Reply with quote
thanks
My build is just that. Lowered the roof line 6" and widening the fenders. Decklid will be untouched. It's a more difficult process, but worth in in the long run. I've cussed the car many times, but I've stuck with it and should be doing the filler/smoothing in the next two weeks, as long as my work schedule permits.
keltikrewser
keltikrewser is offline
PostPosted: Wed Jul 06, 2011 8:50 pm    Post subject: Reply with quote
Great write up! I've been thinking about lowering the lid on my '66 and was wondering if I could get some advice.
I found ^^this^^ in the Gallery and I LOVE the chop on this bug. I can't quite figure out how it was done. It looks quite a bit different than any shown in this thread. Besides the slanted B pillars, which I understand how to do, the rain gutter on the C pillar looks a lot smother and flatter than most others I've seen and really seems to rake the roof forward.
I've tried to contact the guy who posted it in the gallery(search "black chop" to see more of it) but have not gotten a response.
Any input or advice on how to accomplish this would be greatly appreciated.
Later,
Ryan
TH3 R00KI3
TH3 R00KI3 is offline
PostPosted: Thu Jul 28, 2011 8:30 am    Post subject: coils Reply with quote
what did you do for the suspension in the rear ? i see coil overs but what did you use? and do you have better pictures of it ?
Clark Kustoms wrote:
Heres the car done. You can see how wide the area from the oval and the
first roof line is from making it wider.
HeidelbergJohn4.0
HeidelbergJohn4.0 is offline
PostPosted: Thu Jul 28, 2011 4:33 pm    Post subject: Reply with quote
Later,
Ryan
That looks like a capella chopbut not chopped as much as the original capella bug from the 70's
71 LWB Manx style dunebuggy
71 Beetle
71 Volksrod
Machette Speedster
2012 Passat TDI SE (sadly sitting in a buyback parking lot somewhere waiting for it's heart to be ripped out.)
gmltwc
gmltwc is offline
PostPosted: Sun Aug 14, 2011 10:45 pm    Post subject: Yes, what about the windows? Reply with quote
texson wrote:
Great Info. What about the window work? How do you cut the windows to fit???
More specifically, the side and door glass as well as the windshield. Where do you get those made?
Will any glass place make them up for you?
Is there a better way to do it?
DST155
DST155 is offline
PostPosted: Wed Aug 17, 2011 3:53 pm    Post subject: here is my 65 chop Reply with quote
This is my chopped 1965 beetle, It has had around 4 inches chopped out
6Bug
6Bug is offline
PostPosted: Fri Aug 19, 2011 8:19 pm    Post subject: Reply with quote
Hi, didn't read anything on what to do about the glass. I consider myself pretty crafty, but cutting safety glass sounds scary expensive. This step by step is exactly what I've been looking for, thanks!
JustBuggy
JustBuggy is offline
PostPosted: Sun Aug 21, 2011 8:17 am    Post subject: Reply with quote
I don't know how they cut the glass nowadays but many years ago I worked at a custom body and paint shop and we did own glasswork.
We protected the original glass on both sides by masking everything that we wanted to keep right up to the cut line. Then the cut line was masked with a thick rubberized roofing tape. The glass was then cut by sand blasting along the cut line.
Ya might want to try it on a scrap piece 1st ........
Elchopperfreak
Elchopperfreak is offline
PostPosted: Mon Nov 07, 2011 7:35 pm    Post subject: Reply with quote
For the donor roof and doors, should the car be the same as the one getting chopped or any beetle will do?
The one I am planning on chopping is a 71 super beetle
www.ChopperFreak.com
VOLKSWAGNUT
Fastest VW Belt Changer
VOLKSWAGNUT is offline
PostPosted: Fri Nov 11, 2011 7:06 am    Post subject: Reply with quote
Love this post. Ive been contiplating chopping and rodding my current project. I'd be going the Capella chop route slanting the "B" pillar is ole' school chop.... Still looks the best in my opinion.
aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited
highdesertarabians
highdesertarabians is offline
PostPosted: Fri Jan 27, 2012 7:46 am    Post subject: Reply with quote
how much would someone charge to do a 4"chop? i have a 66 straight roofed bug i want done.
Clark Kustoms
PostPosted: Sun Jan 29, 2012 4:50 pm    Post subject: Reply with quote
I charge $2500.
chop your volksrod
subgraphic
subgraphic is offline
PostPosted: Sun Jan 29, 2012 7:26 pm    Post subject: Reply with quote
I charge $2500.
With glass and seals? Very Happy
View user's profile Send private message AIM Address Yahoo Messenger MSN Messenger Gallery Classifieds Feedback
SA-Rattie
SA-Rattie is offline
PostPosted: Tue Mar 06, 2012 5:24 am    Post subject: THANKS MATE! Reply with quote
Thanks for this post, I've been reading through it a lot, I will use this method to chop my Rat as it is a great look! The car looks great and the owner must be really happy with it?!! Keep up the good work! Cool
Page 7 of 9
