JeffRobenolt Samba Member
Joined: February 25, 2007 Posts: 1513 Location: Wisconsin
Posted: Thu Mar 12, 2009 9:19 pm Post subject: Rear shocks toping out, what are my options. |
My nose high 85 just got leveled.
I cut some spacers out of a cutting board as per the post on here.
It gave me an 1.5" lift and leveled the van at 19", pretty high. My Monroe coil spring shocks top out now.
What shocks do I need now? Does anyone sell adapters to get my shocks back in there travel?
Thanks Jeff _________________ --------------------------------------------------------
jfats808 wrote: |
Most, some, few is not all. You can always learn something from everyone , even the fool. |
shorepig Samba Member
Joined: November 30, 2005 Posts: 516 Location: Vancouver, B.C.
Posted: Thu Mar 12, 2009 9:32 pm Post subject: |
I also drive an 85 westy with saggy ass syndrome, so I popped some spring helpers into my rear coils and it raised it up exactly 1.5 inches. Today I installed Bistein HD's and they are not topping out. Maybe you could switch to Bilsteins.
A question for you:
Now that you've raised up the back of your van you have changed the angles on your cv's. Are your cv's making any odd noises...do you feel any vibration at hwy speeds? |
Posted: Thu Mar 12, 2009 9:44 pm Post subject: |
If you raise the rear it will make the cv angles greater.
I don't notice any noise or any other problems with the cv's.
Can I use syncro rear shocks? _________________ --------------------------------------------------------
jfats808 wrote: |
offroad. Samba Member
Joined: January 01, 2009 Posts: 211 Location: llanelli, s wales
Posted: Fri Mar 13, 2009 3:52 pm Post subject: |
you could try something like this.
lee. |
PDXWesty Samba Member
Joined: April 11, 2006 Posts: 6246 Location: Portland OR
Posted: Fri Mar 13, 2009 3:54 pm Post subject: |
Nice! Where can you get those? |
Posted: Fri Mar 13, 2009 4:20 pm Post subject: |
dont know if anyones making them commercially, but not hard to make only a metal bracket welded to an old shock bottom.
lee. |
Posted: Fri Mar 13, 2009 5:39 pm Post subject: |
I just ordered some shocks for a 05 Chevy Astro van that are suppose to be the same as the Syncro shocks, almost 3" taller than the Monroe coilovers.
NOW I just hope that the Syncro rear mounts are the same as the 2wd.
Anyone know?
jfats808 wrote: |
Posted: Sat Mar 14, 2009 8:42 am Post subject: |
Does anyone know if the rear shock mounts on a Syncro are the same as a 2wd?
jfats808 wrote: |
Posted: Wed Mar 18, 2009 4:39 pm Post subject: |
The Syncro shocks did fit, They are the same as Chevy Astro shocks, which most parts stores carry.
jfats808 wrote: |
