ceramic vs. reg exhaust
What exhaust system?
Ceramic coated
66%
 66%  [ 12 ]
Regular paint
33%
 33%  [ 6 ]
Total Votes : 18
goskiracer
goskiracer is offline
PostPosted: Fri Mar 13, 2009 12:02 pm    Post subject: ceramic vs. reg exhaust Reply with quote
So while crawling about the syncro today I noticed that my muffler is quite rusted through, along with most of my 22 year old exhaust. eventually all the pipes, cat etc needs to be replaced. Would you recommend the ceramic coated exhaust or the regular painted bits? I will be moving to Ohio in august for grad school and this is my daily driver. Thanks.
86' Syncro 2.2 Vanistan, WBXhaust, ski-pole shifter for +11hp
TheBlueTurtle
TheBlueTurtle is offline
PostPosted: Fri Mar 13, 2009 12:04 pm    Post subject: Re: ceramic vs. reg exhaust Reply with quote
id be interested to know too..
do they cost the same?
84 Westfalia (Goldie)
GoWesty 2.2
Dogpilot
Dogpilot is offline
PostPosted: Fri Mar 13, 2009 12:06 pm    Post subject: Reply with quote
Ceramic. My S&S's are four years old now here in the high snow country and are still going strong. This pic is last year, but they still look the same:
Geology with a Syncro rocks!
98 Disco I
08 Range Rover SC
08 VW Rabbit S
1951 O-1G
goskiracer
PostPosted: Fri Mar 13, 2009 12:10 pm    Post subject: Reply with quote
Dogpilot, is that the S&S group from the Bus Depot?
the caveman
the caveman is offline
PostPosted: Fri Mar 13, 2009 1:11 pm    Post subject: Reply with quote
Unless you want to watch all the money you spent on the exhaust you just got rust within a few months ,then the only choice is ceramic or stainless. If you are planning on keeping it for a long time and storing in in winter outside then the only choice is stainless. And even then there's cheap and good stainless.
Dogpilot
Dogpilot is offline
PostPosted: Fri Mar 13, 2009 1:15 pm    Post subject: Reply with quote
Actually, I bought mine direct from S&S along with the muffler. I can't imagine the BusDepot S&S being different. I do not think there was a difference, except shipping, S&S is nearly local to me in AZ.
98 Disco I
08 Range Rover SC
08 VW Rabbit S
1951 O-1G
madspaniard
madspaniard is offline
PostPosted: Fri Mar 13, 2009 2:28 pm    Post subject: Reply with quote
can you guys post where you bought your exhaust system (S&S) or where to buy the best stainless steel system? This is something I'm going to have to do sooner rather than later.
Dogpilot
Dogpilot is offline
PostPosted: Fri Mar 13, 2009 2:53 pm    Post subject: Reply with quote
http://www.ssheaders.com/4cylinder.htm
98 Disco I
08 Range Rover SC
08 VW Rabbit S
1951 O-1G
SteveVanB
SteveVanB is offline
PostPosted: Fri Mar 13, 2009 8:14 pm    Post subject: Reply with quote
I am having/had(install went smooth,everything fit) great luck with the kit from evwparts! Get the hardware kit and gasket kit from vancafe (copper nuts/quality gaskets)and chuck the crappy gaskets that come w/the exhaust kit! Oh yeah,,,,,p-nut oil on the pipes after your first trip to the beer store!
91 CARAT
OilNBolts
OilNBolts is offline
PostPosted: Sat Mar 14, 2009 1:20 pm    Post subject: Reply with quote
Ceramic is superior if the cost doesn't scare you. I had it done by Jet-Hot on an exhaust system for a motorcycle (Buell X1) and it had some light rust a few years later. But, far less than it would have had if I'd used barbecue paint.
Jet-Hot would have warrantied the job, but I would have had to disassemble the muffler, and that was a bear when the thing was still unused.
My point is, I expected the system to look great forever, and that really didn't happen. But it was expensive.
Current fleet: Vanagons, two '88s and an 89 Bluestar EJ25D. Beetles, '63, '64, '72 convertible. '89 Cabriolet. Plus, three Subarus and several lesser vehicles. Too many cars.
