Louis Samba Member
Joined: September 26, 2007 Posts: 423 Location: canada BC
Posted: Sat Mar 14, 2009 10:18 am Post subject: Need help 36hp stroker! |
here what i have:
36hp
okrasa head
okrasa 69.5 crank
now my problem is pistons and cylinder...
is the 83mm 40hp bigbore kit fit the 36hp rods?
how thick the shim as to be get comp ration of 8:5.1
what modification do i have to do to make it work?
THanKs!!!! |
beetleseb Samba Member
Joined: November 09, 2006 Posts: 430 Location: Cheltenham UK
Posted: Sat Mar 14, 2009 1:39 pm Post subject: |
I'm doing something similar at the moment
I belive the 40hp big bore pistons will fit as the wrist pin is 20mm but the cylinder will be a lot of work.
Porsche cylinders can be made to work but they are not cheap.
You may be able to use chevy journal con rods ment for later vw engines with overseized bearings (they are 2" 36hp is 50mm) to get the 22mm wrist pin if that helps
Good luck
Seb |
grueni Samba Member
Joined: November 03, 2008 Posts: 582 Location: Germany
Posted: Sat Mar 14, 2009 4:47 pm Post subject: |
chevy rods a way to long for a 36hp engine. |
Posted: Sun Mar 15, 2009 3:20 am Post subject: |
grueni wrote: |
My Bad, I'm still learning
Good luck sould be a fun toy!
Seb |
Louis Samba Member
Posted: Wed Mar 18, 2009 12:43 am Post subject: |
help someone??
please....
someone done it?
help a brother out!! |
grueni Samba Member
Posted: Wed Mar 18, 2009 3:38 am Post subject: |
what kind of help do you need?
pistons will fit...cylinders only with alot of work stud holes and dimensions ...
you need to open case and heads und cylinders too.
and if you do this you can make your hads or (and) cylinders to your compression ratio...good kuck |
Louis Samba Member
Posted: Thu Mar 19, 2009 12:42 pm Post subject: |
thanks...
all this is a puzzle... can get confusing and pricey if you buy the wrong parts!
just trying to follow someone else experience with this kind of project.
cheers |
grueni Samba Member
Posted: Thu Mar 19, 2009 1:44 pm Post subject: |
for sure you are right. but it's also "just" an engine |
Louis Samba Member
Posted: Fri Mar 20, 2009 12:14 am Post subject: |
what about a 69.5 okrasa crank with 356 piston rods and 22mm pin piston would it work?
is the okrasa crank or stock 36hp crank fit the 356/912 rods? |
grueni Samba Member
Posted: Fri Mar 20, 2009 7:26 am Post subject: |
noo,...sorry. smile
you sound like a child in candyshop |
Posted: Fri Mar 20, 2009 8:51 am Post subject: |
Its a dark art these early engines and too many people are keeping quiet!
Luckily they always correct me when I'm wrong so heres what I know, please let me know where I mess up!
36hp crank = 50mm rod journals
Porsche crank = 53, 54 or 55 (cant remember of the top of my head)
porsche and later 1300 + vw pistons = 22mm wrist pin
36 and 40hp = 40hp wrist pin
40hp plus barrels have a different stud spacing so won't bolt on
You can get a big bore 83mm piston for a 40hp with the 20mm wrist pin. You can search on the mahle website for products but I can't find a 83mm with a suitable wrist pin
On the engine I'm building now I'm hoping to use
83mm big bore cylinders
Highly modded barrels from a 1500sp (cue angle grinder )
64mm crank and con rods
Heads with 33in and 30 out and just a bit of porting
A mr okrassa cam
8.5 to 1 comp ratio
Twin 28pci carbs
Hopefully I will get 45-50 bhp.
Good luck with yours
Seb |
Julio Iniguez Samba Member
Posted: Fri Mar 20, 2009 3:56 pm Post subject: |
The 40hp big bore do work and it's not that bad. Turn them 90 degrees and they fit over the stud patern and the way we trimmed them was with a die grinder & cutting disk. We measured how much had to be trimmed then with the grinder scored the fin about half way through grabbed some channel locks and slowly bent up til the fin snapped on the line. All four took about an hour.
Julio |
mightymouse Samba Member
Posted: Fri Mar 20, 2009 7:14 pm Post subject: |
Specs on this cam your speaking of? anyone? guess i could just email joe..LOL _________________ Nothing can stop the man with the right mental attitude from achieving his goal; nothing on earth can help the man with the wrong mental attitude.
Thomas Jefferson
Note to EVERYONE.
Know your ZDDP levels or you WILL lose a cam and lifters. |
Louis Samba Member
Posted: Sat Mar 21, 2009 12:03 am Post subject: |
thanks Julio!
i will order a set of 40hp bigbore.
i was reading a okrasa article saying that the original kit was coming with 4 head spacers and 4 pushrod spacers... anyone using those and who is machining something like that?
cheers |
grueni Samba Member
Posted: Sat Mar 21, 2009 12:15 am Post subject: |
i don't know if mr. okrasa do it too, but okrasa ,öttinger use in his old okrasa engines the old 356 preA cams. |
Louis Samba Member
Posted: Sat Mar 21, 2009 10:46 am Post subject: |
i was reading a few old post from coolairx2, he said that he has a okrasa motor with 69mm crank and 912 82mm pistons. said that Joe sold him the pistons...how the hell did he fit the 22mm pin on the okrasa crank? |
Posted: Sat Mar 21, 2009 11:43 am Post subject: |
The mr okrassa cam is basically 36 reground to a pre a. He sent me the specs and its a fast road, tame race cam acording to my head guy.
As soon as I've sold some bits I'll buy one
You can lose the bushes on the con rods to run 22mm but its not a great Idea and will limit you to about 30,000 miles. Or you could bush up the pisyons but its another thing to go wrong!
Seb |
Louis Samba Member
Posted: Sat Mar 21, 2009 2:50 pm Post subject: |
can you post the specs of that cam? |
gimmesomeshelter Samba Member
Joined: May 08, 2004 Posts: 1466 Location: San Carlos, CA
Posted: Sun Mar 22, 2009 11:27 am Post subject: |
Hello-
Have you considered having a set of pistons made to your specs? JE will do it for ~ $800.
BTW, have you read "Souping The Volkswagen"? http://www.oldspeed.ch/pages/press-souping.htm If not, it will probably answer many of your questions.
Paul _________________ "I would rather have questions that can't be answered than answers that can't be questioned."
Richard Feynman |
