Corn1849 Samba Member
Joined: December 04, 2006 Posts: 116 Location: Wood River Valley, Idaho
Posted: Sat Mar 21, 2009 5:34 pm Post subject: Power Steering Line leak |
Hope fully this is a simple quuestion.
I've got a leak in my Power Steering Line, just south of the fuel tank.
I assume this is the Suction Hose?
The rubber line/clamps are the problem.
What type/size of hose is correct for replacement?
Will I need to bleed the system?
ATF Dexron or VW Hydraulic Oil (G 002 000) ?
Thanks,
Marc
_________________ Now: '89 Westy
Then: '99 EVC
Before then: '84 Westy
Way before then: '64 Bus |
One by One Samba Member
Joined: August 14, 2003 Posts: 43 Location: Northern Wisconsin
Posted: Sun Mar 22, 2009 9:40 am Post subject: |
I'd look into replacing the entire line with hose rather than a installing/replacing a patch.
You will need to bleed the system to get the air out, which is easy. Use ATF fluid. I'd also replace the power steering filter, I think this filter gets clogged which causes higher line pressure which leads to leaks (my theory anyway). _________________ '91 Carat |
Posted: Sun Mar 22, 2009 9:56 am Post subject: |
One by One wrote: |
I'd look into replacing the entire line with hose rather than a installing/replacing a patch. |
Now I'm really confused.
Was this a patch in the rigid line or an original "coupling point" (like the one in the pressure line)? _________________ Now: '89 Westy
Then: '99 EVC
mr_vanagon Samba Member
Joined: March 31, 2005 Posts: 589 Location: Southern Illinois (GO SALUKIS)
Posted: Sun Mar 22, 2009 10:39 am Post subject: |
That's a coupling point not a repair. My '89 has one in the same place and it is stock.
I'm wondering how to bleed the PS system. I'm going to have to replace one of the hoses at the pump. I already planned to replace the filter but I have no clue on bleeding.
Anybody have experience here? _________________ '68 Autostick Bug Mom bought new
'89 Tintop Vanagon Dad bought new |
jeremysmithatshawdotca Samba Member
Joined: February 11, 2002 Posts: 2530 Location: Edmonton, AB
Posted: Sun Mar 22, 2009 11:37 am Post subject: |
I think you just fill the reservoir up to the line, and turn the wheel all the way back and forth from stop to stop several times, recheck the reservoir, fill if needed, and repeat, until the fluid level remains static. |
presslab Samba Member
Joined: September 29, 2008 Posts: 1730 Location: Sonoma County
Posted: Sun Mar 22, 2009 12:22 pm Post subject: |
Yes, that short hose is original. You could get some tranny cooler hose from your FLAPS. Man, I wish my van was as rust-free as yours.
I use Dexron III in mine. Now would be a good time to flush your system as well.
Do as Jeremy says and the system should pretty much bleed itself... _________________ 1986 Vanagon Westfalia EJ25
1988 Subaru GL-10 EJ20G --- 2000 Honda XR650L
2010 Titus El Guapo --- 2011 On-One 456 Ti |
