MAYHEM Samba Member
Joined: January 30, 2006 Posts: 1813 Location: Warm and sunny coastal CT
Posted: Tue May 19, 2009 1:06 pm Post subject: |
project bug wrote: |
I thought I did a good job. |
Looks good to me _________________ Greg
Model Citizen
johnnypan wrote: |
I digitize myself in the privacy of my own home. |
project bug Samba Member
Posted: Tue May 19, 2009 1:24 pm Post subject: |
RoachGhia wrote: |
Looks good to me! I love the color of the shroud against the body color, and the red wires are a nice contrast. I hate the oil cooler, but you already said you're working on moving it.
I don't understand the problem you're having with the seals though, even with the diagrams. But as a general rule, engine tins fit like crap, and take a lot of patience to get installed, especially when you have to use aftermarket parts. Can you take a picture of the part that you're having trouble with?
In my experience, the pulley tin will not clear an aftermarket oil pump with a full-flow fitting in it, so that little bit will have to be trimmed most likely. So you're not doing anything wrong, it's just a common problem there.
Good job, man! keep it up, and have fun with it! |
Thanks Roach, and Mayhem
I used cast iron engine paint for all the tin.
I figured out a solution for the ill fitting tin and seal problems. You are correct with the pulley tin requiring some trimming. I flipped the seal over installing it incorrectly from what I have seen, which offered more clearance. The upper cylinder tins do seal against it now.
The main problem was the breast plate running into the header, and not bolting up so nicely to the upper cylinder tins... I can fabricate a new one which is no big deal.
Once the oil cooler is moved I will install the deck lid propped open on the bottom only. Considering the natural vacuum created by a totally sealed engine compartment will not be created my may concern is shielding the exhaust heat from the engine. I do have the firewall plate installed too.
The back tires sticking out are still a little "mullet" for me. _________________ 1964 Sunroof |
BigHerc Samba Member
Joined: November 26, 2006 Posts: 809 Location: sierra madre, CA
Posted: Tue May 19, 2009 4:50 pm Post subject: |
BigHerc wrote: |
looks good man, nice work!! |
Thank you.
I like your build also. _________________ 1964 Sunroof |
Posted: Thu Aug 20, 2009 5:35 pm Post subject: |
Well, summer is almost over and it's time to plan for this winter.
In light of a few things I've noticed with the car the body is coming off the pan as soon as I complete finishing the garage. Considering the stuff I want to do it makes sense to go that far.
Last month the master cylinder failed... That was fun!
Most of my plans seem the same as I start to ponder new parts.
The engine has a bit of an odd noise so I'll go through it. Probably new pistons and cylinders so I can get rid of the thinwall 92's
It's quick enough for what I want to do so I'll leave the FK8 and 44 IDF's.
The trans weaps a bit of fluid so I'll go through that too.
I may do a little work to the heads though.
As for the chassis. I'm still torn on body color, interior color, and wheels.
I do know the colors will be OE VW. The original color was Ruby red but I've been kicking around mango, another green, or panama biege.
Intererior color of choice is still red at this time.
Disc brakes for sure but I'm not sure if I want to stick with wide five or go smaller bolt circle and use a more modern rim in the 17" flavor. The purist in me says stick to the wide five, so we will see.
Another idea I had was to run the painted slotted 356 type wheels with no caps to go for kind of an outlaw look. Minimal, simplistic, but functional.
Suspension wise since everything will be replaced I'll narrow the beam a bit and run a fully threaded coilover front and back eliminating the torsions. I may even go IRS on the back if I decide to go a bit more modern with the look of the car. Coming from a strong racing history all the negative camber if I decide to go low really bothers me.
Sometimes I hate starting a project and making all the decisions....
But In short it will be "GFK clean" with my flavor. _________________ 1964 Sunroof |
german69 Samba Cow Hand
Joined: December 10, 2006 Posts: 352 Location: North Idaho
Posted: Thu Aug 20, 2009 10:57 pm Post subject: |
This thing already looks dope! Cant wait to see it next year! i will be following your progress for sure. Just keep us updated.
Nice work and good find on that bug! _________________ GoodVanGarage |
Posted: Fri Aug 21, 2009 8:37 am Post subject: |
german69 wrote: |
Nice work and good find on that bug! |
Thank you.
I can't believe I found one this solid for the price in Michigan. _________________ 1964 Sunroof |
Posted: Mon Aug 24, 2009 2:57 pm Post subject: |
As I look around at for ideas this makes me a little happy in my pants. It's almost elegant in a way.
Posted: Sun Sep 13, 2009 6:14 pm Post subject: |
In order to start work you must have the proper space.
Man, I'm glad to see a little light at the end of the tunnel. Between work, my girl's parents house, the garage, and building a shed this weekend the last month or so have been so busy.
I started with two bare walls, dirty concrete, and a bunch of mess. I moved in with my girlfriend so the garage was pretty much a catch all.
The lofts the PO of the house hung to the right were way to big and a bitch to take down. Dimensions of garage are 25x16.
10 sheets of pegboard, 3 epoxy floor kits, some lumber, and a whole lot of cleaning I'm this far.
The floor laid out really well. I decide to use the speckles since the concrete had some flaws.
I still need to paint the wall on the left and finish around the door. I plan to print some pictures I've taken over the years for that wall.
The stuff on the floor to the right still needs a home. I also plan to relocate the shelf to make room for 4 foot bench will will hold my vise and drill press.
Lowes had counter tops on sale last week so I decided to pick up a 6 footer for my bench. In total I have less than $75 into it with paint.
I haven't mounted my grinder yet but you can see my spiffy new air compressor.
Now it's almost time to take the body of the pan of my car for resoration. _________________ 1964 Sunroof |
bigblue Samba Member
Joined: July 20, 2006 Posts: 451 Location: where the c-130s fly!
Posted: Sun Sep 13, 2009 7:12 pm Post subject: |
no fair....
i do however like your tool box.post your garage in the garage fest thread... _________________ 1966 Sedan (Dad owned in Germany '74-'75)
1970 Yukon Yellow Sedan 'Puddin' SOLD
1970 Beetle Convertible (under restoration) SOLD
1970 Sedan (fresh restoration)Trophy Queen
1973 Super Beetle (Totaled in '99)
1972 Standard Beetle SOLD
looking for a 1969 Beetle hardtop
i mess with sasquatch on weekends.
jmsmilin wrote: |
...he will be tucking blocks soon... |
Posted: Mon Sep 14, 2009 5:53 am Post subject: |
bigblue wrote: |
no fair....
i do however like your tool box.post your garage in the garage fest thread... |
lol, thanks. I'm quite happy with how it turned out. _________________ 1964 Sunroof |
iaccy Samba Member
Posted: Mon Sep 14, 2009 1:35 pm Post subject: |
iaccy wrote: |
I'd be afraid to work in there and get anything dirty |
lol. Just have to clean up when I'm done. Although I will be a little careful with the floor. Especially bleeding brakes. _________________ 1964 Sunroof |
Posted: Fri Oct 30, 2009 6:04 pm Post subject: |
Well,
I am still on schedule as of this week. The car is coming apart sooner than I hoped but after some inspection I feel it's ready to be freshened up. I'll let the pictures do some speaking.... Overall, it's as solid as I thought so far.
Interior and the seats I didn't like removed
The sunroof area is very solid
Here is the original color, in OG paint exposed.
Heater channels and other bits are very solid. No holes I can see as of yet.
Yeah, I need a new harness.... I can't believe the mess.
Rusty, rusty, but everything is very solid and I seen no signs of any patching anywhere.
After much inspecting and looking for witness marks I don't see any real patching our major body work.... Until everything gets media blasted I think I'm dealing with an original pan. _________________ 1964 Sunroof |
OTO X58 Samba Member
Joined: March 27, 2004 Posts: 3102 Location: Santa Cruz, CA
Posted: Fri Feb 22, 2013 5:45 pm Post subject: |
OTO X58 wrote: |
BUMP!
How's this thing coming along? |
Well man, I took it all apart, removed one pan and it's been sitting because life got in the way and a bunch of changes took place.
As much as it pains me I might sell it once spring hits if the money is right but I'm going to regret it. It's far too solid of a project and one of my favorite cars.
The pan ended up being original, the driver side is great. All the sheet metal seems to be original while the heater boxes and everything else are wonderful. I'm not surprised considering it was from California and had less than 5000 miles put on it over the past 20 or so years.
It will be a great project for someone if I sell it. You don't come across too many this solid around these parts. _________________ 1964 Sunroof |
sportyvw Samba Member
Joined: March 12, 2004 Posts: 25 Location: Clinton Twp, MI
Posted: Fri Feb 22, 2013 8:10 pm Post subject: |
Here's an old pic when I used to own her. Maybe it will inspire you to get her back on the road.
Posted: Wed Feb 27, 2013 1:55 pm Post subject: |
Thanks for the pic Sporty.
After much internal debate I'm going to keep it and get back on it as soon as the weather warms up.
It's way too solid of a car and to good of a project to get rid of without regretting it. _________________ 1964 Sunroof |
63karmanng Samba Member
Posted: Fri Mar 01, 2013 7:55 pm Post subject: |
Definitely will be following this build! Keep the updates coming! _________________ I don't think that the voltage matters because the gauge is mechanical. |
fish26 Samba Member
Posted: Wed Mar 19, 2014 4:18 am Post subject: |
Any updates on the bug, keen to see the progress. |
